Question about Whirlpool Duet GHW9150P Front Load Washer
Gurgling sound from Whirlpool Duet washer when not in use
I have a 6 1/2 year old Whirlpool Duet washer. There is a constant gurgling sound (like wather bubbling up) coming from it when it's not in use. I turn off the water supply after each use, and there are no visible leaks. The machine is working fine otherwise. What could be causing this noise, and should I be concerned? How can I make it stop?
  • 5,911 Answers
Check your drain line. You may have a siphoning condition. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
If you have the water source turned off, the only other way water gets into the washer is through the drainage system. If you do not have the proper air gap or placement on the drain line, it can create a vacuum and allow water to siphon back into the washer.
NOTE: Some residual water in the drain line is normal.
If you have any questions, please let me know. I hope this helps you.
Posted on Oct 01, 2009
  • Jeff Rockwell
    Jeff Rockwell Oct 01, 2009
    This does not rule out the possibility that you could have a problem with your plumbing. If your drain hose appears to be okay, listen to the water as it drains in the standpipe. If you hear the water backing up in the pipe, you may need to have a plumber check the line for obstructions.
My Electrolux VC model code ZUA3830PT 2100W(max),makes a gurgling sound though the suction is still excellent, any thoughts? Any ideas?
sounds like something is stuck in the unit . use some kind of wire to see if you can fish anything out .
Nov 22, 2015 | Electrolux Vacuums
Very loud noises
Check the rubber mounts under the compressor and look for any lines touching the sides of the cabinet. The gurgling and clunking are often normal. good luck. Roger
Jan 19, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
Glowworm boiler making noises
You're probably getting what some call gurgling sounds because there is air in the system. You need to bleed the air out at all bleed ports starting with the lowest in the system and ending with the highest.It won't hurt if you do that process a couple of times. Once all the air is out, you should have a normal convection flow of water through the system. - Good luck!
Jan 30, 2013 | Bosch Water Heaters
Washer smells even after cleaning cycle
It sounds like an air vent is either missing or clogged. That gurgling usually indicates some sy phoning action going on which is drawing water out of a gas trap. Hence you are getting sewer smell into the washer.
Thank you !!
Jun 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Continual gurgling sound coming from the well
the pump may be cavitating. caviation often sounds something like rocks going through a pump. this can be caused by the suction line or strainer of the pump is plugged. if continues to run the pump will have unrepairable damage to the casing and will the to be replaced.
Apr 03, 2010 | Jet Plumbing
Toilet wont flush completely. it may take 4 times or more to flush solids. i at first thought this was related to heavy rains we had been receiving in the area over a period of about 4 months. 2 days...
there is no air release. the vent must be clogged somewhere. you can take a hose up there and see if it drains all the way or floods over. since the tub drain has a trap and the toilet itself is a trap, there has to bee a good amount of air pressure coming up without a release. i would say an obstruction. possibly at the junction of the main and the vent.
Nov 09, 2009 | Eljer 091-2190-43 Platinum Patriot...
Whirlpool fridge incessant buzzing
The knocking noise when cuts off , is a compressor internal motor support spring , broken . This does not mean the compressor is bad , only noisy for the rest of the compressor life , but should be covered under the 5 yr warranty . The gurgling sound is the refrigerant being pumped thru the system . The buzzing could be from the compressor also . My suggestion , would be to call a factory warranty company , to see if they can replace the compressor under warranty .
Sep 07, 2009 | Refrigerators
I was told the bearing is shot on the Whirlpool Duet Washer and it is not worth repairing, the machine is only 6 year old, any advice?
a 6 year old washer should not be scrapped unless it is made in china, replacing a 5$ bearing is worth fixing. even if you need to buy a drum unit.
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fridge losing coldness
Defrost problem. Either defrost heater, defrost thermostat, or defrost timer is bad.
Sep 05, 2017 | Frigidaire GLRT184RA Top Freezer...
Bosch dishwasher
is all the water draining from the tub? if not the pressure switch will not reset and it will continue to try and clear it self...check drainage system.
2. pressure switch is jammed on..build up in the sensing chamber..common..or switch faulty...rarely
3. if water is in the bottom panel most have a flood switch which automatically operates the pump in case its over filling
Dec 04, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Whirlpool Duet GHW9150P Front Load Washer Logo
210 people viewed this question
Dan Webster
Dan Webster
Sal De
