Question about Bob Mackie SR1530 System
My mackie 1530 powers up. No sound comes through. Sometimes if I crank the volume on the mixing board all the way it will come on.
I have a Mackie 406M Powered Mixer. can't get sound out of it anymore. all the input level set lights stays on. any suggestions
That sounds like the amp board died. Mackie parts can be hard to source, and Mackie is really slow to ship, so I suggest taking it to a Mackie authorized service center. Here's a link-
Contact Support Mackie
May 18, 2016 | Mackie Music
My mackie srm 150 has power but no sound
If there's no sound at all then there's a problems with speaker-soundboard connection.
Mar 03, 2015 | Mackie SRM150 Compact Active PA Spkr ea
The Mackie SRM150 Monitor
The problem could be a defective linear regulator component on the preamp/mixer board. Checkout the link for repair instructions. https://lieven.kks36.be/2017/12/14/mackie-srm150-repair
Jul 30, 2017 | Mackie SRM150 Compact Active PA Spkr ea
Mackie srm150 volume cuts out intermittently
Jun 08, 2013 | Mackie SRM150 5.25" Compact Powered PA...
Mackie sub swa 1501 no LED no output but light on board appears to be on
los transistores de salida estan en corto 2sa1943 y 2sc5200 reviisa los drivers tip 122 y los irf
Feb 18, 2012 | Mackie SWA1501 Subwoofer
Hi, Model: Mackie 1604 VLZ PRO When using the control room monitoring, even if the corresponding "SOURCE" switch of the subgroup/main mix is disengaged, there is still small volume of sound. This is...
You may be getting a small amount of cross-talk. How high are the gain settings and sliders when this occurs? Also, can you describe the overall setup that you are using? I'll check the prints, but you should not be getting any volume unless the gains are maxed.
Dan
Oct 15, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Copystar 1530 copier Power Source PCB defective
Hello sir; You have to make sure this board got problem (reminder; did you check the fuse) after you bought the board that's non refundable, if you still need that call me at 9735336778 Everett Lin.
Jun 03, 2009 | Copystar CS-1530 Copier
Hooking up powerd monitors to a Mackie 1604 VLZ3
Are you sending the main mix to the monitors or are you giving them their own mix? What about using the sub groups, use 1 for your monitor send.
Apr 04, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
No sound
Willing to bet you've blown the amp, or fused the coil. I've had it happen twice, apparently when running off a power source that apparently couldn't handle the load. Hope it's under warranty - if so Loud Technologies (deals with all Mackies warranty stuff) should be able to replace the unit. Otherwise, you'll need to take it in to a service department and have it checked out.
Good luck, you'll have to arm wrestle with them to get them to replace it.
Jun 12, 2008 | Mackie SWA1801 Subwoofer
Bob Mackie SR1530 System Logo
346 people viewed this question
Top Bob Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bob Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
