Question about Western Digital 500GB My Book World Edition 500 GB Hard Drive
Back-up hard drive no free space eror
Hi
I have a Seagate 80GB external hard drive for back. It had been working fine. I had to update unattended back-up and reset through the bounce back centre.
I deleted the old back-up files on the external hard drive to start of fresh.
Created new back-up
Now when the back scans, it comes up with an error saying the is not enough space, yet they is easily the capacity.
Should I reset the drive somehow?
Cheers
Paul
  • 1 more comment
  • sarthish Jul 17, 2008
    I have a 250 GB passport and I tried loading 5 gigs of movies onto the drive, it...the drive says not enough space, how do I fix it??
  • Anonymous Dec 22, 2008
    I have a 500 GB hard drive and want to export a 10 GB .avi I to it be I get a Not enough space to continue error, when I'm only using 23% of the memory available.
  • alex_woods88 Feb 24, 2009
    I'm trying to copy a 4gb avi file on to my 500gb hard drive. I've only used 64 gb so theres clearly enough room but I keep gettin a message saying there is not enough room and i should delete some files.
  • 383 Answers
SU error messages Error SU0335 Setup could not determine your hardware settings. There may be a missing or damaged Setup file or there may not be enough memory to continue.
Windows Setup requires 15728640 bytes available on your C: drive ... This error is generated when Windows detects the hard disk drive, but the hard disk drive is not formatted and/or does not have enough available space to ...
Basic software troubleshooting. If your computer does not have enough disk drive space or does not meet the ... of disk space during the installation, this would cause an error during the
Computer questions and answers listing 300 - 399 CH000325, Out of environment space. CH000326, Not enough drive letters ... CH000381, A serious disk error occurred trying to read/write drive
Good Luck / Just read and follow instructions.
Good Luck.Please dont for get to Vote/Thank you.
Posted on Dec 20, 2007
Seagate Freeagent external Hard drive won't increase free space when files are deleted?
How are you deleting the files? If you're simply moving them to the trashcan/recycle bin then they're still taking space on your drive. Try emptying the trashcan/recycle bin.
Mar 21, 2013 | Seagate FreeAgent Computers & Internet
External Hard Drive not Accessible after Windows Vista Update
Assuming that the external hdd is physically working fine, everything is pointing to a damaged boot sector.
You can get back most (if not all) your data stored in your external drive with the help of an application called: Pc Inspector File recovery.
Its a freeware.
Here is the link: http://pcinspector.de/Sites/file_recovery/download.htm?language=1#
Simply install it on your C:\ drive, and follow the prompts.
Please let us know the outcome.
Don't forget to rate this answer if it helps
Dec 12, 2009 | Maxtor Hard Drive
Problem
Hi Ryan,
I decided that retrieving my data was more important that the seagate warranty and i was not prepared to send the free agent overseas with the data still on it so i removed the hard drive from the freeagent case (case now stuffed) and put the hard drive in an "off the self" hard drive enclosure". All my data was there. It is still working fine. Two big lessons for me - moving files from my lap top to the external drive is not back up and external hard drives can be fragile, best not move them around like a library book. From my low tech view the circuit board on the freeagents is flawed.
Regards,
TMV NZ
Jan 10, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
279GB free space in a Seagate 320GB will not take a 5GB pst file
First of all HI :)
The main problem you have is that the file system of your hard drive is FAT32 not NTFS. You need to change it to NTFS in order to work. Here is how.
>> Copy all your data (the 50+GB you used) on to another hard drive
>> Now from My Computer
>> RIGHT CLICK
>> CHOOSE FORMAT
>> CHOOSE NTFS FILING SYSTEM
>> instead of FAT32 and
>> give your hard drive a nice full FORMAT
This will take a while and WARNING you will LOSE all your DATA so DOUBLE CHECK BEFORE YOU START THAT YOU COPIED EVERYTHING.
Hope that this Fixya Helps you :)
Best Regards
(please take some time to rate solution thanks)
Jan 07, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Data Storage
Make sure you are storing them in both places. I have a hunch that even though you are storing them in the my documents folder it is the one on the external drive that is storing them & when you are trying to delete the computer is reading them as stored to the external & is deleting from there. Hope this helps & please remember to rate my answer. Thanks.
Dec 31, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Partision prblem
This is because an 80GB hard drive only has 75GB inside it will not be exact because of the way hard drive manufacturers compute the size. 80GB by name but only 75GB in real hard drive space. much like a if you have a flash drive or a portable uSB you will notice this also.
Dec 27, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate 250G running out of space
creat incremental backup rather than complete fresh backup.
empty trash can.
either way, it's possible the backup drive uses up more than working drive especially adding/deleting files alot between backup's.
Dec 26, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Formated my external seagate hard drive
Put in another pc ur hdd and format it and put back on ur pc...If u have another pc with same  motherboard and with same chipset it will work fine but if u dont have same motherboard it's not big problem after u have formated in another pc but it back on ur pc and if u see bluescreen just repair ( reinstall and it will work fine )
Oct 25, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How do i free up space on my start up disk?
your problem is the space is it?i think on top of moving your itune library u should move all other less important files to any external storage and see whether this will solve the problem.
Sep 05, 2006 | Smartdisk - Peripherals - HARD DRIVE,...
Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
557 people viewed this question
Top Western Digital Computers & Internet Experts
Alun Cox
Marvin
Marvin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
