Question about Wolf Range WKGD-2 Gas Double Oven
No gas to oven
I have a wolf 36" 4 burner with gridle I turn on the oven and the ignitor glows but no gas flow after 30sec or so I tap on the safety value and then the gas flows could it be that the ignitor is not telling the saftey value to open or is the safety valuve bad
    President:
  • 744 Answers
Hello, even though the igniter is glowing it does not mean it is drawing the correct amps to open the safety valve. If your igniter is glowing orange replace it. Igniters should glow brillient yellow to the point where you cant look at it. replace the igniter and you will be good to go. Good Luck!! Mike
Posted on Oct 01, 2009
  • sterlingcat1
    sterlingcat1 Jun 20, 2012
    Mine does the same, I tapped on the regulator and it took off and quit again, going to replace the regulator.
I have a Maytag (Magic Chef) gas oven model CGR3730ADH. The oven will not heat up. The ignitor will glow/heat up but there does not appear to be any gas flow. The top burners work normally. After...
HI,
First of all, thank you for all your information. A rule I live by, even if an ignitor glows does not mean it works. The ignitor works on the flow of electricity through it not how bright it glows. If you can use a amperage meter, hook on one of the two wire to the ignitor directly. You need 3.2 to 3.6 amps to open the safety valve. If lower than 2.6 amps, it will not allow gas to enter the burner. If you have no clue what I am asking you to do, you can purchase and replace the ignitor and life will be better. P# 12400035. Its not difficult to change, the screws holding the ignitor in place sometimes strip out, when you get them off, you can replace them if needed.
Good Luck
Jul 23, 2011 | Maytag Ovens
My oven is not working The Broiler works and the stove top works fine but the oven will not heat and when you turn it on no gas comes out I tried turning it on and using a lighter but nothing happens
You gave us good clues in information!-- Thanks!
Most modern gas ovens have a device called a Glow Ignitor to light the burner.
If this ignitor has filed, it will NOT left the gas valve open-- (Good thing, right? :-) )
You say the broiler lights fine-- so let's observe something when the Broiler lights:
Do you see a bright glow near the Broiler burner?
(Usually toward the top rear of the oven--)
Well, you should see a similar bright glowing near the BOTTOM rear of your oven, for the main burner to light off-- If you do NOT see this glowing-- then you need a new ignitor-
You can remove the bottom burner cover, and dig deeper into the repair if you like-
But a new ignitor needs to be exactly like the failed one-- the safety circuit is very fussy about the exact same ignitor-- or it will not allow lighting-- even with a new 'generic' installed.
How deep do you want to go into this repair?-- Maybe it is time to call the service people into do the job?-- You can tell them that you think the ignitor needs replacing-- and approx. what will they charge you for the service call and the ignitor?
I hope this helped.
Mack B
Jan 27, 2011 | GE 30 In Freestanding Gas Range ...
I JUST MOVED INTO A HOUSE WITH A WHIRLPOOL SUPER CAPACITY 465. IT DIDN'T COME WITH A MANUEL AND WE DON'T KNOW HOW TO BAKE. WHEN WE PREHEAT IT DOES NOTHING. THE SELFCLEAN AND BROILER WORKS THOUGH
Remove the bottom tray in oven compartment...... usually 2 screws at the rear... Turn it on to bake and see if ignitor glows if not test ignitor for 120v if you have 120v replace the ignitor. If it glows and still does not light burner after a few seconds the ignitor is weak replace it. (The gas safety valve has to receive a certain amount of power that must flow through the ignitor for the burner to ignite a weak ignitor will not allow enough power to flow through it). If you are not getting 120v trace the circuit.
Nov 04, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Oven will not light, hot surface ignitor is working, is this a safety valve problem?
    While the ignitor is glowing, tap on the valve with the handle of a large screwdriver. If the valve opens and the burner lights- replace the ignitor. If not replace the valve-depending on age I will sometimes do both right then.
    Eric
    Jun 25, 2009 | Ovens
    Oven won't light, even with ignitor getting red
    If your oven won't bake, check these:
    Bake igniter
    Other causes
    Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
    The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
    Other causes Other reasons that your oven may not bake are:
    • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
    • The thermostat is defective.
    • The safety valve that prevents accidental gas flow is defective.
    • The selector switch is defective.
    May 23, 2009 | Magic Chef 9122 Gas Single Oven
    Frigidaire Model EGF337Ecc oven not heating. element is bright orange you smell the gas but burner does not come on
    If the ignitor is weak, it will not open the safety valve. It WILL however glow, but it's not strong enough to release the gas. The ignitor should pull at least 3 amps, any less, it won't open the safety valve for gas to flow. Repl. the ignitor, it should be fine.
    May 03, 2009 | Electrolux Ovens
    Amana arg7800ww oven will not come up to temperature.
    Your gas valve has a thermocouple circuit that will not let gas flow until the ignitor is hot enough. A failed ignitor can still glow but not be hot enough to open the gas valve. Replace your ignitor.
    Jan 13, 2009 | Ovens
    Electric starter gas oven model jgrp17 won't heat
    more than likely your glow bar ignitor has stopped working or at least pulling enough amps to open the safety valve. The floor of the ovens come out may have a couple screws toward the back. take the floor out if a diffuser is on top of the burner remove it. the glow bar ignitor is mounted on the burner turn the oven on and watch it should glow bright red and in about 30 secs open the gas safety valve. If it does not glow you may want to verify power to the ignitor, more than likely the ignitor is the problem. If it glows but does not open the safety valev still replace the ignitor not pulling the required amps to open the safety valve. just put a little dish soap on the screws to the ignitor to help from srtripping them out
    Nov 13, 2007 | GE JGRP17 Gas Single Oven
    Wolf Range WKGD-2 Gas Double Oven Logo
    287 people viewed this question
    Top Wolf Range Ovens Experts
    John Rodgers
    John Rodgers
    Fred Sops
    Lakeland Appliance...
    Are you a Wolf Range Oven Expert? Answer questions, earn points and help others
