Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
We have a coldspot 106.56676501.Manufactured 01/06. The ice maker stopped working. We do not have a manual for it. Any advise to solve problem? Thank you
  • 190 Answers
SOURCE: kenmore coldspot top freezer auto ice maker, water
Dear customer,
               We suggest u to perform the following checks to solve ur problem...
  1. Check the refrigerator for level
  2. Check the ice maker for level
  3. Inspect the fill cup alignment
  4. Inspect the water supply line
  5. Test the water inlet switch
  6. Test the water inlet valve
  7. Check the shutoff arm
  8. Test the shutoff switch
thank you..
Posted on Apr 08, 2009
  • 93 Answers
SOURCE: We have a Kenmore Coldspot
It is probably your defrost cycle causing this. Obviously if you shut the water line off then it is not coming from there so there is only 1 other place it could be. Every 8, 10, or 12 hours depending on you defrost timer the refrigerator will defrost itself.......the frost melts into water and drains into a pan under the fridge. If the drain is plugged then it will just run into the refrigerator. If you have a freezer on top model then just remove the back wall inside the freezer, it will be a few 1/4 inch screws....If you have an icemaker then remove that too, it will be held on with 3 screws. Just look behind that wall and you will probably see ice at the bottom.....defrost the ice and pour a cup or 2 of water into the drain to make sure it is unclogged. If it is still plugged up then you have to find the clog....either in the back of the fridge behind the lower cover or in the refrig compartment near the back of the roof.
Posted on Sep 12, 2009
  • 1214 Answers
SOURCE: have kenmore coldspot model # 106 manufactured
Need the complete model number for this unit, but I am going to guess that you have a defrost problem with the freezer, more than a drain issue.
Posted on Dec 17, 2009
cj2176
  • 520 Answers
SOURCE: Kenmore Coldspot Ice Maker Modle #106 56622500 I
these have to be in correctly to lock back in and allow the unit to function. Try removing the bin again and be sure there isn't any small pieces of ice trapped anywhere. Also make sure there aren't any broken pieces from the bin. Hope this helps. Good luck.
Posted on Aug 18, 2010
imufo2
  • 3773 Answers
SOURCE: Kenmore Coldspot/ Acceler-Ice, the ice
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Posted on Jul 30, 2011
Ice maker not working properly it stop working. how can i get this ice maker back working again.
I suggest you look at where the water comes into the ice tray - there probably is a small black tube. Check the tube to see if it is "frozen" - with ice. I've taken a blow dryer to the ice maker to melt all the frozen lines.
Dec 26, 2012 | Kenmore Coldspot Freezer Knob Part 532015...
I have a Kenmore Model 106-55602400 Coldspot and the icemaker stopped working. What do I do?
The control module has failed on the ice maker. You can replace the control module alone, but I would replace the ice maker completely.
Here is a link for the control module.
Here is a link for the new ice maker.
Oct 15, 2012 | Kenmore Refrigerators
Kenmore coldspot ice maker
What is your model number? Here is a link to the complete service manual for Whirlpool/Kenmore ice makers. You may need to create an account to access the service manual.
Sep 02, 2012 | 3M Refrigerators
Kenmore coldspot model 106 9445781 the icemaker motor makes loud noise. Sounds like its under a heavy load.
Suggest you take the ice maker out and defrost it. You propably have ice crystal buildup and causing it to labor harder.
Jan 16, 2012 | Kenmore Side by Side Refrigerator
Aug 18, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The ice maker has stopped working, the motor is co...
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
May 20, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker not working wont cycyle if manualy filled model#59597990 coldspot
You need a new ice maker. We have parts and supplies for all brands of appliances and will be happy to make sure that you get the right part for your Coldspot. Just call us or email us and we will get it out to you right away! We hope this answers your question and solves your appliance repair issue!
Sep 09, 2009 | Refrigerators
Kenmore coldspot top freezer auto ice maker, water
Dear customer,
thank you..
Apr 08, 2009 | Kenmore Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
88 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
