Question about Garden
I have no spark on a Echo gt 1000
I have found no shorts or bad connections. The plug is almost new. The most likely source of the problem is the module or the coil? How can I test to identify which is bad?
  • 148 Answers
I know of no absolute test procedures for this condition.
In our shop we recommend replacing both parts . Otherwise, we are not able to provide coverage for our repair to our customers.
(We have sold Echo products for 22 years)
Wish I could offer more help!
Posted on Oct 01, 2009
When to change sparks plugs into my echo 2000
Spark plugs are replaced when the electrodes are found to be corroded, burnt, cracked or oil fouled.
Normal spark plugs need to be replaced every subsequent 30,000 Km.
Iridium - tip spark plugs are replaced every 80,000 Km.
Mar 26, 2013 | 2001 Toyota Echo
No spark #1 plug
each plug has its own coil...? If so check batttery power at the end of
two wire that connect to the coil. (When car is still on )
Q: Any voltage...?
A: Yes.>>> Bad coil. Replace new one.
A: No.>>>>Check for broken wire or bad connector.
Mai
Mar 15, 2013 | 2006 Ford Ranger
Have 1992 Yamaha 1000 fzr an coils not fireing
Hi, Timothymccau and the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Troubleshooting help with no spark on 94 FZR1000 The FZR Forum
View topic 91 FZR600 with no spark
https://www.tradebit.com/filedetail.php/243740163-1989-1995-yamaha-fzr-1000-genesis-exup-fzr1000
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-fz-owners-manuals
Mar 18, 2012 | 1992 Yamaha FZR 1000
Not getting fire to plug,replaced ignition still no spark,echo pb-400e
With a good plug and a new switch there are a few remaining basic options. There is either a bad ignition coil or a bad wire or bad connection somewhere.
I hope this helps.
Jul 29, 2011 | Echo Inc. 25.4 CC Backpack Blower
No spark Backpac blower New plug
You have a bad coil. This is the part that is connected to the spark plug.
Jim
Sep 15, 2010 | Echo Garden
Theres no spark, i changed the plug but its still not sparking. I even held the plug and pulled it to double check. Nothing at all.
your switch may be shorting or your black ground wire is shorting. if all is ok on the wiring your coil is bad. replace it. good luck
Oct 15, 2009 | Echo Garden
This is an illustration of use of classes in php please tell me do i need to put the classes in seperate php file and the objects in seperate file or in other words for the below example how many seperate...
Everything can be in the one file if you want, but that doesn't help with segregation of logic from the presentation layer (i.e. what you see on screen).
Personally I'd put my core class libraries in one or more files and include() them. And I'd probably put any extended classes in separate files and include() them additionally.
include ('library.class.php');
include ('extended.class.php');
Oct 14, 2009 | Computers & Internet
Echo GT 2000 does not have spark and will not start. Checked fuel lines, ok, replaced spark plug, ok. checked for spark at plug, no spark.
Your ignition module is probably bad. The part may be as much as $35, but you might want to double check.
Jim
Jun 20, 2009 | Echo Garden
Weak spark on an Echo GT 1000 trimmer
Recomended spark is 6mm or more if there is no play in the crank bearings you can try closing the magneto air gap to 8 thou if that does not work you will need a new ignition module.
Jun 12, 2009 | Garden
Garden Logo
159 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
