Question about Maytag 24 in. MDB6600A Jetclean II Built-in Dishwasher
Food left on dishes, and glasses are very cloudy. We use rince aid, and have tried several detergents. Water temperature has been turned up twice.
  • Neptuneblue May 11, 2010
    Had the same problem, turned out dishwasher wasn't draining right. Check the drainage hose (under sink, hooked to garbage disposal in my case). Make sure it has no kinks and has a smooth, close-to-level path from dishwasher to drain. I had to loop the drainage hose around a pipe a couple of times to keep it level. Then check to make sure there is no water left in the bottom of your dishwasher after you use it. If there is, it's still not draining properly.
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Posted on Jan 01, 2010
Whirlpool adp6000ix not cleaning properly
I would suggest getting a de calcifying agent and putting the washer through several cycles. Sounds like the dump valve may be getting plugged up.
Sep 06, 2012 | Whirlpool Dishwashers
This is a 3 yr old dishwasher with very gentle use. It now is not cleaning glasses....even when rinsed before hand the glasses are still stained and spotted. Also my silverware needs to be completely...
Hard water stains are easily taken care of with the help of vinegar. Add 1/4 vinegar to the cycle when you start it and it will help to remove spots and cloudiness.
As for food residue you might check your filters and water pressure.
Oct 30, 2010 | Kenmore 13863 Stainless Steel Dishwasher
Glasses and dishes coming out cloudy
You should try cleaning all the filters inside,take them all out & clean them well.Also remove the wash arms & make sure there is no food scraps blocking any of the water holes in them.After doing that you should run some rinse aid or dishwasher cleaner thru a cycle.
Jun 04, 2010 | Dishwashers
Dishwasher is not washing dishes properly . cloudy glasses etc fairly new machine but used salt and rince aid but still no joy
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jun 02, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
CLOUDY DISHES IN DISHWASHER SOMETIMES THE DISHES COME OUT CLOUDY
modern day dishwasher use less water than the older ones so you have to use less soap a lot less only 2 tablespoons but you also have to use rinse aid with the very little soap the cloudy residue on the dishes is left over soap
Apr 04, 2010 | Maytag MDB9600A Jetclean II Built-in...
White film left on dishes, does not seem to be cleaning thoroughly
could be several things... usually it just needs rinse aid.. all dishwashers spot or leave dishes cloudy without rinse aid.. or your water is just to hard, in that case you will need to soften it with salt, check the owners manual to see how that is done.. also run the dishwasher right after you put the dishes in, if you leave them for a day to wait to fill it up then the dried food gets like cement.
Dec 01, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Rinsing agent not dispensing
the problem is hard water. go to www.dishwasherfilter.com. they have a filter designed specifically for this problem. it filters the water going into your dishwasher leaving your dishes crystal clean with every load. it is very affordable and guaranteed to work.
Mar 18, 2009 | Dishwashers
Dishwasher is not washing dishes.
Make sure your water is at least 120 degrees and change to a dishwasher detergent with a water softener and a rinse aid in it.
Jan 31, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
Food left on dishes
Scrape your dishes of food.  Dishwashers remove whatever is left.
Nov 26, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Maytag 24 in. MDB6600A Jetclean II Built-in Dishwasher Logo
278 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
