Question about Apple iPhone 3G
IPhone Bluetooth wont turn on
I have a Pwned iPhone 3g running 3.1, but since I upgraded to 3.1 bluetooth just won't turn on, had it pwned on 3.0 and all was fine but now you switch on Bluetooth and it just sits there and spins till it goes back to the off position
  • 2 more comments
  • bbascombe Oct 01, 2009
    No No Bluetooth just will not activate at all.. switch it on in settings, and it will just spin there for a minute or 2 then goes back to the off position
  • Zamda May 11, 2010
    Do you have a bluetooth device that you're trying to connect to? If there's no device in range, it may just be auto turning off to save battery
  • Leslie Coggan May 30, 2013
    my boss is having the same issue. You turn the bluetooth switch on and it just sits there
Joed911
  • 4338 Answers
SOURCE: iPhone 3G keeps saying 'bluetooth unavailable' and 'No Wi-Fi'
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Posted on Jul 24, 2009
SOURCE: iPhone 3G bluetooth problem
I'm also have this problem also and i can't solve it. And for more problem it doesn't have tool to delete some file as MP3 file and i can't use other audio file set as ringing tone.
If anybody can help please post your solution in here.
Thank for advance
Posted on Nov 30, 2008
  • 59 Answers
SOURCE: bluetooth problem
just go to seetings click general and turn on bluetooth a liitle bluetooth icon is going to pop up in the left corner
Posted on May 15, 2009
RixsFixes
  • 2200 Answers
SOURCE: my iphone 3g will pair with bluetooth but wont connect
To qwer355 and also to the asker and anyone else viewing this solution.
The 'solution' provided to this question by hygatgf is Spam.
I am unable to remove it immediately as it was posted outside my moderation timeframe. However it has been reported to Admin and will be removed from the site ASAP.
Until then please do not click on the link provided as it is a completely irellevant link.
RixsFixes
(FixYa Moderator)
Posted on Sep 27, 2009
SOURCE: im unable to pair iphone 3g with bmw x5 2005
That BT is NOT compatible with iPhone, it is that simple, you must get a compatible one.
Posted on Mar 19, 2010
Stucked dfu mode iphone 3g
Open redsnow, click extras, and select Custom iPSW. A dialog window should pop up, go to where you have the ORIGINAL iPhone 3G 4.2.1 iPSW and select it. Press ok and It should then create a NO_BB iPSW in the same location as where the original iPSW is. Second step is to enter PWNed DFU mode. Open redsnow again, click extras and select PWNed DFU mode. Follow the onscreen instructions and you should be in PWNed DFU mode. Open iTunes and a message should show stating that your device is in recovery mode. Great now press ok, hold Shift and click Restore. A dialog box should show, go towhere the NO_BB iPSW is. Click it and press ok. Your device should now be restoring. Afterwards your device should turn on.
Feb 26, 2013 | Apple iPhone 3G
Apple icon frozen have held both home and off for 2 minutes still frozen
your iphone 3g probably has its program corrupted theres a lot of software there to use put your iphone in PWNED mode then restore it thru itunes.
Feb 06, 2013 | Apple iPhone 3G
My iphone 3g will not pair w/ bluetooth headset. Bluetooth menu just cycles over and over.
On iPhone:
1) Go to Settings
2) Go to Reset
3) Select "Reset All Setting" (Make sure you save passwords. Data is safe.
On Bluetooth:
Clear all previous pairings.
Once iPhone reboots, turn on Bluetooth.
Dec 08, 2010 | Apple iPhone 3G
I am having the exact same problem!!
Bluetooth on iPhone:
On iPhone:
1) Go to Settings
2) Go to Reset
On Bluetooth device:
Sep 05, 2009 | Apple iPhone 3G
Wont find bluetooth
What do you mean by won't find bluetooth? some bluetooth headset doesn't work with iPhone make sure your headset support iPhone ! or iPhone support that headset. If you have iPhone 3G try to use iBluetooth (download free on Cydia) to send and receive files with other phone brands. Good luck n hope this help ;)
Aug 31, 2009 | Apple iPhone 3G Black Smartphone
Wont sync with iphone
Make sure that the headset and the phone are both are in "pairing" mode. Even though the iPhone's bluetooth is on you will have to select the headset from the phones bluetooth menu. To get the headset into pairing mode press and hold the "+" sign for 3 seconds. Hope this Helps!
Jun 08, 2009 | Apple iPhone 3G
IPhone 3G bluetooth problem
sony not so good.. try this will work best for your iphone.
May 27, 2009 | Apple iPhone 3G
I want to use my iphone 3g bluetooth in every situation
You can't send and receive files with the iPhone's bluetooth. Version 3 of their firmware will supposedly provide this functionality, but only on the iPhone 3G. (2G models don't have the necessary hardware)
As for the hands-free car setup, that should work just fine. It's a matter of pairing the two devices together.
Apr 20, 2009 | Apple iPhone 3G
Cannot play mp3 via bluetooth
can not play iphone mp3 files to streo bluetooth headphone devise
the iphone 3g bluetooth is at present for headsets/handsfree devices only and cannot link/pair with anything else (phones/pc etc) it has been deliberately crippled to force file transfer etc to be done exclusively through itunes
Jul 15, 2008 | Apple iPhone 3G
Apple iPhone 3G Logo
1,796 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
