Question about Philips HTS3450 System
Picture but no sound...
I have a similar problem as some other people here.  I read the part about replacing the 6.3 amp fuse but can you tell where it is?  Is it in the back panel??
Are there any diagrams available to help with locating the fuse?
I'm tempted to go right in and just hope for the best.  Are there any other fuse that I could confuse it with?
  • 1 more comment
  • reddress Dec 29, 2007
    I have just set it up and I have no sound at all. The green power light is on the woofer but absolutely nothing else happens. This fuse business... where does one get a fuse like that? Has anyone ever successfully done this?
  • reddress Dec 30, 2007
    Sorry, can you provide a more specific answer please (especially if you think I will have problems disconnecting the wiring to fully open up the back to access the fuse)
  • onthevergi Dec 31, 2007
    One year old system and speaker began making a buzzing sound then the whole sound went off. We have unhooked and rehooked all to no success. Funny this is all happening the same time...some conspiracy?
  • 263 Answers
Just follow the power cord to the back if no fuses near there on the out side that is insude same way follow the power cord and thats right there
Posted on Dec 29, 2007
Power light is lit, but there is no sound coming from the speakers , it was working fine and just stopped working ?
Its an PA amplifier and i think this is build with an integrated powerpack IC output stage,
There are different TOA amps but if this model look first the fuses if that are (important)measured defect give a new fuse a try if it blows again there is something wrong in the cables or a speaker conection or filter , ut if the fuses are good there could be an single great brown or black colored IC with STK (....)A or B or something similar is to read on it on the great heatsink inside the amplifier that could be having 15 or more legs must be replaced , BUT also some capacitors thats belong to the output stage because every defect is having a cause.
It think this amplifier IC should similar be looking like this
Aug 05, 2016 | TOA Electronics - P-924MK2 - 240 Watt...
What must i do for tail lights and dash to work on F150 2006
You should check and / or replace the 15 amp mini-fuse. It is in location #6 on the fuse panel under the instrument panel. 15 amp mini fuses are blue in color. Usually, but not always, you can tell if a mini fuse is burnt out by removing it and looking through the clear plastic to see if the fusible link is intact or open (burnt).
If it is labled, it may read "Parklamps, BSM, Instrument panel illumination"
Below is an image map of the fuse panel for a 2006 F-150.
e203adf8-5a39-450d-9174-344d711f50e1.jpg 1b35e398-ef12-4b80-b105-ea7bc461f159.jpg 4b6d29f1-53eb-455a-8c59-a9f766410061.jpg
May 01, 2014 | 2006 Ford F-150
P25 Koolatron fuse ahs to be replaced. Can't read AMP on old one. What AMP do I need to replace it? Nothing on thi son Kollatron's website, incredible!
If fuse blows, it normally means there is a fault. To briefly recap, compressor is about 2 amps, fans x2 is approx. 1 amp. and light/other 1amp. Possibly a 5 to 6 amp fuse. If it trips again, have the compressor or fans checked.
Aug 05, 2010 | Koolatron (2526435) Beverage Cooler
When i turn on my line 6 spider 3 amp it keeps blowing the fuse
MOST likely the power amp chip is blown. They use a TDA2050 chip that is in a seven lead power tab package similar to the TO220 transistor package. Readily available from for just under $3.
If you keep replacing the fuse, you may damage other components.
The other possibilty is a diode and/or filter capacitor has shorted.
Jul 17, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
Hi my hitachi 61sdx01b red power light is working but i have no picture or sound?
CK fuse F903 if it blows it again then replace STRM6511 CK all of the pico fuses 5and 6 amps they look like resistors they willbe green or yellow they are fuses.
Dec 21, 2009 | Hitachi 61SDX01B 61" Rear Projection...
No sound and current read 0 amps reads 0 it is installed correctly it was workin before then quit the volt indicater started blinkin now the light is constant but no sound the volts reads 12.1
Check the fuse on the unit first, if fuse is good and you have power to the am you may have fried it. This is common when the speaker load is not adhered to prperly. Make sure your speakers are connected properly (2/4/6/8 ohms) and not exceeding the limits of the amp, this fries them 99% of this time.
Sep 04, 2009 | Kenwood KAC-X541 Car Audio Amplifier
Six (6) blinks on the Timer/Standby led
6 blinks means lamp thermal fuse blowing, replace thermal fuse.
See here
Aug 30, 2008 | Sony KP-57WS500 57" Rear Projection...
57h82 no video
Your set has pico and micro fuses soldered in ( various locations) depending on what circuit B+ supply is being "watched"...the amperage can vary from 2 to 5 or more...
Went all white, then no pix suggests you lost the 200volt
source B+ that goes to the RGB pcboards = one on end of each CRT.......Some websites offer SM's = search your Model # then service manual.........HTH>...........T.
Jun 29, 2008 | Toshiba 57H82 57" Rear Projection...
32'' Panasonic TV, 4 yrs old, keeps blowing the fuse
Hi Mendi.
I had a similar problem, in that I could not find the proper fuse for my set. I bought a bit higher amp fuse from Radio Shack and it ended up blowing a couple months later. I've since pulled the TV down and replaced it with an LCD set, so I've solved my problem.
But, to address yours, I don't think the amp difference would not be the problem. Likely, there is a power issue on your set causing it to draw more amps and become out of specification. Using a higher amp fuse would buy you more 'capacity', but if its blowing those too (repeatedly), its likely a real problem in the set. I'm not a TV technician, so I can't tell you why. I'd suggest taking the thing in for service (cheaper than the house call) or if that is too expensive, looking at putting your money into a set that won't give you those problems. Or, just keep replacing the fuse until it doesn't fix the problem.
Sorry I cant help much more.
May 13, 2008 | Panasonic CT-36SL13 32" TV
Blew the fuse in the cigarette adapter
I got replacement fuses at Radio Shack.
Dec 05, 2007 | Lowrance Iway 500c GPS Receiver
Philips HTS3450 System Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
