Question about Square D Co. HOM130 Circuit Breaker
I have 2 seperate circuts that keep going out then after a few minutes they come back on
  • 8,404 Answers
What are you running on these two cirduits?
Is the total load more than the rated breaker?
15 amp should be protecting #14 wire. 20 amp shuld be protecting #12 wire. 30 amp #10 wire.
Add up the amps of everything you have on the line to check this. If you have Clamp Amp meter, you can measure what is going out the wire.
On second thought, if you had a clamp amp meter, you wuldn't be asking the question.
Let me know what you find out ...
a
Posted on Oct 01, 2009
My USB cable connection was pushed in and broke. It's detatched from the circut board it's connected too inside the hard drive. Can I buy this circut board seperately. It also has the power connector on...
No, but you can buy another enclosure to put your hard drive in. Disassemble your mybook, remove the drive and connect it to your new enclosure -- that's it!
You can buy a new enclosure from newegg, or radio shack (they had a few for really cheap on clearance last time I checked), Just make sure you buy the correct size enclosure, it's most likely 3.5"
Jan 01, 2011 | Western Digital 1TB My Book for Mac Hard...
Hln617w1x/xaa keep shutdown in 5 to 10 minute,picture kind of bleeding??
Its a common problem. The lamp needs to be replaced.
Call 1-800-samsung & choose the parts dept.
For the replacement lamp it cost $149.99 plus tax & shipping .
You give them the lamp code ( red sticker on the side of the tv) , they send it out 5day shipment.
Local tv repair services can install it for an installation fee. This will save money apposed to ordering through a tv repair shop who charges an order part fee plus etc...
Oct 17, 2008 | Samsung HLN617W 61" Rear Projection HDTV
My left channel goes out on my 533, when I touch the RCA in the back, it comes back on for a few minutes then cuts out again???
You need to replace the RCA plug with a new one. If it is on a seperate cable replace the lot, if not cut it off. There are only two wires one earth and the channel, you can't go wrong.
Dec 04, 2010 | NAD 533 Turntable
How does an ignition switch affect a car?
It is a switch allowing current to flow to all apporiate systems most have three seperate circuts a starter an ignition circut and the accessories.
Nov 20, 2010 | 1998 Chrysler Sebring
97 linc town car/ at night the auto head lights turn on. on low beam, works fine then when using turn signal the headlights go out. hit signal arm to high beam, and the lights come on, then i put back on...
You have a bad mutifunction switch or headlight switch is going bad and is over heating then cooling off comming back on Have a mechanic check it cause there are other things that can cause this. Since it's not blowing a fuse at this time I would say the head light switch is bad.
Sep 28, 2009 | 1997 Lincoln Town Car
Intermittent Sound
you have a bad surround sound board, you must replace the board or send it off to pts electronics for rebuild, to save money you can hook up a seperate stereo to your cable box or sat. box and take the tv out of the loop for sound.
Sep 15, 2009 | Hitachi 61SWX10B 61" Rear Projection...
Constant flashing clean light
count the blinks shoud be 7 times it blinks then a pause if it does that its a heat circute problem need to check the heater and replace the controls
Jul 13, 2009 | Whirlpool Dishwashers
Where is my blower motor relay on a 2001 olds alero
The blower motor circut for testing the unit is located above the glove box. You will have the remove the glove box for access to check if the motor is any good. If you are looking for the relay, they can be either in a seperate fuse panel located in the passenger footwell or under hood at the base of the windshield, under the plastic shroud. If the motor is not working or only works on a few speeds, it has been my experience that the motor needs to be replaced. I would look there first. I hope this helps and good luck.
Jul 12, 2009 | 2001 Oldsmobile Alero
Mitsubishi VS-45607
there is a protection circut that will shut down the tv when it detects a failure in one of the components , when components heat up to much they go into thermal breakdown, the part that is heating up and failing is getting worse , so it will need to be test to determine which one
Oct 09, 2008 | Mitsubishi VS-45607 45" Rear Projection...
I have a bosch exact temp self cleaning oven and the control pannel dosent work, you can turn the oven on but you cant turn it off, also when i unplug the oven and start over tne buttons dont work at all...
Well i now have the answer to the bosch stove dilemmas if you have a glass touch panel on your bosch stove and you can't get the touch buttons to work right then check the circut board on the back of the glass it is cheaply held to the glass with a non hardening caulk and when your oven heats up the glass panel
the caulk gets so soft that the circut board and the caulk seperate causing inconsistent button operation. To solve this push the circut board and its frame back to the glass then get some aluminium tape at the building supply you shop at in the heating section and tape it into place so it can't seperate anymore then it should work for you. Make sure you have everything grounded properly.If you are concerned about the grounding you can use duct tape to be safe. ( there has been a lot of complaints about glass touch panel incosistentcies on more than one model so im 90% sure this will fix those too).
Jun 29, 2008 | Bosch Kitchen Ranges
Square D Co. HOM130 Circuit Breaker Logo
44 people viewed this question
Top Square Electrical Supplies Experts
Jim D
Level 1 Expert
ken skalski
JOHN LAPIER
Are you a Square Electrical Supply Expert? Answer questions, earn points and help others
