Question about PfaFF Tiptronic 2030
Loose end cap cover.
The end cover (that the tension wheel sticks through) is loose and falls off when the machine is in use. How can I fix this?
    Scholar:
  • 41 Answers
This actually applies to most of the newer Pfaff machine models:
  1. If the cover will come completely off, look at the inside of it to make sure the bracket that holds it in place is not broken. If it's not broken...
  2. Grab a flashlight
  3. Remove the stitch lid - there are little silver clips at the base of the lid on either side - push the lid either to the left or right against these clips and you'll be able to pop it right off. You will reverse procedure to put it back on. Removing the lid isn't absolutely necessary but does make it easier to see/access screw.
  4. Raise the handle of the machine
  5. Aim your flashlight into the machine behind the left side of the handle... you should be able to see down inside the machine to the set-screw that holds the side cover in place
  6. Check to see what kind of screwdriver you need - either a Phillips head or a Torx Driver. Most of the newer Pfaff models require a Torx Driver (this is a star-shaped screw-driver available at most hardware stores - Size T25 should fit this particular screw)
  7. Slide cover back into place - may need to wiggle it a bit to get the bracket under the screw
  8. Tighten screw & you should be back in business
If the bracket on the inside of the cover is broken, this part will need to be replaced. Pfaff parts are only available through an authorized Pfaff dealer so your local dealer will need to order it for you.
Hope this helps - please don't hesitate to respond if you need further help or clarification.
Happy sewing,
Kim & Linnette
Posted on Jun 13, 2008
When I finish to sew the end of string does not lacks it self and when you pull the bottom of the string everything opens
If the upper thread is looping on the bottom of the fabric as you sew, the upper tension is too loose. It could be threaded incorrectly, the upper thread may not be seated in the tension disk properly (be sure to RAISE the presser foot BEFORE threading the upper thread), or the upper thread tension is set too loose.
If you have checked everything and it is still looping underneath, the bobbin tension may be too loose or the bobbincase needs replacement.
Sewing Machine Thread Bunching Up Here Why
Oh You Crafty Gal Sewing Lesson 10 How to Fix Tension on Your Sewing...
Understanding Thread Tension Threads
Dec 20, 2015 | Janome Sewing Machines
How do I fix the bottom bobbin thread
THE BOTTOM AND TOP THREADS ARE IN A TUG OF WAR. WHEN THE TOP IS TOO LOOSE THE BOBBIN WILL BE PULLING HARDER THAN THE TOP THREAD SO A GREAT DEAL MORE THREAD WILL END UP ON THE BOTTOM. TO CORRECT THIS YOU INCREASE THE TOP THREAD TENSION. IF THE TOP THREAD IS PULLING HARDER THAN THE BOTTOM THEN A GREAT DEAL MORE BOBBIN THREAD WILL END UP ON THE TOP. TO CORRECT THIS YOU WOULD LOWER THE TENSION ON TOP.
Dec 12, 2014 | Sewing Machines
Top zigzag is fine, bottom is loose
sounds as if it has insufficient top tension, clean between discs then re thread with presser foot down
Feb 17, 2014 | Singer 4423 Sewing Machine
Need to put bobin in a merritt 4530
Flip the presser switch up to raise the presser foot. Turn the hand wheel counterclockwise until the needle is in its highest position.
  • 2Hold the hand wheel in place with your left hand while turning the hand wheel knob counterclockwise with your right hand to loosen the hand wheel knob.
  • 3Place the desired spool of thread on the spool pin so that the pin fits all the way through the hole in the center of the spool. Put the spool holder onto the end of the spool pin that is sticking through the spool of thread and press firmly to ensure that the spool holder keeps the spool in place.
  • 4Grasp the end of the thread and hold it taut between the thumb and index fingers of both hands. Snap the taut section of thread into the thread guide post located to the left of the spool pin.
  • 5Pull the end of the thread gently. Wrap the thread around the bobbin winder tension disk near the left front on top of the machine, starting at the side of the tension disk facing you and wrapping around in a clockwise direction.
  • 6Poke the end of the thread through the small hole in the bobbin from the inside out so that the loose end of the thread sticks through the top of the bobbin. Put the bobbin on the spindle, or bobbin winder, and gently slide the bobbin winder to the right.
  • 7Hold the loose end of the thread in place while pressing down on the foot pedal to start the machine. Hold the foot pedal down until the bobbin is as full as desired. The machine will automatically stop once the bobbin has reached capacity.
  • 8Cut the loose end of the thread using scissors. Slide the bobbin winder to the left and remove the bobbin. Hold the hand wheel in your left hand and tighten the hand wheel knob with your right hand by turning it clockwise
  • Apr 05, 2012 | Singer 6510 Sewing Machine
    Tension on reverse side of fabric is too loose-
    Set the tension back to the recommended setting (in manual). This is usually around 4.
    Always thread the machine with the presser foot up as this allows the thread to properly "seat" into the tension control.
    Mar 23, 2010 | Brother XL-5130 Mechanical Sewing Machine
    I have a 7570 and cannot get the tension the bottom thread is loose and can be pulled right thru I checked the top and adjusted the bottom and nothing seems to change.
    When you thread your bobbin in the bobbin case, hold it only by the thread. If the bobbin and bobbin case fall, the tension is too loose. If this is the case, turn the bobbin tension screw 1/4 turn until the bobbin and bobbin case do not fall when only holding by the thread. The top tension should be set between 4 and 5. The best way to see which one needs to be adjusted is to do a zigzag. If the thread is pulling more on top and your top tension is set between 4 and 5, the bobbin tension is too loose. If your top tension is set between 4 and 5 and it's pulling on the bottom, the bottom is too tight.
    Feb 17, 2010 | PfaFF Creative 7570
    My machine
    Step 1. Set the upper tension tighter by turning the dial slightly to the right, or looser by turning the dial slightly to the left. (Or by using the electronic control if the sewing machine has one.) This adjusts the tightness of the main thread.
    Step 2. Set the lower tension slightly tighter or looser using the dial or electronic control. This adjusts the tightness of the bobbin thread.
    Step 3. Cut a small scrap of fabric, preferably the same type you want to sew with.
    Step 4. Sew a few test stitches on the scrap. Examine the stitches to see if they’re too tight or too loose. The stitches should lie flat against the fabric, without pulling the fabric or making loops that stick out.
    Step 5. Repeat Step 1 to Step 4 again as needed.
    Good Luck!!
    Thanks
    Jul 09, 2009 | Juki Sewing Machines
    Removing front cover
    if you very carefully lift the decorative plate at the bottom left corner you'll find hidden screw took me a while to find it cause mine
    Jan 28, 2009 | Euro-Pro 416 Mechanical Sewing Machine
    Boobin tension is to loose
    that means your top tension is incorrect, be sure to make sure your machine is threaded correctly and that your tension assembly is working correctly,,,,,,easy fix!
    Jan 22, 2008 | Brother LS-2125 Mechanical Sewing Machine
    Sewing Machines Logo
    297 people viewed this question
    Top PfaFF Sewing Machines Experts
    Tally Girl
    Tally Girl
    Douglas Plant
    Douglas Plant
    Irene Tulloch
    Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
