Question about ASUS M2N68-AM SE2 Motherboard
I bought this motherboard: ASUS M2N68-AM SE2 Motherboard CPU Bundle - AMD Athlon X2 7550 2.50GHz OEM Processor, Geforce7025/nForce 630a, mATX Motherboard back on June 30, 2009 from www.tigerdirect.com. Now this motherboard constantly powers off and back on. I have an Nvidia 9400 GT PCI -Express video card, 530 watt power supply, DVD-Burner, 4 GB of RAM, and a AC powered USB hub with a mouse and keyboard connected to it. I have no idea what is causing this problem. I ran memory tests and all of them passed. It currently has the BIOS 0701. My hard drive and DVD-Burner are connected through SATA.
  • 657 Answers
I guess this is happening because of the CPU getting heated, Kindly check if the CPU heatsink and the fan is seated properly. Also check if there is any power issue, try to connect the system to another wall socket
Posted on Oct 01, 2009
I want to know the graphic card slot in the motherboard ASUS M2N68-AM-SE2. Whether it supports DRR1, DDR2 OR DDR3.
Hi, you can see the list here:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM/#specifications
At this site you also find drivers.
Remember to select your operating system
AMD Socket AM2+ / AM2 Processors
for AMD Phenom™ FX / Phenom / Athlon™ / Sempron™
AMD Cool 'n' Quiet™ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
Support 45nm Phenom™ II CPU Chipset NVIDIA Geforce 7025/nForce 630a
System Bus 2000/1600 MT/s Memory 2 x240-pin DIMM, Max. 4 GB, DDR2 1066/800/667/533 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*DDR2 1066 is supported by AM2+ CPU only Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
Storage Southbridge
4 xSATA 3 Gb/s ports Support RAID 0,1,5,10,JBOD
ATAPI support ,AHCI mode
LAN RTL8211CL Phy Gigabit LAN Audio ALC662 High Definition Audio 6 -Channel CODEC
USB 10 USB 2.0 ports (4 on back I/O, 6 on board)
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCI-E x16 Graphic card slot.
Aug 25, 2011 | ASUS M2N68-AM SE2 Motherboard
Id like to buy a msi nf725gtm-p31 mobo but am unsure if it supports am2 processors and ddr2 can u pls advice thanks
Here are the specs of the motherboard, both answers to your questions are "Yes". Happy purchase and have fun with it !
CPU
• Support socket AM2 for AMD® Athlon 64/Athlon 64X2 CPU / AM2+ for AMD® Phenom CPU / AM3 for AMD® Phenom II / Athlon II CPU . (95W only)
Please refer to CPU Support for compatible CPU; the above description is for reference only.
bult_ar_org.gifHyper Transport Bus
• HyperTransport 1.0 supporting speed up to 1000MT/s
bult_ar_org.gifChipset
NVIDIA® nForce 630a & GeForce 7025 chipset
bult_ar_org.gifMain Memory
• Supports Dual Channel DDR2 667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 8GB.
bult_ar_org.gifSlots
• One PCI Express 1.0 x16 slot.
• One PCI Express 1.0 x1 slot.
• Two PCI slots (support 3.3v/5v PCI bus interface).
bult_ar_org.gifOn-Board IDE
• One IDE port by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
bult_ar_org.gifOn-Board SATA
• Two SATA II ports by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports storage and data transfers at up to 3Gb/s
bult_ar_org.gifRAID Function
- SATA II 1~2 supports RAID 0, 1 mode by NVIDIA® nForce 630a & GeForce 7025 chipset
May 12, 2011 | Computers & Internet
Hi.I have a ASUS M2N68-AM SE2 Motherboard with AMD Athlon 64 X2 6000+ Processor.Whenever I boot,it says that the CPU is not supported.I have updated my BIOS to the latest version.Still doesn't help...The...
What bios are you using? Usually that error message can be disregarded since you can manually set the CPU clock, voltage, etc in the bios and it should work. Also, this might mean that the bios currently loaded is corrupted/broke. But since you did update the bios, to what version?
Also, are you using the integrated graphics for gaming? If so, that would not suffice for heavy gaming at high resolution. You should be using a dedicated video card for that.
As for system performance, how slow is it? What is your OS as well? can you try to download cpuid, and see if your processor is detected properly in windows.
Apr 27, 2011 | ASUS M2N68-AM SE2 Motherboard
M2N68-AM PLUS does not support cpu AMD Phenom 9750
No it does not. although it says it supports sockets AM2, AM2+, and AM3 and the Phenom 9750 is an AM2+, the Phenom 9750 has a wattage requirement of 125 watts. This motherboard ONLY supports CPU's up to 95watts! You would either need to get another motherboard or another CPU (or both and make a second computer).
Side note: also keep in mind that if using this motherboard with an AM2+ CPU, it will not be able to handle 1066MHZ memory (or higher) in dual channel mode, in order to get this speed you will either have to take out the second dimm or run both dimms at 800MHZ.
Hope this helps!! (and if it does, please rate or leave comment. It will be much appreciated!!)
Feb 12, 2011 | ASUS M2N68AM PLUS Motherboard AMD Athlon...
I need the drivers for amd sempron motherboard M2N68-AM SE2. could anyone share me the download link plz. thanks in advance.
I have found them for you
go to asus.com
http://support.asus.com/download/download.aspx?SLanguage=en-us
this will have the complete chipset, I have checked and your model still has updates including the bios
Nov 15, 2010 | ASUS M2N68AM SE2 MicroATX Motherboard AMD...
No beep, no display in new asus m2n68-am se2 motherboard
Try booting the system with a bootable and well memory stick and probably check the power switch if it send any signal to the board while pressing it.
May 07, 2010 | ASUS M2N68-AM SE2 MicroATX Motherboard &...
Asus M2N68 says CPU is not supported but works ok
if the voteage do not match the qvl watt for watt you can damage board or cpu
Mar 31, 2010 | ASUS M2N68-AM SE2 Motherboard
I just bought a asus M2N68-AM SE2 mob and a amd athlon 64x2 6000 processor and it comes up this model does not suport this cpu. others have same problem. I just want to no what cpu will work. what are...
Supports: AM2+ Quad-Core CPU/AM2 CPU and 45nm Phenom? II CPU Here is the complete list; your CPU is not listed. http://usa.asus.com/product.aspx?P_ID=2UWzsrOiRbMPGYpw
Oct 16, 2009 | ASUS M2N68-AM SE2 Motherboard
Which graphics card ican use in ASUS M2N68-AM SE2 mother bord amd athlon 64 5200+
unfortunately, this board does not appear to have slots for upgrading its graphic card.
Model Brand ASUS Model M2N68-AM SE2 Supported CPU CPU Socket Type AM2+/AM2 CPU Type Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2 Chipsets North Bridge NV Geforce 7025 / nForce 630a chipset Memory Number of Memory Slots 2×240pin Memory Standard DDR2 1066 Maximum Memory Supported 4GB Storage Devices SATA 3Gb/s 2 SATA RAID 0/1/JBOD Onboard Audio Audio Chipset Realtek ALC662 Audio Channels 6 Channels Onboard LAN LAN Chipset RTL8201CP Max LAN Speed 10/100Mbps
You are stuck with the integrated card.
Jun 28, 2009 | Computers & Internet
ASUS M2N68-AM SE2 Motherboard Logo
273 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
