Question about Garden
What size line do I need for a Ryobi ELT1000FA Trimmer
  • saltsea210 May 11, 2010
    doesn't it have a gauge id on the spool that came with it ?? would be a decimal numerical ID Hope this Helps Steve
  • 279 Answers
The line guage should be on the spool. It would show as a decimal: .65, .080. .095...etc...Look closely..Lee
Posted on Oct 01, 2009
  • 148 Answers
A good Rule-of-Thumb for homeowner trimmers is:
Curved shaft trimmers need to run .065-.080 diameter line while straight shaft trimmers can handle .095-.115 diameter.
Keep in mind the kind of use the machine gets and match line diameter accordingly. Larger line may fit into the spool, but the power and RPM that's available to you will suffer because of the extra weight and wind resistance.
Hope this helps!
How to install string for ryobi 50 volt string trimmer
Line Trimmer Line Replacement of a Ryobi One+ 2013 ...
? 2:33
www.youtube.com/watch?v=8jEER8lHUQk
Feb 22, 2013 - Uploaded by TheLegoCityBoys How to replace line in a garden Line Trimmer. ... Ryobi 40-VoltLithium-Ion Cordless String Trimmer RY40210 - Real World Review & How To ...
Aug 08, 2015 | Ryobi Garden
What size line does a ryobi CS30m gas trimmer use
The Ryobu CS30 model calls for only .080" line. Other models use larger line and electric models use smaller line.
Oct 03, 2010 | Ryobi Garden
I need to know how the fuel lines are hooked up in my ryobi gas trimmer. All of the fuel lines rotted out. I took them out and I need to know the correct connection sequences (what goes where).
line runs from little filter in tank to carb.
line from carb. to primer bulb
line from primre bulb back to gas tank.
lines are 2 sizes
need to cut at angle end of lines in tank so you can get them thru holes
and grab with needle nose plyers and pull them thru.
make sure you put the little filter on end before you pull line thru and leave
enough so filter can move around the whole tank.
second line in tank is smaller and need to cut and pull it thru hole in tank to primer bulb
Jun 23, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a Ryobi BC 30 trimmer. It runs fine but
Are you using the proper size line? Check the ends of the spool. It will give you the size you need. Also while you are checking, locate the arrow that shows the direction to wind the line. Hope this is of some help...Lee
Oct 05, 2009 | Garden
Replacing fuel lines on ryobi 767r trimmer
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Jul 03, 2009 | Ryobi Garden
Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
May 27, 2009 | Ryobi 15" Electric Factory Reconditioned...
Which reel for trimming
Your instruction supplied with your trimmer gives you the information you need. It will recommend which size string to use. Both reels should use the same string.
Nov 30, 2008 | Ryobi Garden
Ryobi 2 cycle gas trimmer 705r/725r
The gas nipple that come out I have...whats goes in the other hole?
Aug 28, 2008 | Ryobi Garden
Garden Logo
74 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
