Question about Sony PlayStation Portable (PSP) Console
Psp battery problem
Ive tryed charging it in, but when i insert the plug it will only show a charge for about 30 seconds then it goes off, i tryed switching the battery to another psp but the same problem, then i tryed with a car charger and i still get the same thing, what might my problem be or what shoulld i do??
Replacing the batteries and chargers should help,also don't leave your charger plugged in when its done,you will occasionally devastate it,making it charge slow and battery life drain in hi speed,Best option is to charge it until to 90%-95%.
Posted on May 26, 2011
  • 4 Answers
U have briked ur psp and need to hold r trigger (while psp boots up) and recover it (that only works if u have custom firmware) if u dont have custom firmware u need to get a pandora battery and jig stick and use that to downgrade an restore ur psp to 1.50
Posted on Jan 26, 2008
    Problem Solver:
  • 6 Answers
Ok I had made a Pandora Battery to unbrick and downgrade PSP's. Well as I was doing transforming the battery I neglected to back up the eprom.
I instead loaded and eprom from another battery. The battery would not charge and would only show a small percetage and then shut down.
This worked for me. I took a high output white LED and carefully slid it into the two end slots on my OEM Battery. You know you have the right polarity when the LED lights up. Now as the LED only draws minimal current it was still going after one week. I then added an incandesant flashlight type bulb by connecting it to the led leads. You have to be careful as not to short the wires together. Let it run and you will see it slowly dim as the battery drains.
Do not let the battery draw for too long though. Check it frequently and wiggle the LED so you can tell you still have a connection. If the incandesant bulb is out but the LED is still lit you should be good to go. Draining the battery too long can reverse the polarity and pooch your battery.
I plugged my battery into an external wall type PSP battery charger and let it charge for several hours. I was suprised to see the charging light turn green. I placed it into my PSP and checked the battery's properties and it was 100%!
I gave it to my kid to play with for a while and it played fine. I then took and backed up the eprom and changed it back to a pandora battery as it is my spare.
Once the
The problem 's if u kept ur psp battrey without changing the battery it will bad , you have to wake up the battery by open the battery ,you remove the battery from the case .use solding iron to remove it after that , use ur psp changer to jump start the battery for just 5 min , after that solder it back it will start working ,,,,,,, bye
Posted on Dec 20, 2007
Psp battery and screen
It's bricked. What that means is that the system software has been corrupted. The most common reason for this is if someone turns the PSP off in the middle of a system update. It can be fixed, but it requires special equipment which costs about $40 if you can find it online. The following website can rebuild the system software for you for $30. They also do other PSP repairs -- you can send them both and they will check them out for you! No charge for an estimate!
May 28, 2010 | Sony PSP (Piano Black)
My PSP will not turn on unless it is plugged into the outlet. When I try to turn it on by itself the power light flickers green for two seconds and then disappears. Also, the battery is fully charged. When...
replace the battery as it may be out of CYCLES even tho it says its fully charged if the battry is new your going to need a new element inside usually this consist of a new logic board under the battery pack.
good luck
Apr 27, 2010 | Sony PlayStation Portable (PSP) Slim...
Power Problem with my psp
Make sure the plug is all the way in the socket, and make sure it's plugged into an outlet. If those are bouth done. Are you sure it only charges for the 3 minutes? maybe it's full by the time th elight goes off. Uhhh I'd say it's probably something wrong with either the things connecting the battery to the PSP or, the female end of the power connector. Damn females always messing things up.
Apr 28, 2009 | Sony PlayStation Portable (PSP) Console
Psp won't charge
check the battery or the charging cable is not inserted correctly or its cutted
Jan 26, 2009 | Sony PlayStation Portable (PSP) Console
have you tried using the battery on another PSP? Prolly, the battery is a defective one?
Jul 29, 2008 | Sony PlayStation Portable (PSP) Console
My psp will only turn on for about 10 seconds and turn off there is no picture during that time what do i do
It sounds like a problem with your rechargeable battery. when you charge it, is it showing a full charge -- should be after around 45 minutes. wosrt case is you'll need a replacement battery from Sony.
Apr 11, 2008 | Sony PlayStation Portable (PSP) Console
PSP Charging problem
TEST : Take battery out. Plug in to wall. Wait 30+ secs with psp on. if the power turns off, then its the adapter which is broken, which costs about 5$
Your battery needs to be changed. Standard flavor costs bout 8$, extra long lasting spicy flavor costs 16$. (lol, chips)
Seriousley though, after some time, wear, and in some cases, temp. changes, the battery can become so weak, that it will only hold about a 5 second charge. Once you get less than 1 hour play time W/O charger, need to get a new battery.
Feb 21, 2008 | Sony PlayStation Portable (PSP) Console
Psp battery won't charge
Its a problem with the unit's charging will have to get it replaced it shouldn't cost you more than 10$..
Oct 27, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
211 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
