Question about Icon Epic T60 Treadmill
It feels like the belt is catching. Worried that if I get going to fast it's gonna pitch me into the wall
    Problem Solver:
  • 11 Answers
Use a silicone spray on the underside of the belt, this will lubricate the belt and make it run smoothly
Posted on Oct 01, 2009
Whining engine
does yours have a turbo fitted as it can be this. if it dont go up or down with engine speed it can be somthing ells , like a wheel bearing catching brake shield ( onto the disc) or even the thrust bearing on the clutch. auto dont have this.
Mar 23, 2014 | 2001 Toyota Celica
Hoover makes a loud noise and does not pick up
Issar 702:
Take the machine to a room that has no carpeting, (this is 'gonna get messy :-) First, make sure that the machine is unplugged from the wall, then remove the wand with the hose and verify that the hose, wand and vacuum head are not clogged up... check carefully, some clogs or items stuck in the hose and wand assembly can be hard to find! Then check the hose from end to end making sure that the hose is clear of debris. Then open the canister and check to see that the gasket around the top of the canister is not damaged, then check the belt coming off of the motor driveshaft is not binding or damaged. You should be able to rotate the belt by hand with the machine off and unplugged.
Jan 06, 2013 | Vacuums
Will not start. engine turns over very fast but
Hi does it sound like it is turning over much easier than normal? much faster as you say.
If so, it sounds like the timing chain/belt has broken
or the starter motor celinoid or the starter not catching.
Does the engine sound exactly the same tone wise or is it much higher pitch when trying to start?
Regards
Dan
Feb 01, 2010 | 1996 Mercury Grand Marquis
When in fast spin there is a loud rattling sound as though there are stones in the drum
You could have something fast between the inner and outer drum, or one or more of the drum paddles is loose..
Remove lower rear panel of washer, remove the belt, and from the front spin the drum by hand, this this will show if the drum bearings are o/k.
There should be little or no noise from the drum.
If it is rumbling, or feels rough, then the main bearings have failed.
If ther is something caught, then you will hear it catching or clicking.
Hope this helps.
Dec 10, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
My car wont start, fuel pump problem?
fast high pitched noise? never seen or heard of this, done 100's of belts, this noise is caused by a belt being adjusted to tight, belts just break. do you have fuel pressure, what engine do u have?
Sep 28, 2009 | 1997 Chrysler Sebring
Turns over really fast will not catch n start.... not firing almost acts like its gonna backfire...like air popping
The timing belt has jumped a tooth, you must d a compression test, then get a repair manual to check if the mechanical timing is of indicating a jumped tooth on the timing belt.
Aug 05, 2009 | 1989 Buick Electra
Turntable spins too fast at both speeds
this is belt driven turntable....have you tried adjusting it via the pitch control or even getting another belt for that turntable....
Apr 12, 2009 | Audio Technica AT-LP2D Turntable
Vaccum stops cleaning after a while it shuts off
Sounds like the motor is overheating and thermalling out (Hight Temp shut down). This could be caused by overfilled cannister, obstructed passageways, or debris accumulated around the motors cooling fan. Try emptying the catch container and blow out / clean all the filters. Check for obtructions by going to the hose mode and alternately blocking and uncovering the nozzle end - feel for good suction and listen for a definite change in motor sound (Pitch Change) With the intake open, the motor should rev freely, when blocked it will slow and sound labored / loaded down. Another possible cause could be a binding brush roller overloading the motor - but this will usually burn out the belt first. Notice any unusual smells? Burned belts stink like burnt rubber.
Jun 01, 2008 | Fantom Vacums FM760 Twister 500DX Bagless...
Icon Epic T60 Treadmill Logo
293 people viewed this question
Top Icon Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Alienware X51
Alienware X51
Level 1 Expert
Are you an Icon Exercise and Fitnes Expert? Answer questions, earn points and help others
