Question about Garden
Poulan Super25DA old chainsaw from the mid 70's.
Poulan Super25DA (Model S25DA) old chainsaw from the mid 70's. Power head is perfect. I need to know what kind of sprocket will allow me to change from a 1/4'' pitch chain to a 3/8'' pitch Part number or shaft diameter and number of teeth on sprocket would be helpful.
  • 17zeus17 Oct 01, 2009
    I should have been more specific. I checked all Oregon parts. They don't have anything listed for a Model S25DA and no 1/4" pitch anything. It's probably too old. So I'm looking for a cross reference to change everything (bar, chain sprocket) to 3/8" pitch from the 1/4".
  • 148 Answers
Call your local Power Equipment Dealers and ask if any of them deal with OREGON replacement parts.
OREGON makes clutch drum, chain and bar combinations in the thousands!
NOTE: Along with clutch drum and chain replacement, your bar will need to be changed also, as the sprocket-tip in the nose of the bar will be a different pitch.
Posted on Oct 01, 2009
Which carburetor kit do I need for a 556y model for poulan chainsaw
Samantha, 556y not a valid model #, Recheck your # and try matching it to the attached links, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Poulan Chainsaw Carburetor Parts
Poulan Carburetor Kits
http www searspartsdirect com model part 2300cva 1324 1503220 10037773...
Jul 29, 2016 | Poulan Garden
How do i replaceclutch drive on a poulan chainsaw p4018wt
Attached is a video from YouTube Donyboy73. In it he removes a clutch and sprocket from a Poulan 2150. I know this is not your saw, but also know all 2 cycle chainsaws are very similar.
There are many helpful chainsaw videos on YouTube. I hope this helps.
http://www.youtube.com/watch?v=zf28-ztoHfg
Aug 15, 2014 | Poulan Garden
Headbolt tension
Hi Belinda, I am not sure what you are asking for when you say headbolt. If you mean cylinder bolt, jug bolt or head bolt then
approximately 125 inch pounds.. not foot pounds!!!
This image I found for a Poulan chainsaw site, Poulan makes most of Craftsman saws. If you match the size you should find your torque setting.
jeromekj
Apr 20, 2014 | Craftsman sears 18" Chain Saw Chain (...
Broken crankshaft on Poulan PP4218AVX Chainsaw
YES IF SAME MODEL AND SIZE, MAY BE IT WORKING PULL OUT THE DEFECTIVE ONCE AND REPLACE OR SWAPPING BY THE OTHERS SAME IN SIZE AND MODEL. I THINK ITS GUARANNTY WORKING..
Dec 28, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do i tell what "type" of Poulan Model 1950 saw I have
The type no. should be on the ser no. plate 1-8 there are small changes between the type no.s but they are all model 1950, is this the machine that you inquired about the sprocket? as that was not the model quoted in you first question!!!!
Jan 13, 2013 | Poulan 14" Chainsaw
How to change the head on a poulan p1500?
hello , poulan p1500 is not the model number,need number to tell you how because there are four kinds of heads,,let me know,,
Jan 12, 2012 | Poulan Garden
Poulan chain saw how to get old chain drive sprocket off.
You'll have to stop the crankshaft from moving. The easiest way to do this is to take the spark plug out, pull the starter rope out a little ways, and stuff some of it into the spark plug hole. Spin the sprocket until it stops turning, that will put the piston at the top where it can't pass TDC and stops the crank. Turn the sprocket until it comes off then put your new one on.
Aug 09, 2011 | Poulan 14" Chainsaw
I bought a used Poulan Pro 3450 and have been surprised by its performance. It came with a 20" bar and I was wondering what the largest bar I can put on the power head is.
hi there maufader
pauly46 here
poulan 3450 think max bar is 24 " have seen modles come out with 22 " bar on std
with 3/8 0.58 chain std but would not recommend any bigger as might burn out clutches
with increased cutting load/ drag
here is web site for parts
http://www.ereplacementparts.com/poulan-3450-gas-chainsaw-parts-c-16962_17147_17763.html
i know its not a poulan pro but is still a poulan 3450 - but model appear to be identical with very minor differences.
cheers hope this helps
May 22, 2011 | Garden
Cannot get chain back on bar of poulan pro electric chainsaw model 1630
Slide the bar on the studs all the way to the left, or rear of the chainsaw, and feed the chain around the motor sprocket, THEN along the top of the bar to the right, and around the bar's sprocket at the right end of the bar, if this doesn't work, report back. This is the original bar and chain correct?
Nov 21, 2010 | Poulan 1630 16" Chain Saw
Garden Logo
238 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
