Question about Lincoln Welding Tools
Idle selenoid lincoln sa250 welder
Hi, my name is nelson and i am located at venezuela, i have a lincoln sa250 welder with a 3152 perkins diesel, it hasnt the idle selenoid, so i am trying to build it cause cant get it here, can somebody tell me what size of wire the coil has inside, i will appreciate any help, bye
CarlGehrke
  • 169 Answers
SOURCE: Diesel fuel pump/installation
If we're talking about the thing that has a pipe to each of the cylinders on your engine then the answer is Yes, your injector pump must be correctly timed in order for the engine to run properly. This is the part of the diesel that does what a distributor on regular car engine does, namely ignition timing.
The exact procedure for setting the timing depends on what model of engine you have, get a manual from Perkins to be sure.
That said it usually goes like this:
1 - make sure the engine has the correct cylinder at TDC, this makes the gear connected to the camshaft be in the correct position.
2 - Set the pump at the correct position, this will either involve looking at a mark in a window on the pump (standyne pumps), or looking at the keyway in the shaft of the pump, etc.
3 - Bolt the pump into place on the engine making sure the gears/drive meshes nicely. Connect all the fuel lines to the pump.
4 - purge the injectors by loosening each fuel line at the cylinder end and cranking the engine until fuel comes out of the pipe, then tighten it back up.
5 - Crank the engine and start it, check the rpm.
Rank this answer if it helped,
Carl
Posted on Dec 02, 2008
mamicheddy
  • 79 Answers
SOURCE: My lincoln welder/generator Ranger 8 will not idle
Sounds like your CT or CT board is bad. CT stands for Current Transformer. A CT senses an increase in voltage draw or current, which will trigger the idle solenoid.
Posted on May 07, 2009
SOURCE: i have a lincoln classic
First check oil, if oil is good, check oil sending unit by using a jumper wire to both terminals.Your toggle switch may be bad on your idle swith.If that doesnt fix it pull red wire off pc board ground it to frame if it idles down then your pc board is bad.
Posted on May 20, 2009
  • 27 Answers
SOURCE: SA250 Diesel welder starts but will not arc and
BRUSH OR BRUSHLES?
brush brushes worn /sticky
brushless AVR board
Posted on Sep 04, 2009
  • 7 Answers
SOURCE: I am trying to wire a remote into a 1969 lincoln
Go to lincolnelectric.com - click service - click manuals,and if you can find a code # on your machine you can view a complete manual.
Posted on Oct 13, 2009
How to download ecm software for perkins engine DSE 404D.22 made in UK
my name is christian i m a gen technican based in abuja . pls i need some soft ware to repaire gen
Mar 04, 2014 | Miller 907175 Welder Generator Perkins...
Lincoln diesel welder not working
Put a 9 volt battery across the slip rings of the exciter for a moment to "Flash" the exciter. If the first attempt does not work, reverse the polarity of the 9 volt battery. It only takes a few seconds. This creates the initial magnetic field that makes it work.
Mar 25, 2012 | Welding Tools
How to install oil pump on 300d lincoln welder perkins
It is most likely an accumulation of hardened oil deposit, which can get quite hard. Pushing pump shaft in and pulling out repeatedly should slowly knock it clean. Since there are not many suppliers of those parts, best to not pry on anything.
Dec 24, 2011 | Lincoln Welding Tools
Hi, i have a lincoln 300D welder and the problem is when I have it on auto/idle it wont work. it only weld when I have on high/idle. please help. it a 2006 lincoln 300D classic with a perkin engine
You can try to turn the screw on the carb to slightly raise the idle and see if that makes a difference. If not then there is usually a type of inductive pick up that has part of the wiring going through it. When it sense a current draw it releases the engine from low speed. Some of these set ups don't work well if the idle is turned down too far so that's why I suggested trying that first. Plus is that works it is a cheap repair.
Jul 20, 2011 | Electrical Supplies
SA250 Diesel welder starts but will not arc and cannot weld
BRUSH OR BRUSHLES?
brushless AVR board
Aug 25, 2009 | Welding Tools
Lincoln 175hd mig will not feed.
Make sure your roller motor is spinning. If it is, then adjust the rollers tight enough to spin out the wire. If power is available and motor does not spin, check the fuse on the control board. If it is ok, then it is your control board.
May 06, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
Need transformer for Hobart Cybertig CT300
Hi Steve
my name is Rob
The cyber tig brand covers a lot of ground some of it older than me!
critical questions
do you have a parts list?
can you get from the machine
Model number
Spec number
do you have any drawings?
if these are all no all is not lost.
I can get a transformer custom made. i would need some details from the old unit.
Please let me know.
Regards
Rob Lee
Jan 29, 2009 | Hobart Welders Champion 500433A Factory...
I have a lincoln classic 300d perkins welder when on low idle it keeps idling high only kicks down for a second
Oct 12, 2008 | Computers & Internet
Welding Tools Logo
285 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
