Question about Dorel Alexander
We moved and cannot find the hardware.........we need replacement screws and parts to put it back together
We also just moved, and broke some of our hardware pieces. I discovered a direct number to Dorel Asia to re-order parts, 1-800-295-1980. You may need the model number.
Posted on Oct 12, 2009
Instructions on how to install replacement screen on ddx616, brother broke screen then took it apart, lost screws, received replacement prts, just need to know exactly how to put it back togethe
I'm sure not many have attempted this repair but it's not going to be unlike most other repairs to this type of device. There will be blank sockets on the new screen with male pins that correspond to cable connectors on the head unit. You'll have to ensure that all open sockets are plugged into the cable from the unit on the new screen assembly. Electronic screws are fairly standard but if you're not sure take one out of the unit and take it to a hardware store to match it. ( I recommend ACE hardware). From there you just align holes and slots and start screwing it back together. good luck!
Feb 03, 2016 | Kenwood Car Audio & Video
Can you walk me through the steps on how to replace rear brake shoes on a 1989 bronco II
The best way to do it , is remove the drums from both sides. Take one side apart. When putting back together, look at the other side, just remember it is opposite from the side you\'re working on. springs are in the same place, just backwards. Do NOT get parts from one side mixed...They are color coded. Get the hardware kits. They wont come with the slack adjusters. Make sure the adjusters are clean and move freely. Most adjusters are screw type, some (Ford) have rachet types. If they look worn, they are bad. Replace them also. Lude them with anti sleaze/ silver nitrate.
Sep 04, 2014 | Ford Bronco II Cars & Trucks
Frigidaire stack dryer was squeaking so bad that I decided to take it apart to see why - noticed it was the socket at the back .. I oiled it, put it back together but my husband and I cannot get the 3...
The drum was not positioned correctly to allow installation of the screws. You may be able to salvage the job by removing the screws and starting over but more likely the screws have been cross-threaded and hardware and parts replacement may be necessary.
May 01, 2014 | Dryers
Pulled the motor because fan was rubbing against plastic shroud. Shaft moves back and forth with about 1/2 inch play. Are the bushings shot and Will I need to replace this motor?
no there is a stopper on the motor like a bit of plastic looks like a ring you need to replace this. take the circlip off the motor and take the shaft out may need to unscrew the screws on some motors on the shaft at both ends there should be a plastic part ( the rings) replace them can use copper or plastic. then put back together and check the movement if still moves a lot try thicker one. should move about 3mil max back and forth.
Oct 23, 2013 | Rheem 84-ERV100 Energy Recovery Ventilator...
My both room has a small water leak
If the two parts screw together you need to get some plumbers tape , turn the water off ,dry the ends and put the tape on tight and just re-screw them back together.
Nov 15, 2009 | American Standard Home
Child Design Crib Replacement Parts
I did the same thing I took the smallest side piece into my local do it yourself hardware store and the found the pieces for alot cheaper than the manufacture.
Jul 26, 2009 | Childesigns Shelby Crib
I need the instructions and screws
I can't find the instructions but they are simple to put together... As for hardware your local hardware store will have the screws you need... You may need to take the part in to get your thread right. If all else contact the manufacture and they may be willing to sell you the parts needed....
Oh and Congrats if you are/had another child
May 21, 2009 | Artist Colony Baby Gear
Cant get it back together
I put together what I knew where it went, the put the whole thing together and looked at it before putting in the screws. I saw a hole and remembered a "button" there that moved sideways with a spring pushing it back into the original place. I reopened and after examining the part put it in that slot. I then put it together and it worked. I put the screws back in then and all is well
Thank you for the reply.
Glad I found your site. I will keep it if I ever need any help.
Kathryn
Oct 11, 2008 | HP Wireless Optical Mouse
Replacement hardware for DaVinci Emily Crib
Debbie, please shoot me an email if you found your parts...I too need some parts: asparkman@att.net
Sep 15, 2008 | DaVinci Leonardo Crib
Baby Gear Logo
231 people viewed this question
Top Dorel Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Jim Goldsmith
Jim Goldsmith
Are you a Dorel Baby Gear Expert? Answer questions, earn points and help others
