Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
Hot tub has power but nothing else works
There is power going to the hot tub, the light comes on but the jets will not power up. I have hit the reset button, unplugged it and nothing happens. We have only had this hot tub for 3 months with an average usage of about 2 times a week.
  • 1 more comment
  • A Miller May 11, 2010
    You need to get your dealer over to fix this ... dont mess with it unless you are a skilled technician.
  • Lynn Sherman
    Lynn Sherman Sep 12, 2012
    My Maryland Hot Tub wont heat , Spa Pump wont work , Jets not working
  • Lynn Sherman
    Contact Maryland Hot Tub Repair - Pool and Spa Service and set up a Diagnostic service call. Here is there contact info: Maryland Hot Tub Repair - Maryland Pool Service - Maryland Spa Repair Pool Parts - Spa Parts - Hot Tub , Pool and Spa Repair - Pool Opening - Pool Closing - Pool Service 410-304-2463http://www.maryland-hottub-pool-spa-repa... or see them onhttp://marylandhottubrepair.blogspot.com...
MY control panel was replaced ,it cycles but, no lights ,no jets,no heat works..What's the problem .
Posted on Jun 10, 2012
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
  • 81 Answers
Once more try to turn off the power to the hot tubs and call a service specialist if you wants resolve the issue or when the central electrical wiring is problem.
Posted on Jul 15, 2015
    Problem Solver:
  • 9 Answers
Contact Maryland Hot Tub Repair - Pool and Spa Service and set up a Diagnostic service call. Here is there contact info: Maryland Hot Tub Repair - Maryland Pool Service - Maryland Spa Repair Pool Parts - Spa Parts - Hot Tub , Pool and Spa Repair - Pool Opening - Pool Closing - Pool Service 410-304-2463 http://www.maryland-hottub-pool-spa-repa... or see them on http://marylandhottubrepair.blogspot.com...
Posted on Sep 12, 2012
  • 80 Answers
Verify that you are getting power to the pumps when the pumps are told to turn on.
Posted on Oct 01, 2009
My hot tub has an issue. Only half the display is working, there's no heat and the jets wont turn on. If I trip the curcit, I can get the hot tub jets for 10-30 seconds and that's it. HELp
Almost all hot tubs use 230 volt AC power which comes from the power company in two power wires plus one common common wire. You get common 115 volts between a common and either other wire. "Half way" working could well be an attempt to run on only one of the wires. There is also likely to be a ground fault circuit breaker in the wiring which makes sure current going out to the tub is all returned via the wires and not through someone's legs to ground. If you're comfortable with an AC voltmeter check some voltages but understand that 230 volts is way into the killing range. Two people present and well insulated probes are important.
Apr 15, 2016 | Pool & Spa
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
My hot tub is not coming on at all and is giving me a Pr code. What can I do?
please follow this steps and fix it. God bless you
If the unit won't start, make sure power is on at the electrical panel or the electrical panel . Then test the pump and the motor. Check for and repair broken wires or loose or corroded terminals. If necessary, have the pump switch control tested and serviced professionally.
If the jets do not work, clear a blocked water intake of hair and other particles (see below) or replace a broken jet (see below).
If the water in your spa or hot tub is too hot or too cold, check to see if the high-limit reset switch has been tripped and, if needed, reset it. Adjust the thermostat setting and have the thermostat serviced if the problem persists. If necessary, test and replace a faulty heating elements
Nov 26, 2013 | Qca Spas Dream Series Dream Master Hot Tub...
I am getting a Pr code and the tub is not coming on at all
If the unit won't start, make sure power is on at the electrical outletor the electrical panel Then test the pump and the motor. Check for and repair broken wires or loose or corroded terminals. If necessary, have the pump switch control tested and serviced professionally.
The light will not come on after starting jets and the reset button has been reset. The water is hot in the tub. brand new unit
i have the same problem, checked ohm's there good at 15, why won't the rapid heat light come on letting me know t's working?
Jan 16, 2011 | Jacuzzi RapidHeat In-Line Heater U395000 [...
My electric went out for 24 hours. I hooked up my generator to the breaker box to power the house. The generator only powers one 110 leg so there would have been 110 going to oneside of the 220 breaker to...
You should start with checking all your breakers to be sure the breaker did not pop just half of your breaker. This is something you should do with all your breakers. When you do this you should shut down all your 220v breakers so you don't get bleed back through the system. Other than that you need to look for resets on the tub. The heater is a good place to start and don't forget the gfci's on the tub or in the bath or laundry room.
Dec 13, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Froze the jacuzzi.
You'll need to start electrical troubleshooting from a point where you have power and then keep testing further into the unit to find out where the power stops. Is there a local 'ground fault' reset button inside the hot tub control area (under the tub?)
Jul 11, 2009 | Home
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
2,332 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
