Question about Xerox DocuColor 40 PRO Laser Printer
Xerox docucolor pro 40 error code reading 6-220
The copier will not boot up and has an error code that reads 6-220
    President:
  • 1,462 Answers
Here are various solution for your issue
  • Remove and re-install the Imaging Unit (make sure that Imaging Unit is locked in place). Turn the printer off, then on.
  • Remove and re-install the Main Charge Grid. Turn the printer off, then on.
  • Remove and re-install the Transfer Kit. Turn the printer off, then on.
  • Remove and re-install each of the Toner Cartridges. Turn the printer off, then on.
  • Replace the Main Charge Grid. Turn the printer off, then on.
  • Replace the Imaging Unit (make sure that Imaging Unit is locked in place). Turn the printer off, then on.
  • Replace the Transfer Kit. Turn the printer off, then on.
  • Replace the Toner Cartridges. Turn the printer off, then on.
  • Please leave me comment, if you need futher assistance
    RNJ VINODKUMAR
    Posted on Oct 01, 2009
    Error code list
    Hi, you can find the error code list for the DocuColor 3535 in the Troubleshooting section of the manual. If you don't have a user manual, you can download a PDF version from Xerox here:
    http://download.support.xerox.com/pub/docs/DocuColor_3535/userdocs/any-os/en/3535_User_Guide.pdf
    Mar 08, 2010 | Xerox DocuColor 3535 Copier
    Xerox DocuColor 242 Fusor Error/ Paper Jam
    Those coded normally are related to something not being seated properly in the paper transport in the fuser area.
    Mar 02, 2010 | Xerox Office Equipment & Supplies
    How to clear error codes in dc 12
    we can clear from NVM read/write
    but if know exact solution go for that
    www.partsdrop.com/techinfo/enx_DC12info.pdf
    this like is use ful for some code
    Jan 15, 2010 | Xerox DocuColor 12 Printer
    Xerox docucolor 3535 - error 010-348
    Hi, you have to reset this code entering into diagnostic mode, If this fault is declared 3 times in succession, print and copy mode will be disabled. In order to clear this condition, reset NVM location 744-003 to 0. Saludos from mexico
    May 10, 2009 | Xerox DocuColor 3535 Copier
    Xerox docucolor system fault problem
    hi please chek and tell what error code showes in your display.. some error codes showing in ur display, pls check it that.
    Aug 25, 2008 | Xerox DocuColor 12 Printer
    XEROX DOCUCOLOR 12 - Booting
    if u getting this message in ur fiery just reinstal software... this only solution... and if u get this error in ur printer pls check error code in bottom of the display..
    Aug 21, 2008 | Xerox DocuColor 12 Printer
    Xerox dc 12 error 3-317
    The NVM can only be set with a laptop.
    Mar 15, 2008 | Xerox DocuColor 12 Color Copier
    Error code 14-376
    I have a problem with Error Code 3-380 in DC12 please help me.
    Feb 12, 2008 | Xerox DocuColor 12 Printer
    Error codes
    3-333 communications failure between the Foreign Interface
    and the machine.
    Press 0 and start button at same tame.
    Enter 6789 and select confirm. Select dc 131 NVM read/write.
    select input number an type:
    752-002 0 = Foreign Interface disabled 1 = Foreign Interface Enabled
    759-015 1 = Addition Device (Auditron) 2 = Subtraction Device (Debit card)
    if you want to see current value select "read"
    Oct 22, 2007 | Xerox DocuColor 12 Printer
    Xerox DocuColor 40 PRO Laser Printer Logo
    Top Xerox Office Equipment & Supplies Experts
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    CheckitRight
    CheckitRight
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
