Question about HP Color LaserJet 2600n Printer
Fault "door Open" Hp2600n
Just completed the rather complex lens cleaning due to no magenta colour printout. Now have a "door Open" fault showing in the printer window. Have had a look but cant fint the control switch for the door - obviously stuffed up something here during stripping down for the lens clean. Anyone know the door-switch location please??
  • Mezz200 Feb 28, 2009
    I have this problem but cannot see any plastic switch in the top left as indicated. Anyone got any ideas?
    Cheers.
    Mary
Obviously people arent as ambitious as me. Door switch is at the top left front and is a sliding plastic section that is pushed into the interior of the LHS circuit board that I did not replace fully - the micro switch was not in the fully inward position so the slider did not engage the switch. Very simple really!
RicW
Posted on Dec 28, 2007
Fault finding
Magenta Print-head may be blocked.
Depending on the model of machine.
Either on the Menu on the printer find Ink Management or press the Ink Management button.
Print a Test Page
If no Magenta Dots showing then proceed to Cleaning and Clean the print-heads through the proceedures given on the machine.
Print another test page. If Magenta Dots are fine then cleaning done. if not then try cleaning again.
If still not fine then the machine will need to be cleaned professionally which will cost a reasonable amount. Most service fees are more that it is to replace the printer.
Mar 31, 2014 | Brother DCP Office Equipment & Supplies
Lens is 50mm 1.4 50% of the time lens will not stop down to aperature selected. Will stay wide open. Lens has nt been dropped or abused.
The lens aperture blades most likely have become oily and are sticking together, it's a very common fault.
To fix it the lens needs a near total strip down, clean and reassembly and it's absolutely not a job to be undertaken on a DIY basis, especially on one as expensive as yours. The job could be awkward when lenses were mechanical but was a DIY prospect for skilled DIYers, Now that everything operates electronically there are fewer complex mechanical linkages, but for various reasons the job has become far more difficult.
Your only option is to return it to Sony. If it's under warranty then it's free, if it's outside of the warranty then it may be done free on a goodwill basis as oil migration is a fault caused by poor design or manufacturing. If you live in the UK then your right to a free repair is far stronger due to the Sale of Goods Act. Basically it makes retailers responsible for all faults on goods for up to six years (five in Scotland). So if you live in the UK and Sony wish to charge you, you may have a claim against the retailer for the cost of the repair.
Jul 18, 2011 | Sony 50mm f/1.4 for Alpha
Dear Sir, I have one HP Color LJ 2500 Printer. Problem is that when I am taking printout all colors are not coming. Red Color and others colors are missing except black one. Model number: C9706A
I have worked/ serviced similar Laserjet Color Printer with same issue.
Actually, prints with faded colors or different colors are due the the dust/ toner dust accumulated on the optics (mirrors and lenses) inside the printer, which refect the laser beams to form prints. For instance, red color is formed by a mix of yellow and magenta toners. The color is replaced by yellow due the the partial or complete blocking of the image laser beam for
magenta as the mirrors which reflect laser beam get covered with dust and toner (which partially blocks the laser beams). Hence the image is not produced properly. This needs professional hands for servicing and cleaning of the optics inside the printer. Note that first magenta goes off, followed by yellow, then cyan and lastly black. This is due to the mirrors placement inside the printer. Magenta is the last one facing upwards at 45 degrees angle and gets most of the dust and goes off first.
Rest assure that the printer requires ONLY CLEANING OF THE MIRRORS, which are inside the printer. So, it is advised that you get the printer serviced by any printer repair/ service professional. (Please note that the mirrors, lenses and scanner assembly inside such printers is extremely complex and can get damaged very easily especially the mirrors).
Hope it would help. If you need any clarification, let me know
Good Luck!
CreativeTECH
Apr 08, 2011 | Office Equipment & Supplies
Hi, my HP2600N colour laser jet leaves two 1cm wide coloured smudge lines length ways on all my A4 prints. The printer is getting to about 2 years old now so i'm fearing that some major part needs...
Dots, Lines and smudges on the printouts are due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines.
Also, make sure that the visible inside of the printer is clean and there is no spilled toner inside, which sometimes results in dots.
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Replace the Cartridge or get the PCR Roller changed by a professional.
Rest assure that the printer is fine and needs no major replacement.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Jan 22, 2011 | HP Color LaserJet 2600n Printer
Magenta colour is very light
fist of all chack print out with useing new cartridge . if prolem not get fix than ...
that fault due to scaner problem .
u have to change scaner printer.
Apr 28, 2009 | HP Color LaserJet 2600n Printer
Ip5000 printer
This could be down to None canon carts clogging the head up or clogging the purge unit up, If they are all canon carts it could still be down to the print head, if not it could be down to the Logic Board. At the worse case it could be down to both printhead and Logic Board
Hope this helps
Oct 20, 2008 | Canon i850 InkJet Photo Printer
MFC240C - all printouts in green colour
green is a combination of Yellow and Cyan, it is possible that you are missing magenta, depends on the file you are trying to print, if you can print one of each color this time print only magenta it would be helpful to isolate w/c is w/c from there you can find out what is the problem
hope this helps
Aug 08, 2008 | Brother Multi-Function Center MFC-240C...
Wonky colour printing!!
you need to run a print alignment test.. this should correct the colour faults (unless you really do have blocked cartridges,
Sep 27, 2007 | HP DeskJet 5550 InkJet Printer
HP Color LaserJet 2600n Printer Logo
330 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
