Question about Video Game Consoles & Games
The upper screen are all white but when i turn it off its ok
  • 21 Answers
It's these wires in your ds on the right that are damage you should buy a new one or use your warranty.
Posted on Oct 04, 2009
How to calibrae my gps nuvi garmin 255????????????????
For the Garmin 2x5 series GPS
Calibrating the Screen:
1. Turn off the nüvi.
2. Hold the upper-left comer of the screen white turning on the nüvi
3. Release the power key when the Garmin screen appears.
4. Continue to hold the upper-left corner of the touch screen for 30 seconds until a white screen with "Press dot" appears.
Here are links to the manual for both the 255 and the 255W (wide).
I hope helped & good luck! Please rate my reply. Thank you.
Jun 30, 2011 | Garmin nuvi 255W GPS Receiver
I plugged my Nokia 5130c-2 to my laptop and i contacted a virus and when i tried to on the phone it shows a white screen. and fail to start.
first check that your incoming-out going calls are ok.if it is ok yhen it may be the display ic fault if it is not ok then flash the phone .or first switch of the phone ,put out the battery then put in the battery and then switch on the phone,if problem solve then dont do the upper step,if problem conti.do the upper step 1000%% ok
Jun 27, 2011 | Nokia 5130 XpressMusic Red Unlocked Import...
I need to calibrate my Garmin Nuvi 1260T. It's been alittle off ever since I got it. I tried holding the power button for 30 seconds and waiting until the calibration screen pops up but nothing pops up. ...
In order to calibrate the screen on the Nuvi 1260T, you need to follow these few simple steps.
- Turn off the device
- Hold the upper-left corner of the screen while turning on the device
- Release the power button when the Garmin screen appears
- Continue to hold the upper-left corner of the touch screen for 30 seconds until a white screen with "Press dot" appears.
This should allow you to calibrate the screen. I hope this helps!
Mar 01, 2011 | Garmin nvi 1260T 35 in Car GPS Receiver
Screen seems OK but there is no way to interface as it does not respond to touch. Unit is 255w and about 2 years old.
The solution to this problem is for you to calibrate the screen. Before calibrating the screen, i will advice you reset the gps. To reset your device, hold down the power button for about 15 seconds, it will restart itself and power up fully, if the touch screen does not still work, then calibrating the screen will do the job for you. To calibrate the screen, follow the steps below:
  1. Turn off your nuvi,
  2. Hold the upper left corner of the screen, then turn on the nuvi,
  3. Release the power key once the garmin screen appears,
  4. Continue to hold the upper left corner of the screen for 30 seconds till a white screen with 'touch dots' appears,
  5. Then follow the rest of the guide from there.
It might take a few tries before it works for you but you have to keep trying till you get it right. I am very certain that this will work for you.
Dec 31, 2010 | Garmin nuvi 255W GPS Receiver
My Nokia 7390 wont turn on!!!
the drop might lossened the lcd or damaged ur phone and this is a hardware problem i recommend u to take it to ur product care center
Apr 04, 2010 | Nokia 7390 Cellular Phone
Upper rack is not cleaning. Greasy dishes on top seem that dishes are not being washed. Seems the upper water turning dispenser is not working, Bottom rack seems ok. I guess I only have half a dish washer...
Check the upper arm for free spinning, then remove the arm and check that the seam between the upper and lower halves has not split somewhere. Also check all the small holes for debris plugging. Run the machine in wash cycle for a little while with the upper arm off--that should flush out anything blocking the pipe up to the arm. If still nothing from the upper arm, tear down the lower arm assembly down to the deck while noting position of all parts removed. Clean the big screen at the bottom in white vinegar and hot water. Inspect the holes in the bottom for anything blocking them.
Aug 15, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
The bottom part of my laptop screen have colour lines
You need to change the display screen of your laptop. Walk into HP shop anywhere.
Mar 17, 2009 | Computers & Internet
My nokia n95 turn to white screen.
Power off phone. Press and hold Green, * and 3 and keep them held whilst powering on and for a few seconds after
man the code written is hard reset for n95 **** .there is a hardware problem in the cell phone you need to change the strip of ur cell phone which connect the upper and lower portion.
Jan 30, 2009 | Nokia N95 Cellular Phone
Hello I've got this problem. when my computer running, sometimes my screen go white screen and i can't see at all to the windows, just white screen. but all function is ok so i press power button to...
got this from a friend: Apparently some series of Acer notebook came with BAD_EDID laptop display. The only thing wrong is the checksum which is 9D and should be 1D. Powerstrip 3.76 (registered version) managed automatically to correct EDID.
There is no problem with drivers from 101.x series, but with any newer driver max. resolution is 1024x768 and the picture is in left upper corner of the screen with black bar on the right and smudged taskbar to the bottom of the screen. After installing and restarting resolution is set to 800x600 what results in white screen whit thick black bar slowly appearing on the screen.
Jan 27, 2009 | Acer Aspire 3690-2196 Notebook
Half screen activated only
When only a half screen is produced, it is usually a upper or lower buffer board, if the top half is blank then it is the upper buffer, and of course if it's the bottom half then it's the bottom buffer board
Sep 15, 2006 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
Video Game Consoles & Games Logo
37 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
