Question about KEF Audio PSW 2150 Speaker
KEF PSW2150 buzzing or clipping
I have e-mailed KEP Tech Support and am not optimistic for a happy answer. It sounds like amp clipping or some kind of issue inside the amp, but I cannot get it to stop. It was intermittent at first but is now constant. It happens with and without the sub cable connected and changing the levels and settings on the back panel does not change or diminish the buzzing. I have tried powering off and will next venture inside the back panel although I am not qualified for electrical repair beyond fuse replacement or other simple troubleshooting.
Im having the same problem, did you find a solution to the constant buzzing? Please email me at guns17@cox.net, Thank You
Posted on Jul 26, 2010
Actually there are several causes for this problem. The two mains 12000uf cap need to be checked, there should be about 52v+ and 52v- on the supply rails. Another area to look at is the is the 47uf capacitor c52, this is the reference on PSW2000, which is basically the same. Change these components to 105 degree types. The problem is common due to the unit being on constantly. A better idea would to connect the mains lead to the aux power out on the main system amplifier.
Posted on Jan 12, 2010
    Novelist:
  • 133 Answers
One of the things that may cause such buzzing is a fault at the filter electrolytic capacitor (could be the main one or one of them), it may behave that way if it has a partially or totally desoldered contact pin, if the pin is broken (torn away from the cap) or if the contact of at least one of the two pins has been broken somewhere inside the capacitor.
This may often happen if the capacitors are not glued to the curcuit board which means their body will vibrate when the sub is playing at a level loud enough to shake the internal components - the vibrations may cause a soldered pin to loosen the solder around it or even the pin itself to be broken or torn away from the capacitor.
regards
Triarcuate
Posted on Oct 01, 2009
My kef subwoofer keeps making loud buzzing noise
Either you need new high quality cables,or your amp has output filter capacitor problems.
Aug 25, 2014 | KEF Audio Audio Players & Recorders
The amp on my kef sub woofer amp is making a consent buzzing noise it sounds like a kettle boiling. Help
Ok so no guarantees this will work, but it did for me and I knows it's very late but hopefully it will help someone else with a similar problem.
I had the same problem and as clmrt5000 said a very long time ago there could be an issue with a ground loop, although this is likely to give a high pitched buzzing sound.
This can easily be fixed by adding a switch to disconnect the mains earth from the back plate, or you can just unscrew the earth and tape it up, this fixed my ground loop, (some models already have a ground lift switch)
As for the "boiling" sound I also got a saw tooth wave sound (like a strange squeak or beep that changed frequency) this is caused by faulty components, and thanks to Frank Johnson (http://lug.demon.co.uk/kefrepair/?p=60) who suggested that you can simply and easily replace 3 capacitors on the main amplifier board (c58 - 47uF 63v or 100v) + (c52 & c53 - 220uF 25v) but stand them away from the board on the length of the capacitor leads to prevent them from absorbing heat from surrounding hot components (with heat shrink tubing to prevent shorting)
Now my sub works as good as new, apparently these 3 capacitors can cause all kinds of problems it's a common fault, so if you are handy with a soldering iron, or know someone who is you could save yourself a lot of money by repairing you faulty KEF sub.
p.s. if you have ANY of the KEF PSW subwoofers they all have similar issues, you can find a guide to fixing them at the link above, Frank is a brilliant and very helpful man.
Jan 07, 2011 | KEF Audio PSW 1000 Subwoofer
KEF Audio KIT100 System - I have similar buzzing/clicking.
if you have still the problem, I got the solution from Kef USA. It is somewhat involved in taking the unit apart and replacing a resistor and capacitor. With the instructions supplied any electronic technician or TV repair man can do it in less then 1 hour. email me and I forward the instruction in PDF: Xxel_g@mail.coX . Replace the first X with a and last X with m in my email address.
Jun 21, 2010 | KEF Audio KIT100 System
I have a Kef PSW 2500 that emits a loud buzz when on. I pulled the amp, but I'm not sure if its the speaker or amp. What should I be looking for the speaker outputs from the AMP? How can I tell if its a...
Have just repaired a similar problem with a KEF 2500 - relay was chattering at 50 Hz rate, buzz in speaker output.
Problem was caused by overheated / dried out Electrolytic filter cap (C52 - 47uF 63V) on the relay coil supply feed.
The overheating is caused by adjacent power supply dropping resistors which run very hot due poor design of power supply.
A service manual for a similar model is available at following link, refer to power supply section:-
http://www.eserviceinfo.com/downloadsm/35375/kef_psw2000.html
To replace,
1) remove chassis from speaker cabinet (8 screws), disconnect red/black speaker wires from main PCB spade connectors.
2) Remove 4 screws attaching main pcb heatsink assembly from face panel - lift assembly from faceplate (a bit messy , much heartsink compound between mounting faces)
3) unplug the AC 3 pin connections adjacent to the large capacitors and the 3pin connector on end of pcb (near C52), then roll assembly over the top of the audio sub-board to access underside of pcb.
4) solder connections to C52 is accessible at edge of board without further dis-assembly.
Take extreme care replacing C52, as the circuit board is of poor quality, (usual domestic electronics quality) being single sided copper without plated through holes.
The board is already heat damaged by heat buildup from power supply resistors, so the track will most likely lift and crack when disturbed- to counter this problem link the +ve capacitor pigtail to an adjacent solder pad on the same track.
Assembly is reverse of above, take care to preserve/ensure minimum disturbance of heatsink compound.
Nov 29, 2009 | KEF Audio PSW 2500 Subwoofer
Loud buzzing from Kef PSW1000 Subwoofer
yes. A good idea. Kill power to the sub, then unplug and remove everything from the sub. go ahead and plug it in again and check for buzzzz.
That is test one. if you have buzz still, its the sub assembly. bad luck, but not impossible. If the buzz is gone its one of the signals to the sub. They can produce a buzzz without any signal coming from your stereo equipment. Replace the feed line, enjoy! BTW...Kef sure does sound clean. good choice.
Nov 09, 2009 | KEF Audio PSW 1000 Subwoofer
Kef Kit100 subwoofer buzzing
You have a bad set of Audio output IC's for the sub. There is two of them. TDA7293 REPLACE BOTH!!!
There is 4 on one side of board,and 2 on other "also 1 small one" The the two are for the sub,the other 4 are for the main speakers/surround. They sell on Ebay for $6-10 each or a kit of all 6 for $25.
Jan 18, 2009 | KEF Audio KIT100 System
KEF KIT 100 Sub woofer continuously buzzing
send me a request to my email address axel_g@mail.com and I send you a fix, Axel
Aug 03, 2008 | KEF Audio KIT100 System
Kef kit 100 subwoofer buzzing
if you have still the problem, I got the solution from Kef USA. It is somewhat involved in taking the unit apart and replacing a resistor and capacitor. With the instructions supplied any electronic techician or TV repair man can do it in less then 1 hour. email me and I forward the instruction in PDF: Xxel_g@mail.coX . Replace the first X with a and last X with m in my email address.
Jul 13, 2007 | KEF Audio KIT100 System
Open Questions:
See all KEF Audio PSW 2150 Speaker Questions
KEF Audio PSW 2150 Speaker Logo
1,367 people viewed this question
Top KEF Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Vernon Taylor
Are you a KEF Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
