Question about Akai LCT2701TD Television
My tv will work perfectly, then the sound will disappear and then reappear, at random times and for random periods. i changed my tv, but it still does the same. i have virgin tv.
Picture disappear while sound still on?
My first go-to place would be any connectors you removed when you did the repairs -- as since this happened after a period of successfull run-time, HEAT may have caused them to expand to the point where a minimally-connected contact is failing. (And I admire your tenacity on taking on a job like that in the first place!)
Jan 29, 2016 | Element Electronics FLX3711B 37 in. LCD TV
Do you think it is a coincidence that a thin vertical blue line appeared both times when the analogue to digital signal transition was occurring? After the first tower changeover finished it disappear
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 15, 2014 | Panasonic Televison & Video
Prima Cineplus 50" Plasma PH-50R18C will not turn on
The ambient temperature might be high. Check whether the foolinf fans are working or not. If not, check out the reason for it. The TV must be placed at least 6cm away from wall, and should have sufficant ventilaation.
Nov 15, 2013 | Televison & Video
TV is working beautifully then the screen goes dark for 3-15 seconds and then the image reappears in beautiful HD. The TV is two years old and otherwise works perfectly
Technology changes at a high rate of speed, as we all know. And High Definition (HD) has come a long way in a very short period. Since your television still works perfectly otherwise, I don't think that it's a problem with the set itself. It may only be a victim of technology.
Does this only happen with High Def channels? Does it happen every time you change to another HD channel? If you answer 'yes' to either of these, it is most likely due to the television's processing capabilities. Because of the high amount of data that is required to deliver HD content, manufacturers have found creative (but not necessarily convenient) ways of dealing with the processing issues (blank screen delay for example). Since the audio and video signals for any given television station (either HD or regular) are transmitted separately, the television has to process that data internally so that you get the picture and sound aligned properly when you are watching it. HD broadcasts are much more demanding than regular stations requiring manufacturers to constantly improve this processing speed with every new model. On some televisions, the channel remains blank for a few seconds to allow the television to configure all of the information so it looks good when it's ready, which could explain the delay you are describing. At the time your television was manufactured, this may have been the best technology your manufacturer had to offer. On my personal flat panel, I get the picture and sound right away, but I have to wait about 15 seconds for the sound to catch up to the picture which I think is more annoying than being forced to look at a blank screen. But that's just me.
Hope this information was helpful.
Mar 19, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Permanent blue haze on screen; looks like
The fact that you continue to have sound while the picture disappears points to one of three potential issues.
Issue 1: the LCD Panel.
Issue 2: The Inverter Power Boards (though these tend to cause power/shutdown/no video at startup than video distortion)
Issue 3: the Time Control Board - a small board at the top of the LCD panel on the back that relays data to the rest of the screen.
Any one of these three repairs, you should call Sony if the unit is outside of manufacturer's warranty. They are expensive to perform, and the parts are not cheap. Hopefully you have an extended warranty to help with the issue.
Jan 24, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
How do i fix my missing profile page on Facebook.
Here's what Facebook says about the problem...
Profile Bugs
Content on my Facebook profile disappears and reappears.
Some users are currently experiencing issues on the site where content...
Some users are currently experiencing issues on the site where content appears and disappears for periods of time. For example, a Wall post may disappear and not return until logging in again and/or refreshing the page.
If you would like to submit a report, please click here.
http://www.facebook.com/help/?faq=16412
Jan 20, 2010 | Facebook Social Network
LARGE BLACK RECTANGLE BAR BLOCKING TV SHOWS -- WILL NOT GO AWAY
It sounds like the closed captioning background.
Press Menu on the remote
Press Up or Down, Ch + or C- to get to Closed Caption
Press right side button or Vol+ and Mode will be highlighted
Press right button or Vol+ until it says Off on the right hand side of the Menu
Press exit and that should do it.
Hope this helps.
Oct 17, 2008 | JVC AV-27D303 27" TV
Black menu-like box randomly appears, covering the picture
This is a problem with closed-captioning. What you are seeing is a closed captioning box with no captioning in it. Usually this is being accidentally transmitted by the cable company "head end". Just make sure your closed captioning function is completely turned off. if you are seeing it randomly, it may well be coming from your cable company. Is it just on certain channels?
Sep 05, 2008 | Toshiba 15DLV76 Television
Samsung HL-P4663W DLP TV
no make sure that your set is getting plenty of fresh air clean your filters and check to see if your color wheel is going out it is a small glass wheel with all the colors on it
Oct 22, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Intermittent loss of picture
You'll have to locate the vertical output IC which should be mounted onto a heatsink, then take out a good magnifier under the printed circuit board and examine the solder connections on the pins of that IC and resolder the ones that are cracked.
Mar 12, 2007 | Proscan PS27125 27" TV
Televison & Video Logo
60 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
