Question about E-Machines emachines (emachinees) CD-ROM Drive
EMac won't boot. Grey Screen with Grey Apple/busy clock
EMac won't boot. Grey Screen with Grey Apple and little clock-like icon moving around and around and around forever. Tried to boot from external CD Drive using "Tech Tools" Disc: Disc spun up but no boot. Using OX 10.3.8 I believe.
  • Stephen Quinn Oct 02, 2009
    Thank you for your help so far. I did as instructed. I see no caps under the hatch just micro PCB stuff, although I did discover a battery! Is this the fabled "PRAM Battery" ? Would it be a good next step to replace it? This Mac is like 9 years old so could this Batt cause such havoc?
    Thanks,
    Stephen
    Today I replaced the Battery I found inside. No Change. I know my internal CD rom drive is bad (has been for years). What I don't know is should I be able to boot from an EXTERNAL drive with a Boot disc?
    Guru:
  • 830 Answers
It sounds like your hard drive is going out. Most discs that come with Apple machines are machine specific, which means just any Apple disc wouldn't install on the eMac. Try and burn a free linux disk, I suggest Ubuntu, and see if it will boot with this. If the same thing happens, then you will need to replace the hard drive.
Posted on Oct 03, 2009
  • 10,865 Answers
Based upon your symptoms I believe the hard drive and the battery both need to be replaced.
Posted on Oct 02, 2009
  • 3,866 Answers
Okay
I am wondering if this emac is 1.25 GHz-1.75ghz if so please unplug it turn it over take a phillips screw driver undo the hatch there take a peek at the two left and right capacitors if there swollen on the top you going to need to have these replaced..
Other then that this thing shoot boot if this is not the case..
I currently have a Mac that did this and freezing episodes I replaced the capacitors and its been working ever sense. Good luck..
Posted on Oct 01, 2009
Reset password admin
I could suggest you search for this under "Apple password reset" since I've written the solution several times in the last month, but for you, I'll do it again:
You need to find Disk 1 of the operating system install disk set. The install disk set doesn't need to be the one that came with the computer, so long as it is OS 10.2 to OS 10.5 (PPC). However, some install disks are not compatible with the resolution setting of the graphics chip in some eMacs, so you may have difficulty reading the display.
The reset procedure is as follows: Turn on the eMac, open the optical (CD or DVD) drive and place Disk 1 in it, then close the drive. Restart the eMac. As soon as the startup chime sounds, immediately hold down the option key and continue to hold it until a disk icon appears on the screen. Wait until the optical disk icon also shows up. Click on the optical disk icon, then click the arrow button. This will boot up the computer to the install disk.
When the computer boots up to the install program, DO NOT DO ANYTHING IN THE INSTALL PROGRAM. Look in the Apple menu for the Reset password... item. You should see a selector menu for the account(s) on the computer. Select the administrator account and enter the new password (it can be left blank if you know nobody else will ever mess with your computer). Confirm the password, then quit and restart without holding down any keys.
The computer should restart normally and you can log in to the administrator account with the new password. So long as you remember the new password, you can change it at any time using the "Accounts" pane in System Preferences.
Jun 26, 2013 | Apple eMac Desktop
I have an emac G$ 700Mhz 128MB/40GB/Combo with two related problems: 1. On power up, I get a blank grey screen that, after a while, changes to a similar screen, except that at its center is a small...
I've never used a hair pin-- a straightened paperclip has always worked for me.
One alternate solution (if you have another computer available) would be to boot the eMac into target disk mode by holding T during startup. It should show a firewire icon on the screen, and should act like an external hard drive when you connect it to another computer via a firewire cable. You can use this method to install the OS onto the eMac from another Mac. You can try Googling "Target Disk Mode" if you need more information.
Nov 13, 2010 | Apple eMac G4 Desktop
EMac screen stays as grey screen whith swrling grey pinwheel-wont boot beyond that point?
Your best bet is to reset the System Management Controller;
http://support.apple.com/kb/ht3964
...and then reset the Parameter RAM:
http://support.apple.com/kb/ht1379
If it persists after that, try Safe Mode:
http://support.apple.com/kb/ht1455
...if that persists, try booting to your install DVD and running Disk Utility:
http://support.apple.com/kb/ts1417
..also note in this article that if for some reason you are unable to boot into your Install DVD the instructions for using fsck will do the same thing.
If that fails to resolve the issue, you'll want to reinstall the system:
http://support.apple.com/kb/ht1710.
If none of these steps resolve the issue, it will likely need repair at an Apple Authorized Service Provider or Apple Store.
Aug 27, 2010 | Apple Computers & Internet
I turn on computer apple sign comes on and a
I have no experiense with apple/mac products, but you may be able to boot up into safe mode and do some system repair.
There is a guide here http://support.apple.com/kb/ht1455
Jul 11, 2010 | Apple eMac G4 Desktop
Won't boot up past the grey screen with apple icon
can you get it into safe mode? are you holding the C key down?
Mar 01, 2010 | Apple MacBook Power Inverter Car Adapter
My Emac will boot up but it will not light up.What can I do?
Look closely at the screen, can you still see the icons in the background?
If you can and it seems extremely dark. then your problem is likely an lcd inverter board. This isn't a terribly expensive part but getting it replaced might not be cheap labor wise. An lcd inverter is what powers the backlight for the screen.
Oct 22, 2009 | Apple eMac G4 M9425LL/A Desktop
Emac g4 1.25GHZ 256 wont read hard drive or cd drive
I take it you just get a grey screen and spining wheel when you try to start up
Aug 12, 2009 | Apple eMac G4 Desktop
EMac G4 won't boot-up after increasing memroy
All RAM chips are not equal, you may have to use a specific manufacturer. Put your old RAM chip in and see if it boots. If it does, then you need compatible RAM chips
Jun 03, 2009 | Apple eMac G4 M9425LL/A Desktop
Emac stalls on the OS X start-up
Start here...   Resolve startup issues and perform disk maintenance with Disk Utility and fsck  Mac OS X: How to start up in single-user or verbose mode  If that doesn't help, try booting into Safe Mode and see what happens, if it comes up hopefully another restart may solve, if not, you can at least use this as a starting point to try and resolve. Safe Mode will allow you to get around, surf, etc...   What is Safe Boot, Safe Mode?   Mac OS X: Starting up in Safe Mode
If Safe Mode comes up alright, I would install AppleJack, excellent troubleshooting article can be found here... Troubleshooting Tools: AppleJack  Another excellent free tool for performing maintenance is Onyx (be sure to download the right version for your system). Install the package, then run it, it will check your drive and the structure, after this, click on the automation tab and check on everything for Maintenance, Clear Cache, Cleaning, and check on Reset -> LaunchServices database and Mail's Envelope Index. When it completes, restart. Repeat any time something seems flaky, if not try to run at least once a month.
Feb 01, 2009 | Apple eMac G4 Desktop
APPLE MAC
How many beeps? DOES the white light flash? Whats the specific model?
Oct 29, 2007 | Apple eMac G4 Desktop
Computers & Internet Logo
47 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
