Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
I am able to crank the trimmer but it does not stay on. in the past it worked just fine but sat unused for roughly 4 months and now this. we own a TB425cs string trimmer. how do i fix this issue?
  • saltsea210 May 11, 2010
    is the fuel fresh ? fuel oil mixture
  • 148 Answers
1) Change out the old fuel (not just adding fresh but pouring out the old and replacing it entirely) and check the engine oil.
2) Check muffler and/or spark arrestor screen for restrictions.
3) Clean and reinstall spark plug (check gap).
4) Replace inlet screen INSIDE the carb. (It is located directly under the inlet needle.)
Try each of these as needed.
Hope this helps!
Posted on Oct 01, 2009
1995 polaris 425 magnum wont start
try cranking it with your hand completely blocking the carb intake for a few cranks. that sometimes helps blow out the passages.
Oct 14, 2017 | ATVs
2009 dodge avenger many problems
That light is to let you know there is an issue with the Throttle system and there is reduced power. Check for codes with a real scan tool, not a code reader.
Aug 11, 2012 | Cars & Trucks
Homelite mighty lite wont stay running
the problem is in the carburetor most likely, it may be cleaned and adjusted, if not it will likely need a new carb
May 31, 2010 | Homelite Mighty Lite Lawn Trimmer
Wont run in run position
if it runs on choke only and it sat up for two or three months the carb diaphragm may be brittle and not pumping fuel. install a carb diaphragm and gasket kit or try opening the high speed jet a 1/4 turn
Jul 01, 2009 | Craftsman 25cc Gas Line Trimmer
1993 altima will crank but will not start..
replace the distributor oil is leaking into the electronics of the distributor and shorting out pull cap back off and look and see if oil is leaking out
Jan 24, 2009 | 1993 Nissan Altima
Running rough
you need a new fuel pump
Jan 03, 2009 | 2002 Ford F250 Super Duty SuperCab
TAILGATE
Probably needs new stays/supports/arms, as I think the fluid leaks out of them gradually and you can't get them refilled so far as I know.
Happened to a friend's ancient Nissan Bluebird Diesel tailgate and he managed to get new stay/support/arms from a Scrapdealer at a very reasonable price. Bit of a problem fitting the new ones but managed in the end and now the tailgate stays up no problem.
Jul 07, 2008 | 2005 Peugeot 405
Fuel injection? 1990 Topaz-4 cylinder
since the car sat for 6 months it could be a vaccuum line the lines are rubber or hard plastic the tend 2 dry rot or chewed by small rodents, while the car is running listen 4 whistle or check for cracks or lines off completely
Jun 17, 2008 | 1990 Mercury Topaz
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
323 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
