Question about Yamaha Televison & Video
Yamaha EMX 2200 Powered Mixer
I have distoration on both channels at any volume. The unit has worked perfect ever since I got back 10 years. I know it would be a big job to change all the output transistors but if you can offer anothe place to look it would be good.
Thanks,
Peter Coombs
e mail < coombs3@bigpond.com >
  • 24 Answers
SOURCE: yamaha emx 5000
Your powered mixer does but the model number doesn't match any Yamaha models. Double-check and look for the manual at Yamaha's website. It probably the 300 or the 512.
http://www.yamaha.co.jp/manual/english/search.php?div=pa
Posted on Dec 28, 2008
  • 211 Answers
SOURCE: Peavey CS-800 PA power amp 1 channel is out
Hi Bill,
It's a log time ago that I repaired those amps., but I give it a shot.
There's a speakerprotection after the finals, what I remember it's a triac (SAC187, or something like that).
You will find it at a small pcb at the back of the amp. Normally it has three legs but the centre is cut away. If it's down you will measure 0 Ohm at the output, also with a switched off amp.
Thats all I can remember, it was about 25 years ago.
Maybe it helps,
Gerard
Posted on Jan 30, 2009
  • 4234 Answers
SOURCE: No volume control with 2 faders on Mackie CR1604 mixer
If all other functions work for those channels, the most likely problem is the fader itself. These can fail and operate more like switches rather than faders. Without witnessing the behavior, I can not state that for sure. While these mixers are not the hardest to work on, they are time consuming. The faders can be purchased from Mackie directly. If you need to have this repaired, any shop that repairs audio gear should be able to erpair this for you. Where are you located?
Dan
Posted on Feb 12, 2009
  • 8 Answers
SOURCE: Connecting two powered mixers
Hi, If you have small electronics knowledge this might help you. First fine in each mixer the amplifiers line In if your mixer has two amplifiers then you have four line In. Disconnect this line from your mixer and build a circuit Line out multiflier. You can use op amp for this application this is a simple circuit. You made two input and four outputs. If you are interested i can send you a schematic diagram.
Posted on Aug 10, 2009
SOURCE: no output to speakers mackie 808s power mixer
I can hardly even tell what you're talking about because you don't use any punctuation.
Posted on Dec 17, 2009
How to hook up bose b1 module into yamaha emx 5000
The Bose B1 bass module is designed to handle up to 125 watts into 8 ohms 40-200 Hz.
The Yamaha EMX 5000 is full 500 watts, and full range. This is not a particularly good match.
EMX5000 Powered Mixers Mixers Live Sound Products Yamaha United States B1 Bass Module Bose L1 Encyclopedia FAQ Wiki
Apr 29, 2014 | Bose Audio Players & Recorders
Can I connect only one speaker to a yamaha emx 312 sc power mixer?
First it is certain that you would not want to plug both outputs of the stereo power amp into one speaker combining both channels into the same speaker. (see image from manual below - also link to manual)
Next I would be very concerned about only using the one side of the main amp out as it could cause an unbalanced load, or you could be driving the load into dead air connection and any of these conditions are destined to cause premature failure of the power amp.
Taking a quick scan of the manual for this unit, it appears what is pretty common to most powered mixers, hook up two matched speakers/loads to each chanel of the output.
Your best bet is to shed those monster cabs, there really is no need for them especially with this sized powered mixer, and get yourself a nice pair of full range cabs like EV1202;s, EV SX300's, or some nice 2 or 3 way 15" JBL's/
Just my opinon.
Link to Yamaha EMX 312 Owner's Manual:
Yamaha EMX Series Owners Manual
Dec 06, 2013 | Yamaha Music
Can i use powerd spekers with yamaha emx 88s
Yes. You can use powered speakers with this board
Feb 11, 2013 | Yamaha Emx88s Powered PA Mixer System
Monitors not audible with Behringer 1680S
Assuming you're trying to power the monitors from this unit as well as the mains.....Confirm that the amp switch is in the middle position which splits the internal amps....one for main and one for monitors. Output A would power the monitors.... B would power the mains.
Aug 26, 2012 | Behringer PMP1680S Europower 10-Channel...
How to listen thru headphones using a yamaha emx 88 mixer
Did sound for a southern gospel group, using a yorkville powered mixer. Not familiar with your mixer, but, on the Yorkville I had an unused 1/4" line level output with the monitor mix on it. I bought a cigar-sized, 3-channel headphone amplifier / splitter from Radio Shack, called a Boosteroo. Has 1/8" stereo plug that I adapted to the mono output, with a 1/8" stereo to 1/4" mono adaptor. It receives the line level (monitor in our case) signal and supports up to qty 3 - 1/8" plug headphones. Battery operated. No volume control, so I added an inline dial (rheostat) volume control cable. Can't pull up on Radio Shack, now, but, found it available, elsewhere, online. Worked great for me!
Good Luck SdDude
Feb 19, 2012 | Yamaha Emx88s Powered PA Mixer System
How do i connect lights to a yamaha emx 512
There is no way to hook up any form of lights to the Yamaha EMX512S. If you want to use DMX lights, you would need to buy a DMX controller. There are both analog and software controllers. Controller prices can range from $50 to over $500.
Aug 24, 2011 | Yamaha Emx88s Powered PA Mixer System
Aux1 and 2 are not working...what is the fix on the emx5016cf yamaha board
You are NOT trying to drive speakers from the aux outputs are you? These are LINE outputs that should be using TRS balanced lines to either powered speakers or amplifiers. Often these are used for monitors. The monitoors MUST be powered versions or use external amplifier if the speakers are passive..
Apr 26, 2011 | Yamaha Emx 5016cf 16 Ch 2x500w Powerd...
The speaker connected to my Yamaha EMX 312 SC is not bringing out any sound when we use the microphones but the displays on the power mix shows there is activity.
Assuming that you have checked the speaker leads for broken connections and that you know the speakers themselves work okay (test with a different amp) and that you can hear sound on the headphone socket
  1. Check that you actually have the power amp switch in the right position for the outputs (monitor jacks or main neutrik/speakon sockets) that you are using (see page 25 of the manual)
  2. That your speakers are connected to the speaker outlets on the rear panel and not the 'main outputs' on the front panel, which are for use with a separate power amplifier
  3. Check the mute button is not in
  4. You have turned both the master volume controls up.
If none of the above solves the problem it is likely that the overload protection fuses on the amplifier output stage have blown and need replacing - take to a repairer
You can find the user's manual here
http://www2.yamaha.co.jp/manual/pdf/pa/english/mixers/emx512sc_en_om_d0.pdf
Feb 10, 2011 | Yamaha Emx312sc 12 Channel Stereo Powered...
Yamaha emx 5000
Dec 20, 2008 | Audio Players & Recorders
Televison & Video Logo
479 people viewed this question
Top Yamaha Televison & Video Experts
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
