Question about Garden
My lawn boy 6.5hp mower isblowing fuel out of the muffler
My lawn boy 6.5hp commercial rated mower is blowing fuel out of the muffler... whats up with that??
  • Anonymous Mar 15, 2014
    how to bleed lawn mower fuel lines
  • 718 Answers
Maybe it's a stuck float valve or a bad float. Had a similar problem on a TORO rider but that turned out to have a pin hole in the brass float, it filled up with gas and let just about the hole tank through the muffler. I changed the brass float and still running to this day! Note: your float may not be brass if it is a newer machine it will be plastic.
Posted on Oct 01, 2009
Why wont my mower start and gas comes out of muffler
carb is flooding out ether bad plug or your carberator needs rebuilt
Aug 25, 2014 | Toro Lawn Boy Self Propelled CARB Walk...
I have a Lawn Boy silver series self propelled mower, model number 10324-8902967 that leaks fuel from the exhaust under the mower deck after I have finished mowing and turned the engine off. I will drain...
sounds like the needle valve is not seating some have a rubber tip on needle some have it in the seat but the fuel we now have rot the rubber never store with fuel if possible
Apr 02, 2012 | Toro Lawn Boy Self Propelled CARB Walk...
Victa Turfmaster gear selector. I have had the mower back to the dealer three times to fix different aspects of the selector mechanism.
How old is the mower? If its under warrenty, I'd request a new selector completely! Is it commercial or residential grade?
Sep 24, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
I have a Lawn Boy 10685. Changed the blade and went to start the mower and the pull cord will not pull. I tried spinning the blade by hand with no luck. I took the starter apart and it spins fine. I check...
Remove the spark plug and try pulling the starter again. You may have a fuel leakage into the cylinder and it has caused a hydraulic lock. Check/change the needle and seat in the carb as this leaking is the usual cause if this type of problem. Good luck and please rate this solution.
May 22, 2011 | Tecumseh Lawn Boy Push Mowers Insight...
Lawn boy 2 cycle mower won't start
Replace the spark plug and retry.
If a new plug does not work push the spring button on the bottom of the carburetor to make sure fresh fuel is in the fuel bowl.
if this does not work remove the spark plug and squirt some light oil (like wd 40) right into the spark plug hole; roll the engine over slowly a couple times using the starter rope. put the plug back in and snap the plug wire in place. If the mower now starts after a couple pulls it means the rings are worn, replace the rings.
May 29, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Just bought a 10 year old lawn boy 2 cyl mower from my neighbor. He had not used it for 5 yrs (heart problems). I put the 2 cyl ashless oil into the gas like the instructins said 32/1 mix. That turned out...
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helps
May 20, 2010 | RTO Lawn Boy 6.75hp Mower
Lawn mower blowing out white smoke
Change the oil...it is diluted with water or gas
Apr 05, 2009 | Garden
Garden Logo
264 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
