Question about Maytag Dryers
I have a Maytag Model DE608 dryer and all of a sudden it is not heating. What could be causing this?
    Problem Solver:
  • 10 Answers
Fantastic dryer!!
Several things come to mind. Cycling thermostat, heating coil, electronic control unit. If you know your way around a multimeter, I could further help you out.
Posted on Oct 01, 2009
Matag dryer not heating
Here is a link to maytag dryer repairs http://apcoappliancerepair.wordpress.com/?s=maytag+dryer . The most common problem is the thermal fuse. My question is. Does the heating element start to light. If not...... and you have changed the ignitor and thermal fuse. Then check the flame sensor to see if there is continuity threw it. Power to the gas coils and ignitor runs threw the flame sensor. CLICK HERE to see a flame sensor on a GE dryer. They are the same on most units but Maytag will be on the opposite side of burner chamber.
Apr 30, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Dryer was working fine. It's between 5 and 10 years old. Suddenly stopped heating. Model #HYG3658AWW Rev 14
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 06, 2011 | Maytag HYG3658AW Gas Dryer
Why all of a sudden is my maytag gas dryer not drying the clothes
heatman101
Apr 20, 2011 | Maytag Dryers
I have a maytag dryer (dwsr-ele-2406026-fm54) and all of a sudden it will not heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 16, 2010 | Dryers
My Maytag Dryer DE608.. does not get any heat. It worked great 2 days ago.
heat element can be bad. you can fine heat element inside at the back of the tumbler
Oct 15, 2010 | Maytag Washing Machines
Won't start or heat up
Check your breaker box for fuse box. sounds like you are only getting 1 leg of the 220VAC to the machine.
Sep 19, 2009 | Maytag SDE3606A Electric Dryer
I have an old maytag electric dryer model #DE608 that has a three wire cord. I moved into a new home with a four hole dryer outlet. Can I switch the dryer electrical line from the existing three wire to a...
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power cord, take that wire or strap off the frame. (it can be discarded or better yet, in case this dryer needs to ever be converted back to a three wire cord) connect the frame end of the wire / strap to the center terminal of the power block. Now, Green (ground) wire goes to the dryer frame, White (neutral) goes to the center terminal, and the Red and Black (both "hot") wires go to either outside terminal. (one to each)
Jul 06, 2009 | Dryers
Dryer is not heating air
Sounds like the heating element or coil is out, but it could also be the board to. At any rate, if your not getting any heat what so ever, its more than likely electrical and its best to take it in. If it gets some kind of heat, then you might try cleaning out your dryer vents really good, and also in the dryer. Hope this helps.
Jan 02, 2009 | Maytag SDE3606A Electric Dryer
MayTag Dryer Model # LDG862AAE
dryers either heat or don't heat,you must have a clog in the dryer vent and or the wall vent that must be cleaned out,let me know what you find-mike
Oct 15, 2008 | Maytag Dryers
Dryers Logo
182 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
