Question about Sony DCR-HC26 Mini DV Digital Camcorder
Usb handy cam is invalid when i connect my camcorder to my pc
  • Sony Master
  • 497 Answers
Option 1:
If you want to use the USB cable to connect the Camcorder to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port.(An i.LINK is a black D shaped connector with 4 or 6 pins. The type ofcable to be used will depend on the i.LINK port of your Computer. TheSony Camcorder will have the 4 pin i.LINK cable and if the computer hasthe 6 pin i.LINK port, then you may have to use the 4 pin to 6 pini.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE:As the Camcorder does not support USB streaming with Vista, it is notrequired to use any Sony Device Driver to transfer the video to theComputer. You do not require any Drivers or Software from Sony totransfer the video from the Camcorder to the Computer using thei.LINK/Firewire interface.
Option 2:
(Applicable for Windows XP Operating System only):
Ifyou are using a Windows XP Operating System then you have to installthe USB Streaming Driver in the Computer from the supplied Softwaredisk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
NOTE: If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Good Luck!!!!!!!!!!!!
Posted on Oct 01, 2009
Sorry to say that i couldnot get my answer.oncemore my question is i have a sony handy cam HDR-CX230.it can be recharge via USB port and photo can be transfered.previously i charged my handycam in my...
First off I would buy a converter that allows you to plug your usb cord into it and then it plugs into an AC outlet. It will charge faster. Second, it sounds like when you PC is trying to recognize the hardware you have plugged into the usb port it isn't finding any software associated with the device and is for some reason restarting. If you received a software disc with your camcorder, try loading it on this PC and see if that fixes the problem.
Jan 21, 2014 | Sony 8GB HDR-CX230 HD Handycam Camcorder...
I have the sony DCR-HC26E handy cam i'm trying to connect it with my pc (windows 7) by using usb cable it wont work my pc doesn't recognise my camera ....thanks
USB connection will allow still photos ONLY to be capture to a computer. To capture the footage from the tape you will have to connect with a firewire cable, also called iLink or IEEE1394a. Windows Movie Maker will be one program that can capture the footage.
May 19, 2011 | Sony DCR-HC26E PAL Mini DV Camcorder
I have recorded the videos in my Hi 8 Cassettes sony handy cam CCD-TRV418E. I want to copy the files to my PC and burn the CD's. My cam recorded doesn't have USB port. Please help me how to go about...
You will reqquire an A/D (analogue to digital) Converter to go between the camera and PC.
Connect the camera to the Converter with analogue cables and the Converter to the PC with a firewire cable.
Mar 07, 2011 | Sony Handycam CCD-TRV418E Camcorder
Sony DCR SR 42E handy cam problem. Almost All of the available hard disc space is used up. now i want to copy all the video files from the Handy cam to my PC. i connect the Handy Cam to PC and select the...
Then the video data files are larger than 100 GB, simple as that. Video uses a lot of GB's, so that doesn't surprise me one bit. 100GB is a tiny amount of storage compared to modern machines, mine has 500 GB's, my Desktop has 1 TB.
Mar 24, 2017 | Sony DCR-SR42E Hard Drive Camcorder
Dcr-pc9e handy cam with no connectors
To transfer video from your camcorder to your computer you will need a firewire cable (IEEE 1394). Only with this cable you will be able to transfer video.
Please note that you will also need a firewire port on your computer. if you don't have one then you can buy a firewire PCI card.
Please see the following link for more info and pictures.
http://en.wikipedia.org/wiki/IEEE_1394_interface
Regards,
nicolasiac
Mar 25, 2010 | Sony Handycam DCR-PC9E Mini DV Digital...
SONY HANDY CAM DCR-HC18E PAL Need download for usb driver windows vista
http://support.sony-europe.com/dime/tutorials/videotransfer/vtransfer.aspx?site=odw_en_GB&m=DCR-HC18E&sec=DV
Only load the driver and install in XP compatability mode then use another video capture programme Sony does not support Vista for you cam.
FX vid capture will work
http://www.jhepple.com/video_capture_software.htm
If you get stuck you can reach me on marshall.c@sky.com
May 27, 2009 | Sony DCR-HC18E Mini DV Digital Camcorder
Hi, Pl tell me procedure to load vid data from sony make handy cam to my computer Regards Asit
First you have to install the software.The software is supplied with the handicam in a cd form.You can connect handicam with pc using usb or dv(i link)port.Go to menu in handicam and select usb streaming on.Connect handicam with pc through usb and switch on to vtr mode.In drive C go to programe,sony corpn,DI,capture.Click capure and get capturing window to download your video.
Dec 02, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Importing from sony dcr dvd 100 to macbook
sell the camcorder and buy a different one, I did
Jun 08, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
Handy cam connecting to pc
Usually things are color coded but if not you should use the Fire Cable I'm not sure what color it is but Its usually a USB cable. (It might be called "Hard wire") Hope this helped. =)
Feb 25, 2008 | Panasonic NV-GS27 Mini DV Digital...
Sony DCR-HC26 Mini DV Digital Camcorder Logo
353 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
