Question about Canon PIXMA iP1500 InkJet Photo Printer
Even after cleaning 3 times and deep cleaning my printer, the red colored-lines still have lines through them.
  • 39 Answers
My solution worked i took out the printer head, filled a syringe with warm water and "only" squirted the bottom holes were the ink comes out' i did several times. and be carefull not to touch the holes as it will damage easly..and if you get water on the terminals wipe it off with kitchen paper or toilet paper. i had the same problem it wouldant clean i went through lots of cartriges until i tried my solution and worked. its caused by ink clogging up.(blocking). hope this helps. jay.
Posted on Oct 01, 2009
I replaced all 3 color cartridge with origanal hp products, even after calibrations (3 times-full mode) only cyan and black are printing nicely. red and magenta colors are not printing.this is not driver...
This is a common problem with this model of printer. The scanner optic degenration is due to dust buildup on mirrors and lenses. Since the most vulnerable mirror reflects its laser beam to the magenta toner cartridge, red tones are the first to show fading. Colours shift: purples turn blue and oranges turn yellow. The printer optics will need to be cleaned by a technician to resolve this issue as it means dismantling your printer deep into the optics to fix the problem.
Jun 07, 2010 | HP LaserJet 3600n Printer
My printer is only printing half the line.. can you help
do a deep clean cycle from you computer, and see if that solves the problem. type up one or two lines and change the color to blue or red. those are different ink tanks. if it prints in those colors, then your black ink is out or needs a deep cleaning.
Feb 03, 2010 | Lexmark X4270 All-In-One InkJet Printer
Printed pages have blank lines in the print for the red, blue and yellow colors. Have tried cleaning and deep cleaning several times. No change.
If cartridge is good, prime and allign, remove cartridge and clean copper contacts with contact cleaner, if all fails replace printer.
Dec 17, 2009 | Canon MP610 Photo All-In-One Printer
MP780 printer doesn't show red color, I replaced a new Magenta color toner, but it didn't show any red color.
Go to printer maintenance and perform deep cleaning,do it for 3 times the if it doesn't clear the error, try to look for a chemical solution that can be use to unclogged printhead. Remove the printhead on the printer then soak it but don't dip the whole unit it might got wet the board of the printhead. You can also put some cleaning solution on your old cartridge without removing the printhead on the printer. You must put the solution of course on the magenta only. Let it there for 12 hours then perform a test.
Sep 23, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Black Ink won't print on my Cannon ip90 Printer
Here's the link to the transcript..
http://www.fixya.com/support/c36778-black_ink_print_cannon_ip90_printer
Please post your comments there if you are not able to reconnect to the session with me..
Mar 20, 2009 | Canon PIXMA iP90 Mobile Printer
New ink cartrage
Print Nozzle Check Pattern
  1. Press the Open button to open the output tray.
  2. Load letter-sized plain paper in the auto sheet feeder (ASF) or the cassette.
  3. Display the Maintenance screen on the printer.
  4. Press the up or down cursor to select [Nozzle check], then press the <OK>.
  5. Press the up or down cursor to select [Yes], then press <OK>. (The nozzle check pattern is printed.)
  6. Confirm the nozzle check pattern.
05sj00160_03a.gif 05sj00160_03b.gif < 1 > The normal nozzle check pattern
< 2 > The abnormal nozzle check pattern
< 3 > Some black ink lines are broken.
< 4 > White lines are present in the color ink pattern.
< 5 > Both black and color inks are not present.
Note:
  1. When all patterns are printed normally, press the up / down cursor button to select "All A" and press the OK button.
  2. When any patterns are printed abnormally, press the up / down cursor button to select "Also B" and press the OK button.
Print Head Cleaning:
  1. Display the Maintenance screen on the printer.
  2. Press the up or down cursor to select [Cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head cleaning.
    Note:
    Do not do any other operations until print head cleaning is completed.
  4. Print the nozzle check pattern and check the print head status.
Deep (Print Head) cleaning:
  1. Display the Maintenance screen.
  2. Press the up or down cursor to select [Deep cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head deep cleaning.
    Note:
    Do not do any other operations until print head deep cleaning is completed.
    Note:
    Ifthe printed result does not improve even after doing print head deepcleaning, turn off the printer. Then, after 24 hours or later, do printhead deep cleaning again. (After a given time interval, ink coulddissolve itself, resulting in ink unclogging.
Jan 08, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Jun 04, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
Many lines on photos despite numerous cleaning, deep cleaning
it could be a faulty printer head in the printer or purged unit not work correctly to clean the heads. you need to do a deep head clean then try printer head tested again. may need to do this a couple of time. still have problems get a new printer head for the printer.
Sep 25, 2007 | Canon PIXMA MP460 All-In-One InkJet...
Canon PIXMA iP1500 InkJet Photo Printer Logo
82 people viewed this question
old marine
old marine
