Magnavox TV Model FP4640
Picture is very fuzzy and there is a buzzing noise. There are tubes in the TV with some kind of liquid. The liquid is dirty and needs to be replaced but I do not know what the liquid is
The picture tubes in these models (red, green and blue) use a liquid coolant to keep them cool. In this set usually the blue and green fluid will become contaminated which has a major impact on picture clarity and brightness. If you take the screen off and look directly into the lenses you will see directly how bad the fluid looks. The Red usually is not affected by this problem.
The buzzing could be a noisy coil or possibly a high voltage leak. There may also be some leaking fluid involved in this as I have seen fluid gather around the high voltage cup (underside of the tubes) and cause the high voltage to arc a bit causing noise as well.
This repair is not for the faint of heart as it involves removing the affected tubes, disassembling, draining, sanitizing, reassembling, refilling, reinstalling and realigning them. The glycol based fluid is messy and it's easy to get into big problems if there are any leaks, as the leaks will usually end up on the main pc board. Our shop charges about $350 for this repair.
Posted on Dec 20, 2007
My magnavox tv is making a buzzing sound, no picture, and wont change channels (just a dark screen)
Something has shorted in the set causing the power supply to make that buzzing sound. Most likely the short is in the horizontal circuit. The horizontal makes the high voltage work which in turn lights the picture tube.
Oct 15, 2009 | Televison & Video
Vizio makes loud static noise, picture goes fuzzy.
You should check your home wiring and grounding. Also be aware of anything that has recently been turned on when this happens. Anyone using a microvwave, cell phone, or other appliance that might be causing the interference.
Mar 02, 2009 | Vizio P4 46 in. HD-Ready Plasma Television
hi the problem is the picture tube of ur television has got damaged.. its better to replace a new picture tube...
Jan 24, 2009 | Philips Magnavox 27MS343S 27" TV
Fuzzy picture
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become  cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from that includes replacement coolant, photos. instructions, etc.
Oct 24, 2008 | Philips 55P8241 55" Rear Projection...
Magnavox projector TV
replace the coolant in the CRTs ( picture tubes) and the color and clarity will be restored. If you need more information please let me know by responding to this post.
Jun 25, 2008 | Televison & Video
Blurry screen
coolant fluid on picture tube may be contaminated replace it an setbe ok (this is a technician job)
Mar 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
9p6040 c102
Visit for a repair kit. Its a common problem and an easy fix.
Jan 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 60'' rear projection screen tv
That oil is glycol and is a coolant for the tube. Hope you didn't get the oil on the circuits because it is conductive and the tv will not operate with the oil on it. Must be completely full. Can be bought a electronic parts distributors or a tv shop could order you a bottle. Hope you just removed one tube only. Make sure you seal it back good
Dec 30, 2007 | Philips Magnavox 9P6034C 60" Rear...
BIG TROUBLE with my 52" Phillips Magnavox Rear Projection Tv, HELP!!
It sounds like the 3 "GUNS" are not aligned.
One the controls at the bottom, left hand side You will see an arrow pointing to the first 2 on the left.
That will allow you to scroll down the list of options until you see....CONVERGANCE!
make the red gun center by using the up/down arrows on right. Then add the next 2 until you see a white X or cross.
Thats it!
Jul 16, 2007 | Philips Magnavox 51MP392H Rear Projection...
Buzzing Noise and TV picture is yellow
Andy, I'm thinking the buzz is from the deflection coil (yoke) on the neck of the tube or the power supply. Probably not the high voltage as you can hear the "buzz". If it's really that annoying, you can take a length of rubber tubing (no metal) and listen to the buzz coming from the chassis kind of like a stethoscope. STAY AWAY FROM THE HIGH VOLTAGE, please. The yellow picture sounds like a blue chroma failure. A tube can be rejuvinated if need be but that's a job for a pro. Hope this helps.
Oct 30, 2006 | JVC AV-27220 TV
Televison & Video Logo
152 people viewed this question
Top Televison & Video Experts
