Question about Samsung LN-S4051D 40 in. LCD Television
Dell 1150 LCD Screen
Recently my lcd screen on my laptop started to display red dots and a red background. Does anyone know what I can due to fix this. Will replacing the inverter help?
Buy a new computer
Posted on Feb 02, 2008
Screen is displaying Red background color with glittery pixels effect around the figures
Please change the T-CON board, if it did not fix the problem, you may have a defective LCD Panel.
Apr 24, 2017 | Samsung LN52A650A LCD TV
Hi i recently started having problems with my dell inspiron 1545 screen. At first it started to freeze and fade to bright white, eventually after a few days it became stuck white even after booting the...
Hi lewis haywar,
Try to replace the LCD inverter in your laptop. Most common issues on LCD are due to failing LCD inverter. It fails more often than LCD cable or LCD backlight does.
Please let me know if this solution helped to resolve your issue.
May 11, 2011 | Dell Inspiron 1545 Notebook
My dell has issues with the graphics display,at times when i switch it on it just shows a blank greyish black screen,at other times when it works normally it will just start having a background like a tv...
You should try the cheapest solution first. Replace the LCD cable. These should be easy to find on ebay and amazon. My guess is there is a short in the cable.
Nov 29, 2010 | Dell XPS M1330 Notebook
Inspiron 1150 Latitude D600 14.1 LCD Display-LP141X14 CD-ROM Drive: I installed window xp on my DELL inspiron 1150 lap...
you need the drivers...look here...
you will need a computer thats online to download them,, put them on cd or flash drive
May 17, 2010 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
A line ppears on my dell inspiron 1420
A thin line across teh screen is an indicator that the LCD is bad. There's not anything short of replacing the screen that will resolve this issue.
Aug 31, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell Vostro 1400 LCD Showing Black Screen
If you connected the laptop to an external monitor via VGA and the display, then it is not "an NVIDIA GPU defect" .
The video chipset connected to the LCD screen is the same connected to the external VGA port, and is working fine since picture is OK on monitor.
More likely the problem is either LCD ribbon cable, or LCD display, the fact that the backlight is working means that the inverter is also working.
Apr 18, 2009 | Computers & Internet
Inspiron 1150 lines on screeN problem.
Connect an external monitor to the laptop and see if it also has the vertical lines. If the external monitor looks fine, then your laptop’s LCD display panel is bad. If the monitor has the vertical lines displayed on it, then your graphics card or motherboard is bad.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 10, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Not a typical backlight issue
You can check the brightness with AC in the BIOS and match it with running in battery or else, when you plug the ac adapter, the lcd goes dim, press and hold the FN buttong and tap the up arrow then reboot and try to see if it will still do it. But still the best way to do it is going to the BIOS by pressing F2 at the Dell logo startup.
Hope this helps!
Jul 30, 2008 | Dell Inspiron 1150 Notebook
Dell inspiration 1150 laptop
sounds like screen is blew out try rebooting it with orther screen get back to me lala linda
Apr 25, 2008 | Dell Inspiron 1150 Notebook
Windows could not start
you can use any xp install fresh copy not sure you know someone who could lend you a copy for couple of hours
Feb 20, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Samsung LN-S4051D 40 in. LCD Television Logo
113 people viewed this question
Jerry Greenberg
Jerry Greenberg
