Question about Oster Microwave Ovens
Dont get hot - Oster Microwave Ovens
  • Oster Master
  • 8,404 Answers
Check the door safety interlock micro switches.
Let me know what you find.
a
Posted on Oct 01, 2009
Microwave venting
Is it a combo built into the oven or stand alone?
If its build into something then no.
If its free standing look under the microwave and see if there are air vents in it. If there are are they clean. Microwaves dont vent persay, they just blow hot air out. You dont want to modifity the case because it will expose you to direct and scatter Microwaves. And that is not good.
A easy fix. When you are done making a TV dinner or whatever, keep the door open for a while. The microwave is hot and it will evaporate.
If there is standing water in it, contact the company and get them to fix it, but checking for proper intake and venting is needed. Meaning make sure they are clean.
Nov 05, 2013 | Oster Microwave Ovens
MICROWAVE OVEN "DAEWOO" MODEL KQG-868G PROBLEM :
There should be 3 'fuses' inside a microwave. The 'line' or monitor fuse, the magnetron fuse or TCO (thermal cut out) and the cavity temp fuse. I'm trusting that you have verified that the outlet is 'hot' first. Be careful !!
Nov 03, 2013 | Microwave Ovens
I HAVE A MICROWAVE MODEL EMERSON MW8999SB IS NOT HOT
I unplugged mine and let it sit for a few mins then plugged it back in and it works again....Yeah Me!!!!!!!!
Jun 08, 2012 | Emerson Microwave Ovens
Where is the high voltage fuse on a microwave
The thermal fuse monitors the magnetron temperature and cuts power, if it gets to hot and resets in no more than 20 to 30 minutes. Unplug microwave oven, remove top, "several screws" look over to the right, thermal fuse is mounted on top on the inner chassis, "round and thick with 2 wires clipped on"
Apr 16, 2012 | Jenn-Air JMC8127DD Microwave Oven
I have a Kitchenaid built-in microwave mod: kcms1555rss-2 . When you close the door it hums and gets hot on the inside. Open the door and it stops. It got hot enough to smell when I walked in the house...
call kitchenaid and let them know it stays on and heats i belive this unit has a new board to stop this issue. It isa safty isssue they should repair it free..dont forget to rate me Thanks
Jun 07, 2011 | Microwave Ovens
I bake a lot of cakes and just recently they are cooking too fast on the outside and not enough on the inside.the fan is still going round and the oven is hot.it has been perfect for a long time i just...
There are two shelfs in oven keep the cake in the top part of the oven and keep the consistency of the cake normal and do u use milk in ur cake if u dont then use 1/4 cup milk .
If this still dosent solve ur problem then contact me again thank u (^ _ ^)
Apr 29, 2011 | Microwave Ovens
Heat won't work on ge spacesaver microwave oven --what to do from
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ioi
Dec 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Inside of microwave hot to the touch
is it newer?
also i am wondering why you are touching the inside of your microwave ? (not being funny)
If it is something that is causing water to boil and steam when flicked/dropped on the inside you might have a concern, but you have to look at the wattage of newer microwaves as it progresses so will the heat generated inside.
i can say if you dont feel safe having it in your home then sell it or take it back but as long as it is not catching fire then i would say it is within normal operating perimeters.
Jun 01, 2009 | GE Microwave Ovens
Microwave don't work
You didnt mention if the oven worked or not. Its not blowing the fuse?? Ok it could be as simple as the Diode or capacitor but dont try to touch the capacitor terminals as it holds a nice charge.. Turn on the oven for a bit with a cup of water inside and let it run for a few minutes. If you start to see smoke pull the plug right away!!!!! If you dont let the water boil(about 2 to 3 minutes thyen unplug and carefully fell around for a HOT part, But dont touch any electrical connections! If theres something drawing to much current it will get hot. Ive had bad capacitors bad and causes the transformer to get too hot. as well as bad magnatrons cause the transformer to get to hot. I would recomend that you take this unit in to be diagnoised as there are alot of voltage in this oven as I ststed before and it is dangerous for a handyperson to be fiddling with it. Good Luck
May 30, 2006 | Sunbeam SBM1000 Microwave Oven
Microwave Ovens Logo
35 people viewed this question
Top Oster Microwave Ovens Experts
William Miller
William Miller
Lawrence Oravetz
J.D. Browning
J.D. Browning
Are you an Oster Microwave Oven Expert? Answer questions, earn points and help others
