Question about GE Profile 30" Self-Cleaning Slide-In Electric Range - Black-on-Black
Range top ignighters sparking
The 4 range top igniters continually spark in a frequency lower than
the frequency they spark when igniting gas.
    Scholar:
  • 103 Answers
One of your "switches" to your burners is shorting causing unit to spark when in the off mode, or, you may have a bug problem, bugs have made their way into the spark module.
1: if no bug problem, disconnect stove from electricity, lift top up, remove all of the single connections to each switch to top burners(make sure they don't have any bare wires touching the frame), then plug unit back in, if still sparking then replace module.
Posted on Oct 01, 2009
The spark ignition on the right front have gas but does not ignite at all. All three the others have sparks.
flint or electric probe to earth needs a clean or
closer inspection to replace the ignighter
Jul 02, 2016 | Kitchen Ranges
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
I have a Leisure Gourmet Classic double oven. The hobs, the grill and the upper oven all work fine, but the lower oven suddenly stopped producing any gas. I turn the knob and the austomatic ignition s
Apparently there is a bad valve for that oven , recommend calling a gas service repairman . your gas provider should be able to recommend a good one to you .
Apr 19, 2017 | Leisure Kitchen Ranges
Kitchen aid gas range igniters won't stop
Jammed and broken ignight switch or the spark generator transformer has a short circuit
Jul 13, 2011 | KitchenAid KGSK901SSS Gas Range
THREE BURNERS DO NOT IGNITE AUTOMATICLY ON MY SPECTRA GAS RANGE
Have your licensed repairman clean, adjust, reinstall or replace the the ground plain plate on your stove. If dirt or grease managed to get between the plate and ground it can inhibit the spark ignighter from throwing a spark accross the ignitor gap. No spark = no light (flame). Yep just like the sparkplugs in a car.
May 10, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas ignighters continue to spark after gas is ignighted.
The most posible cause is that the ingiter have been mositure probably from a water leak and have be short the wires of the ingiter. Their is a small chance that it will dry by it self and be normal again. If not you can remove the top and reach for the ingiter, is a plastic box with a lot of wires in and out and with hair dryer you can try to dry it. If it still sparking again then you need to replace the igniter
Jan 11, 2011 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Gas top range ignition stuck on sparking
The switches that are causing the sparking are located under the knobs that you turn the burners on. Lift the knobs off and you should be able to see them.
If you have just cleaned the range the switches may have gotten wet. You can try to dry them out with the hair dryer, or just let them sit for 24 hours with the range unplugged. If they continue to spark after that you will need the switches replaced.
May 19, 2010 | Whirlpool Gold GW399LXU Gas Range
GE gas range igniter continues to spark, won't shut off.
Often times, just leaving the range unplugged for a time will solve the problem, which is most often caused by water or a cleaning agent getting into an igniter switch behind a burner knob. After the switch drys out it usually starts working again. In the mean time, you can still use the burners by lighting them manually with one of those long lighters, but you will not be able to use the oven or broiler without electricity. If the range continues to spark after being left unplugged for more than a day or two, you will have to determine which switch behind the burner knobs is causing the problem. Please don't bother rating, as anything but a Fix-Ya will lower my score. Thanks.
Feb 18, 2009 | GE JGBP28 Gas Kitchen Range
KitchenAid KGCS100SAL0 Gas Range Top, one igniter doesn't work
change the ignighter switch they are mounted to the front of the knobs and must be changed as a set they look like square plastic boxes after you remove the knobs and pull the panel off the front
Jan 28, 2009 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
Igniter
Does the knob control both the gas and spark, try turning on the knob only, if it starts to spark right away then it is possible that the switch is bad. because most of these units are designed where you turn on the gas then push in and hold the knob to ignite then release and spark should stop.
Dec 08, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
GE Profile 30" Self-Cleaning Slide-In Electric Range - Black-on-Black Logo
134 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
