Question about HP Office Equipment & Supplies
Not printing to scale and cannot find our manual
  • Tim Degenstein
    Tim Degenstein Oct 01, 2009
    Go to HP website and download manual for your model
    Also what program are you printing from? If its just 1 program your having this problem with then its probably settings within that program?
    If the problem is in all programs ... when you go to print select properties in the printer pop up make sure your paper size is correct ie: if selected 4x6 and printing on 8.5x11 size is off... good luck
    Don't forget to rate me thx :)
  • HP Master
  • 670 Answers
Scale BFM588 User manual
Although the HealthOMeter.com site no longer posts a user manual for the BFM588DQ-81 scale, they do have a different model scale, BFM955-60, instruction manual that will work for the BFM588 because all the setting buttons are identical. You can download the manual for free at their site. Go to the site, under "Service & Support" setect "Instruction Manuals", then select "Body Fat Scales". Once there, find and select the BFM955-60. It will open as .pdf document and you can save it to your computer and print it out. It worked for my BFM588 scale for which I had lost the user manual.
Nov 16, 2014 | Health-O-Meter Health o Meter BFM588DQ-81...
How to shrink document to fit screen size when printing
Scaled Printing
The procedure for specifying a scaling value and printing a document with pages enlarged or reduced to match the document to the paper size is as follows:
1. Open the printer driver setup window, and select Scaled Printing from the Page Layout list on the Page Setup tab.
figure:Select Scaled Printing for Page Layout on the Page Setup tab
2. Using Page Size, select the page size that was set with your application.
3. Do either of the following to set a scaling factor:
Select a Printer Paper Size.
Select a printer paper size, which is different from the Page Size, from the Printer Paper Size list. If the printer paper size is smaller than the Page Size, the page image will be reduced. If the printer paper size is larger than the page size, the page image will be enlarged.6c3578e0-f243-44b0-aa8e-f7bb7752ed56.jpg
figure:Printer Paper Size on the Page Setup tab
Specify a scaling factor.
Directly type in a value into the Scaling box.
figure:Scaling on the Page Setup tab
The current settings are displayed in the Settings Preview on the left side of the printer driver.
4. Click OK.
When you execute print, the document will be printed with the specified scale.
Note
If the application software with which you created the original has the scaled printing function, configure the settings on your application software. You do not need to also configure the same setting in the printer driver. When Scaled Printing is selected, the Staple Side list box appears grayed out and is unavailable (when Duplex Printing is not selected). When Borderless Printing check box is checked for the Page Layout list, Scaled Printing cannot be selected.
Tip
Selecting Scaled Printing changes the printable area.
Hope this helps
Mark
Sep 13, 2014 | Canon PIXMA MX310 All-In-One Printer
MANUAL FOR HEALTH O METER MODEL BFM689SPKH-63
I called their comsuner number for this scale, BFM689SPKH-63. the number was 1800 672 562. She helped me calibrarte the scale, but that didn't work. To calibrate, step on and off 6 times, let it power off, then try again. That didn't work for me so she said to mail it in to their place in MO, and they will send me a new one. So give that a shot.
Jan 28, 2012 | Health-O-Meter Health & Beauty
When we turn on the scale we get an "old". We are
pcs is for counting a number of small parts. Depending on the scale, you put 10 or 50 on the tray and program in the number of units. Then the average weight of the items is used to calculate the number of pieces for the subsequent handfuls of pieces. In the Units mode, press Print Unit to the type of unit counting and follow the screen to tell the number of parts used to set the average mass of each one.
On the "old", is there a problem with the left most LCD elements (so it could be Hold)? This merely means that once you weigh an object if you remove it from the platform the weight will still be displayed. You can turn this off in the menu. Press On/Off (for > 5 seconds) and then Print Unit. If it says Setup, then press On/Off and the Print Unit repeatedly until you see Mode. Then press On/Off and then Print Unit until you see Off. Then press On/Off and Yes to save the mode.
The other things to check: is the scale connected to the AC with the adapter or is it on battery? Is the lockswitch in the locked position? First try removing the batteries or disconnecting the power adapter. (Consider replacing the batteries) Then unlock the lock switch (under the balance at the front) and the shipping lock (below the platform) if needed.
I hope this helps. I don't have this scale but a very similar one.
(the manual for the SP601 is here: http://www.oldwillknottscales.com/ohaus-scout-sp601.aspx scroll down for the pdf link)
Dec 26, 2010 | Ohaus SP401 Scout Scale 600g X 1g SP601
Need user manual
I found the PDF file that contains the instructions for the weight watcher scale. Thank you, please let me know if this works for you. http://www.conaircanada.ca/en/pdf/ibs/en_WW66C.pdf
Thank you
May 03, 2010 | Conair Weight Watchers WW-87 Body Fat...
I have just purchased a Jensen Digital Audio Player 2 GB model #smp-2gbl and need a manual that the print is large enough that I can read it. Can you help me?
There's a manual for the SMP-xGBL model going to next link:
http://www.spectraintl.com/jn/pdf/SMP-2GBL%20English%20UM%20(ALI,%20no%20DRM,USA).pdf
Adobe Reader is needed to read this manual in pdf format.
Enlarge the view to about 200% or choose fill to width of screen in the top bar of Adobe Reader to enlarge fonts and pics. ( zoom - function )
For a large print of the pdf file choose
above the top bar of Adobe Reader:
File > Print...
in the print overview under Page Handling:
Page Scaling [ Tile all pages ]
Tile Scale [ 200 % ]
Hope this was enough information to get a readable manual.
When needing more help, just post a comment.
Jan 15, 2010 | Jensen Audio Players & Recorders
Want an English manual for Tanita 2240 Body Fat Scale
here is a link for the manual http://www.theusermanualsite.com/mdownloads/9bdb1c74-c15c-4760-bc30-42b15d11a9f2.pdf
this does have an english manual. there is not an english only manual Tanita is a european company and supplies to many countries with different languages to make things simple they print the manuals in many languages. There is an english version of the manual on the link.
Apr 04, 2009 | Tanita 2204 Body Fat Scale
Canon mp530 issues with printing
Use scaled printing (Mac OS X) Instructions to use scaled printing. You can manually select the scaling ratio you wish to use to print images and documents. scaling_sample.jpg Note: The Scaled Printing function is not available when Borderless Printing is selected (OS X.version 10.2.1 or higher).
  1. Open the Page Setup dialog box.
  2. Specify the Scaled Printing settings.
    Note: For a reduced scale printing, enter a value smaller than 100 %. For an enlarged scale printing, enter a value greater than 100 %.
  3. Click 'OK'.
  4. Open the Print dialog box.
  5. Click 'Print'.
Printing will now begin.
I hope it helps!!!
Nov 27, 2008 | Canon PIXMA MP530 All-In-One InkJet...
PRINT SCALING
Print scaling adjustments are in the print driver.
They are in different locations depending on the driver. PCL or PS.
But there will be a scaling adjustment within the driver in te properties.
Will have to search through the driver features to find it.
Jan 14, 2008 | Xerox Phaser 7400/DXF Laser Printer
26 people viewed this question
Seeker5211
Seeker5211
