Question about Frigidaire Washing Machines
My frigidaire gallery series dryer is saying f3 on it what does this mean and how do i fix it?
  • 250 Answers
It sound as though the dryer is saying it has a problem with the temperature sensor. Depending on the model you may be able to easily replace or check the temperature sensor or it may be better to have a professional take care of this. You can order a new temp sensor for a few dollars, but the cable might have just jiggled loose from vibration.
Posted on Oct 01, 2009
Dryer gallery series e68
Good Morning Friend,
I understand you want to know how to replace the board on your Frigidaire dryer, model# GLEQ2152ES, due to receiving an E68 code. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your particular appliance, and should be able to replace the board with ease. Hope this is helpful.
-Best Regards-
WP
Jun 27, 2014 | Frigidaire Dryers
Makes a ticking or clicking noise when dryer is on. How can I fix it? The heat and tumbler still works though.
Hi Lisa, thank you for your post!
Based on the above-listed model number, FEX831CS it shows you have a Frigidaire laundry center. However, you mentioned that it is a gallery series. So do you have a laundry center or a Frigidaire gallery dryer? In order to better address the issue, what is your model number? You can typically locate the serial tag, which lists your model number, on the right or left edge on the inside of the door. How often do you hear the ticking or clicking noise? With this information I can better assist you. Thank you!
Dec 12, 2013 | Frigidaire FEX831CS Top Load Stacked...
My Frigidaire dryer (Gallery series) will not start. It makes a buzzing noise every time i pres the start button.
This is a indication that the motor had shorted out to ground and everytime you press the start button the start and run windings of the motor are grounding out. You'll need a new motor for this fix.
Dec 14, 2010 | Frigidaire Electric Dryer
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
F3 error on frigidaire built in oven, cant cook
F3 INDICATES A TEMPERATURE PROBE FAULT.CHECK RESISTANCE OF PROBE,SHOLD BE 1100 OHMS
Nov 09, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like the bearing is gone, call a repiar man or buy new as repairman 100 per call
Sep 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
How to unlock the frigidaire oven range door and remove error F3?
How do you adjust the oven door on a Fridgedaire Gallery Series gas stove?
Jul 13, 2009 | Frigidaire 30 in. Electric Gallery Series...
F7 error code- what does this mean?
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
Display Condition Remedy
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
May 17, 2009 | Frigidaire 30 in. Electric Gallery Series...
My Gallery series dryer shuts off.
Check your lint screen. If you do not get a complete "lint pattern" you probably have a clogged or partially clogged vent which will cause your dryer to overheat and prematurely shut off. Clean your vent and you'll return to normal operation. If you have a vertical vent (goes up through the roof) get a proffessional to clean it. Dryer vent issues are the #1 cause of house fires according to the U.S Department of Consumer Affairs. Over 16,000 per year.
Nov 24, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Dryer will not run
dryer starts sometimes if you hold in button. frigidaire gallery series model # GLEQ942CSO. serial # XD350164472. flat panel control board.
Mar 31, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Washing Machines Logo
19 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
