Question about OKI C5500n Printer
Vertical lines when printing red or cyan - OKI C5500n Printer
Remove the drum unit. With an alcohol swab, clean the little wire sensors that touch the sides of the drum unit that are protruding from where the unit usually sits. Also clean the copper connectors on the drum unit where those sensors touch. Clean the lens on the underside of the printer lid with an alcohol swab. Try printing again. If that doesn't work, you need a new drum. If the drums are relatively new, call Oki and they'll replace it for free. 1-800-OKIDATA.
Posted on Oct 23, 2009
5 Suggested Answers
  • 7 Answers
SOURCE: printed documents and pictures have dark red vertical lines
does this happen when receiving faxes and photocopying?
Posted on Jun 16, 2008
bnachos
  • 38 Answers
SOURCE: i850 Color Bubble Jet Printer/Serial No. FBHP20999
In your print driver there is the option (nder Maintenance) to clean the heads. Run this and then run a test print. It should remove the lines. If it doesn't run again. If you haven't used the printer in a while it may take several cleanings to correct. If after 4 or 5 cleans, the problem still exists, buy a new cartridge; your current one is dead (even though the other colours may be fine).
Posted on Jul 07, 2009
SOURCE: Epson Stylus T10: Horizontal bands when printing cyan
With I could post a solutions but I have the same problem! Cyan has horizontal gaps, rest of the colors seem to be ok. I've realigned and cleaned the heads many times.
Posted on Oct 29, 2009
KiraRanjeet
  • 70 Answers
SOURCE: i have a red color line printing vertically on
Its time to take a new printer.
Posted on Jul 09, 2010
Why too much yellow and red no greens or blues ?
Inkjet printers use additive pigments. CMYK, Cyan, Magenta, Yellow and Black. It sounds like you're not getting any Cyan ink to the paper. Either your printer is out of Cyan ink, or your Cyan print head is clogged.
Go into your printer's Properties and run a Nozzle Check. It will print a series of lines with each color. There will probably be a big empty space where it tried and failed to print Cyan. You can try cleaning the print heads, but if you're getting NO Cyan that is unlikely to work.
If you're lucky, your printer is one of the ones that the print heads are built into the ink cartridge so replacing the cartridge will resolve the problem. If you're not, you might need to get it serviced (or probably more cost effective, buy a new printer).
Apr 30, 2014 | Epson Stylus CX5700F All-In-One InkJet...
Printing problem comes after 10 page or 50 pages after ,(cyan,magenta,yellow) color verticals 1and half inch line comes in print .
after printing 10* or 50 pages* at a time then you should off your printer for 15 minutes then restart it again.
*problems comes because your printer goes very hot
Jun 08, 2012 | HP LaserJet CP1215 Color Printer
Have vertical cyan lines 1 inch wide on same side
Don't know about your "primed" toner, but go to Diagnostics and run the PQ test. See what that looks likes. Go to Disable Cartridge Check and swap the black and cyan toner. Run another PQ test. Are the lines still there and are they black or cyan? If they are cyan, the cartridge is bad. If they are black it's not the cartridge. It going to take a tech to look at it.
Feb 02, 2010 | HP LaserJet 4650 Color Printer
When printing a red line appears about every 8mm through the all of the page i am useing a epson rx630 fred
It means some nozzle not perfect. If you check nozzle, there is missing lines for some nozzle. Example : Print blue color ( 100% cyan + 100% magenta). If some point of cyan head is clog, the output will be shown that at some lines just show magenta. It repeated. Yous said every 8 mm, so, you must print it at best photo quality. If you have print at best photo quality, and lines still appear, it must some nozlle badly clog. Try do head cleaning, wait for 30 minutes. Check Nozzle.
Jun 25, 2009 | Epson Office Equipment & Supplies
HP 2600n prints some blue vertical lines
1 of 2 things: First, check yuor Cyan cartridge and make sure that it is not leaking. It may have a bad seal. If you replace it with a known good toner, the imaging unit (the black acetate thing) will need to be replaced. This is also a consumable unit.
Jun 23, 2009 | HP Color LaserJet 2600n Printer
Mar 17, 2009 | Office Equipment & Supplies
Possible Print Head Issue
Select the Jet Substitution Mode.
  1. On the Control Panel, select Troubleshooting, and then press the OK button.
  2. Select Print Quality Problems, and then press the OK button.
  3. Select Eliminate Light Stripes, and then press the OK button.
  4. Select Jet Substitution Mode, and then press the OK button.
  5. Follow the Control Panel prompts to select the color and malfunctioning jet number indicated on the Light Stripes Test page.
Mar 25, 2008 | Xerox Phaser 8550DX Laser Printer
OKI C5500n Printer Logo
655 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
