Question about Microwave Ovens
Jenn-Air slide-in range Mod:JES8850BCS Key pad will not work.Two numbers appear on the display at power up. EE214 and M214 Are these numbers error codes,or whats the trouble?
  • gmashford888 Oct 01, 2009
    I have already install a new control board, do you think maybe the key pad? there is no sign of damage to the pad.
  • 3,037 Answers
I've seen this happen many times, you will need a new electronic control board for this unit.
You can order a new one from the following website link
http://www.appliancepartspros.com/part_details.aspx?part_id=4369444
Let me know how this works out.
Benjamin
Posted on Oct 01, 2009
  • Benjamin Patri
    Benjamin Patri Oct 01, 2009
    Well, if a new control board didn't fix it, then yes, the keypad would be the problem though it should be the control board usually.
Clock display keeps resetting to "0"
1. Defective controller or its power supply.
2. Broken display panel.
3. Oven needs to be reset (pull plug for a minute or two to reset).
God bless you
Jun 14, 2013 | Jenn-Air JMV8186AA Microwave Oven
I purchased a house w/ a Jenn-air elect. drop-in range. The Model # is 87946 or 87847. I believe the range was originally purchased in 1975. I am in need of an instruction manual .
Neither of these are a typical Jenn-Air model number. http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US suggests that the model number is on the back wall under the burner on the right side of a drop-in cooktop. For a range the model number is often on the frame inside the oven door, below the vent or on the back of the top of the range.
87946 or 87847 are the part numbers for the cartridges (the elements or the surrounding housing).
Look at the model number locations at the "Help me find my model number" link and try to locate a model number on your range. Then enter that model into the search box. The manual is probably available with the correct part number. Most Jenn-air electric cooktops start with JEC in their model number.
I hope this helps you locate the manual.
(I did try JEC87847 just in case you left off the leading alphabetical characters.)
May 08, 2011 | Jenn-Air Microwave Ovens
I have Model #JER8750AAB Serial#16776012WK When uising the self cleaning feature, oven stopped and F1 displayed on stove ??
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Dec 19, 2010 | Jenn-Air Microwave Ovens
Jenn Air Microwave builtin oven has no display and will not turn on. Had the power to the oven checked and it's ok. The oven stop working when it was on. The oven is 17 years old.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You should check the internal fuse as well as the oven cavity thermostat / thermal cutout and the magnetron's thermostat / thermal cutout.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Aug 23, 2010 | Jenn-Air JMC7000 Microwave Oven
Display says "Locked" and clock is on. Key pad wi...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Otherwise, you may have a shorted membrane keypad.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more free information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 19, 2010 | Jenn-Air JMC8130DD Microwave Oven
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Sharp 930-cs starts fine after 10 or 20 seconds it stops heating, stops spinning & Error message on the display. I replaced the turntable motor but problem continues.
When the Absolute Humidity (AH) sensor is defective (open or short), ERROR will appear in the display after 16 seconds.
If ERROR appears check sensor wire connections and/or AH sensor.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and the Sharp part numbers, most of which interchange except cosmetic parts.
Most computers will open this document automatically, but you may need the free Adobe Reader
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Jun 04, 2009 | Jenn-Air JMC7000 Microwave Oven
Jenn-air microwave keypad, only some of the numbers work. but occasionally they do work what can I do?
you say it occasionally works only some off the numbers, unplug from the wall. & open the microwave up & go to the pad & if you have wd40? spray the circuit board you can use a 1" new paint brush. and give it about 5mins to work reconnect the microwave & plug in,
Apr 23, 2009 | Jenn-Air JMV8208A Microwave Oven
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
Jenn Air Microwave Error Code
Hello Hec1152,
I have found the manufacturer contact information for you, but could not find information about the error code. If everything works fine, but the microwave is not heating your food, then the problem is most likely the magnatron or one of it's components, which sadly to say is the most expensive part to replace. Please feel free to contact the manufacturer via phone or live chat to get more details as to what the error code means.
If you would not mind, could you please rate my help. I would greatly appreciate it.
Nov 29, 2008 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
107 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
