Question about CookTek 14 in. MC-2500 Electric Cooktop
Sudden failure while in operation. Best guesses: circuit breaker, fuse or power supply failure
    Brigadier General:
  • 8,619 Answers
Hi Malcolm,
Thanks for using FixYa. Please make sure that the cooktop has a dedicated 15-amp line. The cook top needs 13 amps to operate and should be on a 15 amp dedicated circuit. If the circuit is not 15 amps or there are other electrical draws on the circuit, the unit is not getting enough power. The fuse may need to be changed. The fuse is a 250V ceramic, 20-amp fuse. It is always recommended to contact a qualified repair tech for changing the fuse as this will solve the problem and is much more economical than sending the cooktop in for diagnosis.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks Rylee
Posted on Oct 01, 2009
  • Sushant Fadte
    Sushant Fadte Mar 27, 2015
    Error showing A1 FL
Had power go off now er flashing on all burners can not reset
It's possible that you had a surge when the power returned that scrambled the controller's brain. Try disconnecting power and reconnecting to restore normal operation. Disconnect power by unplugging the stove from the wall or switching off the breaker that controls it at your main circuit breaker box. Wait a minute or two, then plug the stove back in or turn the circuit breaker back on. If the stove does not work after this, you may need a new controller board.
Aug 06, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
Was using 4 burners and they all stopped working- electric burn smell in kitchen. External house breaker is not tripped
When you used all elements the power supply wire have been
gone to the maximum current absorbed so to the maximum heat. When the cook top
is new it can withstand this heat but due to long time used now you have burned
out wires and probably to junction point. So now the power supply wire is
burned and is open circuit thus not any power to the heater. The wires have
just open circuit and they don't touch each other or the metal body of the cook
top that is why you don't have the circuit breaker fuse to trip off. So now you
need to disassemble the cook top and you will very easily find the burn point
which should be melded and burned black and replace all parts that they have
been burned with new one.
Here is the link where you find the parts layout, the wiring
diagram and also order any parts you might need.
Also just for safety, avoid to use all four heater at the
same time in the future.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170741&diagram_id=28477270#d28477270
Dec 18, 2010 | Maytag MEC5430BDS Electric Cooktop
Stove is tripping circuit breaker Two burners stopped working properly (only get slightly warm). Switched the coils to the other side and the other side is still working. Looked underneath and saw that...
if it is an old stove i would say have it serviced/checked over. if it is a newer stove i am guessing the circuit breaker predates it and is rated for the old stove therefore you will need to have a larger circuit breaker installed (by a licenced electrician)
Mar 04, 2009 | Jenn-Air Expressions AC110 Electric...
The cooktop does not come on
It sounds like the circuit breaker is kicked or the fuse is blown.
look in your electrical panel for the breaker and in the fuse box to see if the fuse is blown.
Feb 12, 2009 | GE 30 in. JP340 Electric Cooktop
No heat. could fuse be blown
IT WOULD HAVE TO BE A POWER PROMBLEM FROM YOUR HOUSE sorry about caps lock on start at house breakers and and check wiring
Oct 30, 2008 | Whirlpool RCC3024 Electric Cooktop
Can fuse be blown?
youl have to pukk out the unit and check the connection/installaiton. youll need to determine if you have proper voltage going to machine. ther if no fuse on the machine, more than like a power supply issue
Oct 30, 2008 | Whirlpool 30 in. RC8700 Electric Cooktop
Kelvinator stove
The stove has its own sepeate circuit breaker and power supply from the rest of the kitchen. Possible issues are a bad circuit breaker, power cord, outlet, or power connection at the range. Easiest checks to make first are visual burns at all these places.
Apr 07, 2008 | Cooktops
Dacor SGM304... no ignition
There is no fuses, as long as you have a power supply into unit then the only item that can cause this fault is a faulty spark generator.the hob will need to be dismatled to repair, remove the knobs, remove the burners and then remove the obvious screws, top will lift off Regards Advisor
Sep 01, 2007 | Dacor Preference SGM304 Gas Cooktop
CookTek 14 in. MC-2500 Electric Cooktop Logo
114 people viewed this question
Top CookTek Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a CookTek Cooktop Expert? Answer questions, earn points and help others
