Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
My spa won't blow bubbles but it will heat up. It
My spa won't blow bubbles but it will heat up. It was fine until a few days ago.
  • 8,404 Answers
You opened the air valve??? Usually a round thingy on the edge of the tub.
I cant imagine how this would not work if it were open ... it works on the same idea as a carb on any gas engine. If the hole is open, the water stream will **** in air.
Posted on Oct 01, 2009
Intex purespa displays current water temp but will not turn on or start filter/bubbles. Bought 1 mo ago: just set it up a week ago. Was working fine for 1 week. TrI'd unplug and reset. Any ideas??
is displayed temp less than 2 degrees than setpoint temperature ? its possible this situation will disallow the pump to go to high speed and the air infusers to work till spa heats back up , or can be a heater fault as well
Aug 15, 2015 | Intex Pool & Spa
98 f150 4.6L Little heat and now overheats and blows resivour cap....Head gasket ?
you need to check the radiator,, there is a good chance that the lower half is pluged up
Mar 08, 2014 | Cars & Trucks
Garden leisure spa
check to make sure you are getting 220 to it if not the check breacker
Sep 07, 2013 | Pool & Spa
Elite 50 boiler
There should be a pressure drain to purge out all the air. Sound like there is an air bubble in the system somewhere.
Jun 03, 2013 | Water Heaters
My 1995 gmc 1500 ext cab siarra 's ac stopped cooling, i put at least 2 1/5 cans in it about three weeks ago, it was running fine until a day ago, please tell me what is wrong, is it compreesor re
You have a leak,to see if you do,get a spray bottle,put soap water in it and spray all a.c.lines and see if it bubbles up any where.Look for usual stains at connections.
May 25, 2013 | 1995 GMC Sierra C1500
Air bubbles in the coolant system causing the car to run hot
If you are seeing air bubbles, then the cooling system still has air pockets in it. Loosen the overflow cap and leave it that way for a few days while you drive.Keep the heater turned on at the max heat level. Roll a window down if necessary. Check and top up the overflow bucket daily and top up as necessary. The bubbles should disappear after a few days, then you can tighten the cap. This should also solve your no heat problem. Once the bubbles are gone you can tighten the cap.
If the problem doesn't fix itself in a week, you should have the car looked at for a possible bad head gasket, which would force air into the cooling system. Hope this helps.
Feb 20, 2012 | 1999 Cadillac DeVille
I have a lazy xl spa heater light coming on massage system working but but hot water not circulating
when the bubbles are on the water blowing out of them is cold, you can not run bubbles and heat at the same time
Jul 21, 2010 | Pool & Spa
Heat isnt working...place on heat and turn on but it just stays cold?? Its been like this for like a week or so..it was doing this then started for a few days where it would kinda get warm again and then...
Try bleeding the air out of the cooling system. At the front of the engine, on top, should be a bleed valve. It's small, and looks similar to a grease fitting. This is the highest point in the cooling system and eventually all air in the system will accumulate here.
Make sure the coolant reservoir is serviced to the correct level. With the engine cold, but running, open the bleed valve until coolant starts coming out. Close it and wait for a few minutes. Keep opening it intermittently until no more air bubbles out -- until the engine is warm.
Oct 24, 2009 | 2002 Dodge Intrepid
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
695 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
