Question about Fuji FinePix F470 Digital Camera
I dropped it. It powers up & zoom goes in & out. The set date/time display wont change or go away. is there a way to reboot camera other than removing battery?? Thanks
  • 3 Answers
SOURCE: Fuji FinePix S5000 - Display has turned pink!
4/8/08 FOR ALL CCD SENSOR'S MFG by Sony: Found the answer. Sony Repair service is fixing for free any CCD sensor problems on "any" camera that had a "Sony Manufactured CCD sensor". I have now called the service center and they sent me a UPS Return label so I can send my camera in for "free" repair. This is good news!!! I can't remember the site I was on but they listed all brands that had the Sony mfg. CCD sensors in them. So call the Sony Repair Center to find out if your camera has the Sony CCD sensor in it. This was an error in the manufacturing process and they are standing good for this.
Posted on Apr 09, 2008
JULIANFIX
  • 975 Answers
SOURCE: How can I set my Fuji FinePix S700 to print the date and time on the picture?
FIRST , go to MENU of camera and look for SETTINGS , DATE & TIME , if you dont see this option then refer to the camera manual to see if you have this option, some camras have this feature and some of them dont , hope this helps AJ
Posted on May 02, 2008
SOURCE: My FINEPIX s1000fd fujifilm camera
Try these:
1) Make sure the lens cap is off. When the camera fires up, if it feels any resistance, it will stop zooming and tell you "zoom error"
2) Recharge or fit new batteries. Use 2700 power if you can get them.
3)Is there a bit of dirt between the zoom part and the camera body? I had this problem after my camera had been in my overcoat pocket. I cleared it out with a stiff artist's brush. Do NOT use WD 40 or similar, as I found to my cost on another camera. It eventually seeped through to the works and made all the pics cloudy!
4) Hold the camera body in one hand and gently wiggle the zoom part from side to side and up to down.You will hear a quiet click in the mechanism.
I have used my S1000fd lots now, and the initial "zoom error" problems have stopped.
It's a fine little camera, I especially like the 12x zoom and the live histogram. Mine has taught me lots about photography.
Posted on Apr 01, 2009
zohail
  • 1223 Answers
pls update firmware issue will be resolved most likely and pls rate me fixya for help
http://www.fujifilm.com/products/digital/download/s1000fd/fupd.html
Posted on Apr 13, 2009
  • 3 Answers
SOURCE: Fuji FinePix S9000 battery change clears date/time.
Hi
I started having a similar problem with my Fuji FinePix F10 after about 3 1/2 years of problem-free use. Another poster had some really helpful advice which I thought I'd pass on. It seems there is an internal battery or capacitor which basically fails after a while, meaning date/time settings etc are lost when the battery is removed. (Some people claim this is a motherboard/chip problem instead - seems to be contentious!) So the camera is faulty, but the problem can be worked around.
The advice I found, which worked for my camera, was this:
- Turn off camera and leave off for approx 15 seconds before opening battery door.
- Change battery quickly (within a few seconds).
- Close battery door and leave camera off for approx 15 secs before turning back on.
This retained all settings when I tested it multiple times. I imagine it might not work if changing over a totally dead battery though.
Hope it helps!
F
Posted on Oct 13, 2009
How to reset coolpix p90
To reset the camera remove the battery for 15mins, replace the battery. power up the camera and go to the camera's Menu and set the Date & Time.
Apr 17, 2013 | Nikon COOLPIX P90 Digital Camera
Canon powershot sx100is. Error 24 on starting and camera turns off. Can view pictures already taken.
some dry wash lens,display & camera.mother board clean with isopropyl or" petrol.if use ******** wash very good.something heat with mobilephone past.so work it again.harry up in one day or"So4 damage your board.
May 30, 2012 | Canon PowerShot 600 Digital Camera
How do I change the date on my ViviCam 5385 digital camera?
Assuming the camera is working, with the camera off, rotate the mode dial so that the icon with the wrench lines up as the active mode. Then press the Power button and turn on the camera. Press the right arrow to select Custom Menu. Then press the down arrow to select Date and Time. Then press the OK button. Use the left and right arrows to select a part of the date to change and use the up arrow to increase the value and slide the zoom lever to down button to decrease the value.Press the OK button when the date and time (24 hour clock) is properly set.
