Question about Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
Lawn mower ran over cable, where can I go to get it fixed ?
  • 8,404 Answers
Go to the hardware store ... get one each male and female plug (three wire). Put the appropriate plug on each end of the cut. Bingo. it is fixed.
I hope this helps you
a
Posted on Oct 01, 2009
I was mowing my grass and ran over a pipe and now my lawn mower leaves oil from the bottom help what can I do?
I would up-end it and see where the oil is coming from. Once you do that, you can decide how to fix whatever is now broken or bent.
May 27, 2015 | Garden
Has anybody rebuilt the gearbox on the Solaris SP21HB? Is it difficult?
I would take it apart at least ther maybe some key ways that broke. That would be a cheap fix most lawn mowers have them
Oct 13, 2014 | Nike Solaris SP21HB 21Inch 24 Volt...
Bosch electric lawn mower wont start, how do I fix it?
cable damaged ...renew cable . ..if does not work try condenser.
Jul 01, 2014 | Electric Lawn Mower
How to fix Mower cord stuck after hitting rock?
Pull the plug. MAKE SURE THE PLUG IS COMPLETLY REMOVED AND SEPARATED FROM THE MOWER!! Remove the cover with the pull start attached. see if you can turn it by the flywheel or the blade. If you can, you can just have the rewind repaired.
If not, then you have a probable bent or twisted crankshaft. Most likely not worth repair.
May 16, 2014 | Electric Lawn Mower
Lost the clutch when i ran inti a stump, nothing appears to be loose or dissconnected
Sounds like the belt has broken or came off the clutch pulley going to the drive pulley. Go to www.m&dmower.com and put your model # of the mower in the parts diagram lookup and it will show a break down on the mower so you can fix it
Sep 08, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Ran over somthing with lawn mower now it wont
You're right to check the flywheel key - are you certain it's ok? Also our instinct is to tip the machine over to clear the obstruction, which can send oil to places it shouldn't be! Does the machine have compression? It's possible to break the con-rod if you hit something really solid. You can check the piston's still moving by taking out the spark plug and inserting something like a cable tie in the plug hole. As you turn the engine over you should be able to detect the piston moving up and down. The jolt could also have dislodged coke in the engine that could foul the spark plug. Try fitting a new one. Come back to me if none of these solutions work..
Sep 09, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner Logo
188 people viewed this question
Top Smartpool Pool & Spa Experts
Robert Plante
Thomas Perkins
Thomas Perkins
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
