Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
Helicopter starting :)
We moved into a flat which uses the Saniflo Saniplus. The motor started to go on for a longer period of time after flushing or using the bath. It wasn't so loud and long before. Also when we take a shower it starts normally but stops after some time and then the water stays in the bathtub. It starts after cca 15mins again.
Could there be some problems with the motor? Do we need a professional service or can we solve this problem our-selves?
  • 3 Answers
Could be the thermal trip on the motor. Suggest you remove the lid and clean out any buildups inside. check for for a jam,around the blades like a tampon. Careful - they are very sharp!
Posted on Nov 05, 2009
I have a saniplus. hums constantly, no longer spins when flush toilet/run taps etc. Water just sits there and slowly empties overnight - gravity?
Could be an obstruction in the blade, impeller or the discharge line. Also the starting capacitor may have gone bad and is not keeping up with the head pressure, it may need to be replaced. But i would suggest inspectin the unit first for any obstructions.
Sep 25, 2012 | Saniflo SaniPlus-Round SaniPlus Macerator...
Think my young son put somthing down the toilet filled up with watre wont flush but hums intermitently
Definitely there is an obstruction on the blade or impeller inside the pump casing. Pry open the lid using a flat head screwdriver and remove the motor with pressure chamber out of the pump csing as one piece. Once the motor is out inspect the blade (on top of motor) and the impeller which is at the bottom of the motor. Also the starting capacitor may have seized up. If the capacitor goes bad it tend to hum and not pump any waste out.
May 24, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo Saniplus won't stop pumping
is it pumping against gravity? if so there is a non-return flap in the outlet spigot could be stuck or worn.
Apr 10, 2010 | Saniflo & Saniplus& Macerator Pump
It starts up before I flush!
is your saniplus connected to a shower or hand basin. if so - some water could be getting into the saniplus while you are on it and causing the unit to operate while you are "on the bowl". dripping taps / valves or a "leaky" toilet cistern are the most likely sources.
Dec 04, 2009 | Saniflo 002/005/007 Saniplus Toilet with...
One time flush is never enough (suniplus noisy)
needs a damn good clean - see my other posts. Dont let your landlord fob you off - or one day you will flush the loo and nothing will happen - then it gets messy.
Sep 14, 2009 | Saniflo & Saniplus& Macerator Pump
System not flushing and motor cut out.
Motor may have been jammed and notw burned out.
May 29, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo works in short burst when not flushed eg in night
Sound to me that the toilet is over filling and in doing so water will over flow down the pan. This is definately what I would check first!
Jan 27, 2009 | Saniflo & Saniplus& Macerator Pump
My saniflo toilet wont flush
I think a small plastic item has dropped into my saniflo toilet it keeps maing a loud noise evey few minutes. hat should I do
Nov 15, 2008 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
311 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
