SOURCE: Simpson Evolution 904 wall oven cooks very unevenly
I agree, the heating is very uneven in our oven, however, when I calibrated the temperature with a thermocouple, I discovered that the temperature gauge was 25C too hot! That is, if I set the oven temperature gauge to 155C, it was actually 180C inside the oven! Taking this in to account, it is now much easier to cook things without them burning.
SOURCE: how do you change light
The glass cover definitely unscrews anti-clockwise, but mine was
impossible to start moving by hand. I used a pair of adjustable pliers
and while the glass cover is made out of pretty thick glass, I didn't
want to be squeezing it so I set the pliers jaws to exactly the same
width as the glass cover. Because the glass cover has 4 bumps set around
it, the pliers jammed on them so I was able to unscrew it.
BTW, the globe under the cover is also a screw mount job - if you're
looking for a replacement, keep in mind that it has to be a max of 25W.
SOURCE: Simpson Evolution 906 Oven light. how to replace it?
I have just replaced mine & had the same problem. I couldnt remove the cover. I found that I just couldnt grip the cover well enough. I got some rubber washing up gloves & used them to grip the cover. It was still tight but it un skrewd quite easy this way.
