Question about Cameras
HOW DO I SET UP OR USE VOICE MAIL - Cameras
Set up voice mail
What model phone do you have and which carrier? For example, with a Verizon iphone 5 these are the steps:
  1. From the Home screen, tap Phone .
    The Home screen is accessed by pressing the home button (located at the bottom of the device).
  2. Tap Voicemail
    You could be directed to the automated Voice Mail system at this time. If so, follow the voice prompts to set up your Voice Mail and greeting instead of completing the steps below.
  3. Tap Set Up Now.
    If the 'Set Up Now' pop-up does not appear, your voice mail has already been set up. Simply tap Greeting in the upper-left of the voice mail screen and begin at step 6.
  4. Enter a password then tap Done.
    The password must be between 4-6 digits in length.
  5. Re-enter the password then tap Done.
  6. Tap Custom to record a greeting.
    To use a Verizon default greeting, tap (check) Default.
  7. Tap Record to begin.
  8. When finished, tap Stop.
  9. Tap Save.
Apr 11, 2016 | Cell Phones
How do I set up voice mail
Voice mail is usually set on first button (number one) of dialer and when you press it for long time you get an message to set the voice mail number if not set earlier or by default. Just ask your provider for voice mail number and put it when requested.
Aug 13, 2011 | Samsung Galaxy S GTI9000 Smartphone
I have a fido pay as you go/ I don't know how to get the voice mail to work
Press and hold the 1 key. The phone should call your voice mail and you'll follow the prompts to set voice mail.
Or, you can call your own phone number and it should go to voicemail, where you can set it up.
If you continue having problems, contact Fido and request customer service re-set your voice mail. Then follow the directions above.
Jan 28, 2011 | Motorola Cell Phones
NEED TO SET UP MY VOICE MAIL
Hi,If your account is enabled for voice mail, you can receive voice messages in your Inbox and also in a text message on your mobile phone. Both the message in your Inbox and the text message will include a preview of the voice message in text.
How do I set up voice mail?
1. Go to https://outlook.com to sign in to your mailbox, go to Options > Voice Mail tab, and then click Set Up Now.
2. When you set up your voice mail:
* You'll register your mobile phone number.
* Text messaging is set up. You can choose to be notified in a text message that you have voice mail or have missed a call.
* Call forwarding is set up so that your mobile provider forwards calls you receive to your voice mail. So if you don't answer your phone, your phone is busy, or you're unreachable or unavailable, the caller will be sent to your voice mail. After your personal greeting is played, the caller can leave a voice message for you.
* You can test whether your voice mail has been set up correctly by dialing your mobile phone number from your mobile phone. This verifies that call forwarding is correctly set up with your mobile provider.
How do I change my voice mail after I've set it up?
After you've finished setting up voice mail, you may want to:
* Change the mobile provider's voice mail number so you can use the key your provider has reserved for accessing voice mail to access your voice mail. For details about how to do this, see Changing the Number You Call to Access Your Voice Mail.
* Create a contact on your mobile phone. For details about how to do this, see Create a Contact for Voice Mail.
* Assign a speed dial key to the contact you create for Outlook Web App voice mail. For details about how to do this, see Set Up Speed Dialing for Voice Mail.
What else do I need to know?
* The voice mail service is available only to certain customers in certain regions. If you can use voice mail, you'll see a welcome message in your Inbox telling you how to set up voice mail for your account.
Thanks for using fixya...
Jan 20, 2011 | Cell Phones
Cant set up voice mail
to set up voice mail on samsung S8300 dial 1750 - to deactivate voice moil dial 1760
Nov 21, 2009 | Samsung S8300 Ultra Touch platinium-red...
Voice mail
Well a about setting ur voice mail
Oct 26, 2009 | Samsung Eternity Cell Phone
Setting up voicemail on sch-u340 phone..cannot read buttons on manual to set up..
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
http://www.samsung.com/us/consumer/mobile/mobile-phones/more-carriers/SCH-U340ZBAUSC/index.idx?pagetype=prd_detail&tab=support
Setting Up Your Voice Mail from page 10 in your manual:
Voice mail allows callers to leave voice messages, which can be retrieved any time.
Note: Once your voice mail account has been set up, you can use the Voice Mail folder (under the Message menu) to view details of voice messages in your voice mail box.
1. In idle mode, press and hold the key or dial your own mobile number
to dial voice mail.
2. Follow the prompts in the new user tutorial to setup your mail box.
Listen to voice mail
to dial voice mail. After connecting, you will hear your voice greeting.
2. Interrupt your greeting by pressing .
3. You are then prompted to enter your password.
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
Oct 16, 2009 | Samsung SCH-u340 Cellular Phone
How to set up voice mail?
press and hold the 1 key down until it accesses voice mail then follow the prompt
Aug 24, 2009 | LG Shine CU720 Cellular Phone
Voicemail
Press and hold the "Mute" or "Clear" button until the handset beeps to clear the New Voice Mail allert.
Jul 04, 2008 | Panasonic KX-TG1033S Cordless Phone
Call will not Transfer to Voice Mail
Typically you want your phone system to ring your phones (say extension 10, 11 and 15) and then if no one answers after so many rings the call is transfered to the port the voice mail is on (let's say it's port 16) The voice mail is set to answer right away but does not "ring" until the call is transfered to it. This way (at 4 rings) if a call comes in on line 1 and you answer after 3 rings but a call comes in on line 2 at the same time, the first ring on line 2 will not make the total = 4 and set off the voice mail. I would guess the port at your voice mail is not set to ring and nothing is set up to transfer calls to your voice mail. Did you set this up yourself? How did you program the phone system?
Aug 21, 2007 | Toshiba Stratagy 4 Lite Voicemail System...
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
