Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Thermastat temp "fixed" and i do not remember how to adjust it up and down.
  • Josh White May 11, 2010
    I need model # to be able to help.
    Guru:
  • Honeywell Master
  • 587 Answers
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Posted on Oct 11, 2009
Replaced blower motor and resistor, also heater core and thermastat, and control panel in dash, still only cold air blows out.
most likely your problem is the temp blend door actuator it is a motor that moves a door in heater case to adjust temp
Dec 24, 2010 | 1997 Chevrolet Cavalier
Dryer does not heat but spins, what should i do?
Have you cleaned the vents out lately this could be your problem. The thermal fuse may be blown if so the operating thermastat may have caused it to blow. Check all thermastats , the thermal fuse, the high temp cutoff and the heating element. Be sure and clean the vents inside and out sometime something will get in the fan housing and slow the fan down or stop it.
Dec 05, 2010 | Amana NED7200TW Electric Dryer
98 civic keeps overheating. will do ok at higher speeds I guess because it causes the fan to spin and cool it down. I was told it was the coolant temp sensor. had it fixed and it worked for about a...
the system may be clogged up somewhere, flush out system good. then put anti-freeze back in and then change the coolant temperature sensor, also change the thermastat. good-luck!!
Oct 25, 2010 | 1998 Honda Civic
The elec fans will not come on\r\nthe temp gage
Hi: Your are sure all your Replays are good,And all your Elecrtical Connections are Good Fuses ,How about your Your Adjustable Screw in Thermastat? Have You Checked That,It Works the Same way your Home A/C would work Cuts off at the High Temp setting and Comes on when it Cools Down to the Low Thermastat Setting.This is Adjustable I Beleive.Call To Verify my Solution with a Dealer. But Sounds like it could be Not Funting Properly. Hope this Gives you another Solution to Check if you already have'nt Checked. from the WYOCWBOY
Jun 02, 2010 | 2002 Chevrolet Venture Passanger
HOW TO CHANGE THERMOSTAT ON THE V-6
First make sure engine is cool.
-Put drain pan under car, coolant will run out.
-Remove the TOP radiator hose that runs to the metal thermastat housing. Coolant will now be running out, try and direct it to the drain pan below.
-Remove the thermastat housing, BEFORE removing the thermastat make sure you TAKE NOTE at how it is situated in the casting.
- Take the thermastat housing and run a wire brush on the flat spot were the old gasket material is.
-Both mating sides of the thermastat housing MUST BE PERFECTLY CLEAN. There can not be any old gasket material left.
-Insatll new thermastat.
-Put a very light amount of PERMATEX orange high temp. silicone on BOTH sides of the new gasket.
-Put a small amount on bolt threads also.
-Now install thermastat housing, and bolts.
-Tighten bolts down a little at a time, alternating between the two, unitl till they are tight.
-Install the radiator hose, and tighten hose clamp.
-Remove radiator cap, pour in coolant, until it sits just below the radiator cap neck. This may take a little time as the system has some air in it.
-Install the radiator cap. Make sure you radiator overflow tank is filled properly.
-Remove the drain pan, make SURE ALL the tools use used are secure, and out of the engine bay.
-Start engine, and place your heater control to 'HEAT"
-Let engine run until the top radiator hose is hot, which means you thermastat has opened.
-Keep watching the engine temp AT ALL TIMES, we wnat to make sure there is no air in the system.
-Inspect for any leaks. Now when the top radiator hose is hot make sure the hose clamp is tight.
Please let me know how it goes.
Feb 11, 2010 | 1993 Buick Skylark
How do I adjust the therastat on the oven. It is
Store bought thermometers are really slow to read the correct temperature. Give your oven at least a half hour closed to let your thermometer catch up. Calibration is very delicate and you could do more damage than good if you don't know what your doing. If you think your temp is off more than 100 degrees, chances are the thermostat is beyond repair. Anything less you can just adjust your temp to compensate. In my area, the gas company will calibrate ovens as a free service. Good luck!!
Jan 16, 2010 | GE Kitchen Ranges
I do not know the model number of my honeywell thermastat. It is square with 4 arrows on the face. Please tell me how to set the thermastat. I press the buttons and see you set for differnt time of the...
press and hold the arrow key for about 3 seconds and release. this puts it into the set mode. then adjust the temp as desired. when you have it, leave it. it will automatically set to that temp in a few seconds
Dec 06, 2009 | Heating & Cooling
Temp gauge off charts
Are you mistaking the engine temp sensor for the engine temp sending unit? The temp sensor is for the fuel injection system and the temp sending unit is for the gauge. If you asked for a sensor thats what they sold you. You need to ask for a sending unit.
Dec 18, 2008 | 2005 Chevrolet Cavalier
MAH5500BW Neptune - water temperature not following panel random
this sounds like a energy saving switch,I would check your inlet screens first. then we can go from there.
Nov 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Cooling fan will not work
i had to replace the relay coolent switch and the thermal coolant switch to make mine work when its suppose to and to stop it from over heating i needed to change pluggs thermastat and anti freeze and adjust timing
Jul 15, 2008 | 1992 Toyota Tercel
Heating & Cooling Logo
81 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
