Question about Sony PlayStation Portable (PSP) Console
Unreadable my memory stick can't be read by my computer, everything is new but everytime i open my memory stick using my computer it's empty..
    Problem Solver:
  • 4 Answers
Check if these steps help
1) Reformat the memory card on your psp .
2) try a different memory card u could have one of the defective ones .
3) if u are using windows xp or vista goto services.msc
stop and restart upnp and removable storage services .
also make sure the recovery options for these services are set to restart the service on all failures .
4) restart your computer after these steps . This should help .
Posted on Dec 20, 2007
Miracle arm automatic gate opener
Recovering memory stick data can be tough, you can try recuva (http://www.piriform.com/recuva). This is a very good tool for recovering data, it includes a quick scan and a deep scan.
If the recovery works or you decide the data doesn't matter or you wish to use the card again, then to format it (this will delete EVERYTHING on the card) for normal use then the HP USB disk storage format tool is the best for this, I know it says USB, but it works for cards too: http://en.kioskea.net/download/download-127-hp-usb-disk-storage-format-tool
Be careful when using this tool, ensure you have the correct drive letter selected.
Nov 11, 2013 | Electronics - Others
My Nokia 5800 Xpressmusic's 8gb micro sd became unreadable.
The format's are NOT compatible, between Apple & Windows PC.
May 22, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Trying to put new hard drive.when it starts up it beeps 3 times and no picture on the monitor.is the power supply bad? originaly the hard drive crashed and the trying to reinstall it kept coming up error...
3 short beeps is a base 64K RAM failure
Remove added memory
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
  • Additional information about determining the type of memory to use in a memory upgrade can be found on document CH000910.
Open computer and reseat memory
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
Swap memory location
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
Try another computers memory
If you have access to another computer that uses the same type of memory try using its known good memory in your computer.
If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard and/or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced.
Replace memory
If you've determined or believe that the memory in y our computer is bad we suggest that you replace it.
  • Information about installing and adding new hardware including memory can be found on document CHADD.
Jan 31, 2010 | Gateway Computers & Internet
My won't recognize my Sandisk memory stick
may be ur computer is not able to read the stick, try it on another PC, some times the memory stick has some power left in it when removing from the camera and the same has to be discharged, to do this refit the stick to you camera and access the stick, then shut down the camera by power off button of the camera and then remove the stick from the camera and connect it to the PC.
Dec 07, 2009 | Electronics - Others
Dise unreadable
Most likely you will have to buy a new or used game because the xbox reads everything off the disc and if its scratch you will not be able to play the certain places that doesnt work or not play at all
Aug 19, 2009 | Microsoft Xbox 360 Console
Is there a way to transfer photos saved in internal memory to the memory card?
Try by removing the memory stick and then attaching the camera to computer with USB cable. Switch on camera. It should open up a dialogue box in Windows XP (or similar OS). Select 'open folder to view file' or open Windows Explorer and open camera folder (probably displayed as new drive E: or like that in My Computer) . You may also check whether there is an option of selecting "camera as mass storage device" in settings menu of camera. If yes then select this before connecting. If you have no means of attaching the camera to the computer, place an empty memory stick into the camera. In review mode, a message indicates there is no data, but there is in the internal memory. While still in review mode, press the menu button and go the the "Setup" section, the last option. Now, scroll down to the "Memory Stick Tool" section. From there, highlight the "Copy" choice at the bottom, and select the OK option to proceed. You will get a message: "All data in internal memory will be copied." Press OK, and it will copy everything in the internal memory to your memory stick. Then, when you have plugged the memory stick into your computer, you will find a new folder entitled Copy. All your photos from the internal memory of the camera will be in there.
Thanks.
Aug 07, 2009 | Fuji FinePix Z10fd Digital Camera
Did not boot and with 3 beep sound
Remove added memory
Replace memory
Aug 04, 2009 | Computers & Internet
My computer can't read pictures from memory stick pro duo
there or to picture folders on the psp one is in the root of the memory stick and the other you have to open the memory stick then open the folder called PSP
Aug 04, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Can you help me!! because my memory stick 8GB have been not read from my psp and computer i don't now it wast corrupt or not because when i was put into the memory card ready my computer have been log...
I recently had the same exact problem with a Kingston SD card of mine. Unfortunately, this usually means that the flash memory is no good any more. This means the data is totally unreadable on the drive now, and you will need to replace the drive.
The good news is that manufacturers tend to offer very long warranties on flash memory devices. I looked up on the Sony support site, and they offer a warranty of five to ten years, which you would fall into. I would call Sony support and start the replacement process. You won't get the files back, but at least you won't need to replace it.
Jul 29, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
My Nikon Coolpix 2100 Lexar starter memory card has become unreadable
It sounds like your Dazzle is not compatible with the sandisk. Maybe the Sandisk CF UltraII card have a new update software in it.
Artgirlny
Jun 13, 2008 | Nikon Coolpix 2100 Digital Camera
Sony PlayStation Portable (PSP) Console Logo
146 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