The manual for the 5385 is available at retrevo: http://www.retrevo.com/support/Vivitar-5385-Digital-Cameras-manual/id/200bh836/t/2/ . You'll need to enter a code to access the PDF.
I hope this helps.
Mar 06, 2011 | Vivitar ViviCam 5385 Digital Camera
I switch on my camera today (finpix 6900) for the first time in a few months and with a new battery. When it comes on it is displaying 'set date & time' but doesnt let me do it or even cancel it as it...
The digital camera relies on the date and time and without setting it the camera will refuse to cooperate with anything you try to do with it. My concern is that once you set the date and time you will be fine until you shut the camera off again because I believe that when you start it back up you will get the same display message and if you do the camera internal battery needs to be replaced.
Aug 07, 2010 | Fuji FinePix 6900 Zoom Digital Camera
How to date change in camera for display see date
Switch on the cameraPress MENU at the back You will 2 icons. One for camera and other for tools. Select tools settings
Scroll down to Date & Time settings. Press Set/Function. Change the date and time as per our time zone. Press again Set/Function. For display of date Select camera icon and on the drop down menu select display. By pressing the function key select the date /date and time. Press Set. The camera is set. Whenever you view picture it will display the date and time
Apr 26, 2010 | Canon IXUS 80 IS Digital Camera
The date is displaying on my pictures for our business we do not want this to happen, it just started displaying recently, we have a DC50 zoom camera, top of the line but very outdated
Press Menu, autourg00778004id1973498.jpg to highlight Setup, then OK to access settings Options Return to previous menu.
Camera Sounds
Choose sound effects.
All On (default)
Shutter Only
All Off
Auto Power Off
Choose inactivity time until camera turns off.
10 minutes
5 minutes
3 minutes (default)
1 minute
Date & Time
See Setting the language, date/time.
Date Stamp
Imprint the date on pictures.
Choose a date option, or turn off the feature. (Default is off.)
Video Date Display
Display Date/Time at the start of video playback.
On (default)choose from date formats.
Off
Blur Warning
See Understanding blur warning icons.
On Off
Language
Format
caution.gif CAUTION:
Formatting deletes all pictures/videos, including those that are protected. Removing a card during formatting may damage the card.
spacer.gif Memory Card - deletes everything on the card; formats the card.
Cancel - exits this setting.
Internal Memory - deletes everything in internal memory including email addresses, album names, and favorites; formats the internal memory.
About
View camera information.
Jan 05, 2009 | Kodak Digital Science DC50 Zoom Digital...
Zoom Error
We had this problem for about 2 weeks, we discovered that having the camera auto retracted after the "ZOOM ERROR" message, giving the camera couples of light slaps (slap the camera's LCD side and aim the camera down), this fixed the camera right away
Mar 03, 2008 | Olympus SP-550 UZ Digital Camera
How do I change the date? I don't have a manual.
1. With power off, press the MODE button to select the DATE mode.
2. Press the zoom out (three trees) button for more than two seconds to enter the date/time set mode.
3. Press the zoom out (three trees) button to select year, month, day, hour, or minute (selected number will flash).
4. Use the zoom in (one tree) button to advance the number.
5. Repeat steps 3. and 4. to set each value.
6. Press the zoom out (three trees) button until the colon (in the hours:minutes) is flashing. When the colon stops flashing, date and time setting is completed.
7. Press the MODE button and the power will switch off.
Jan 13, 2008 | Canon Sure Shot Z180u 35mm Point and Shoot...
Date and time change
First you press the button called "MODE" and, without releasing it, press the "SET" button.
Then, the year will start to blink.
Set the year with the "SET" button. Once you finish setting the year, press the "MODE" button to change to the month.
Then, the same way with the month, day, hour, minutes.
After minutes, the display will stop blinking.
YOUR SET!
Dec 08, 2007 | Olympus Stylus Zoom 140 Deluxe 35mm Point...
Fuji FinePix F470 Digital Camera Logo
32 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
