Agitator not agitating whirlpool quiet care 11 about 9 yrs old
  • 1 more comment
  • Joe Onley Sr.
    Joe Onley Sr. May 11, 2010
    can you move the agitator by hand in both directions? if so, the 'dogs' inside are shot and need to be replaced. If not, (i.e., only moves one way, as it should) then it is probably the spin tube on the transmission and this is a more costly problem, and probably need a new machine.
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Could you please elaborate a bit more on your symptoms? For example: Does the washer fill or drain? Does the drive motor run? Are there any indications that the washer has power? Do you hear any strange noises when the washer attempts to agitate or spin?
  • J. KUYKENDALL
    J. KUYKENDALL May 11, 2010
    model # and will it spin and drain thanks
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
Please see the Whirlpool installation and maintenance PDF on their Top Load, Direct Drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If this is the type of washer that you have, I'd pull the cabinet and check the Motor Coupler.
Following is a description of how to do it.
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
If it isn't the coupler, and you want to go further, it is possible that the "Agitate Gear" in the transmission is damaged.
Here is a description of how to "pull" the transmission on top load washers.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Although getting into the transmission is somewhat messy (it holds about 14 oz. of oil) it can be done, and replacing the gear isn't too difficult.
Posted on Oct 01, 2009
Agitator not turning when washing Whirlpool ultimate II super quiet mod # LSQ9264HZO, everything else seems fine, spins rinses, drains, replaced timer disconnected lid switch wired together besides that no...
This is a common problem among Whirlpool washers. There are 4 dog leg shaped plastic cogs fitted inside your agitator and these are worn or broken there won't allow the top of the agitator to grip to the lower portion. therefore getting little or no agitation. the part number for the dogs are 80040 and come in a package of 4. if there is more damage done to the agitator dog support, you may need to replace the cam as well which is part number 285809. both are very low in cost and involves only taking the agitator , which can be done by taking the dispenser cap off and removing the 5/16 screw. after this you can take an old belt or similar rope type object, and remove the agitator. some agitator require a lot of force to remove but persistence is the key. Hope this helps.
Thanks
Oct 14, 2009 | Whirlpool Washing Machines
Agitator is weak
you need to remove the agitator, then pull the top half off, replace the dogs inside the cam, and re assemble it, you can find a kit online for a few dollars.
Feb 03, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
No spin or agitation on washing machine
check the coupler it is the plastic and rubber piece that is in between the motor and the transmission
Dec 30, 2008 | Whirlpool Washing Machines
WASHER WON'T SPIN OR AGITATE
Fisher and Paykel pride 5.5. It is about 11 yrs old
Oct 04, 2008 | Washing Machines
Replace agitator dogs, which should be available at your local appliance parts store for around $10. Replacement takes about 20 minutes (for a Whirlpool washer, at least.) Remove the center filter and you'll see a bolt (11 mm in the Whirlpool.) Remove the bolt, which you may be able to do with hand-turn socket wrench unless you have an extension for your ratchet. Removing the entire plastic agitator assembly is easy when tugging from below.
This next part may note be needed, but: Once you have the assembly out put it on the floor and stand on it. To remove the free moving part of the agitator, grab the fins and give it a good tug or two to free it from the lower assembly. It may take a bit of effort. Remove the inards, replace the four dogs, and reassemble.
It was *really* easy to do...and certainly a lot cheaper than having someone come out or, as we thought we were headed, to replace the washer.
For even better description: click here
Sep 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate care ll Quiet wash Model # LSQ9564SQ0
The ***** part of the agitator is supposed to ratchet in the clockwise direction. this is normal. If you can spin it in either direction (turned off) then you need a set of agitator dogs.
Jan 10, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
216 people viewed this question
Top Washing Machines Experts
