Question about Samsung CLX-3175FN Color Laser All-in-One Printer
I have a paper jam when the page is 2" out of the fuser. Jams everytime
  • 42 Answers
This looks like a problem with the rollers, because it happens every time. Check out a solution here http://annoyances-resolved.blogspot.com/2009/09/paper-jam-buy-new-laser-printer.html and let me know here if it helped.
Posted on Oct 01, 2009
Testimonial: "I learned this from a repair guy some time ago. I have cleaned what I can but perhaps the critical rollers I can get to"
5 Suggested Answers
  • 208 Answers
SOURCE: Paper jam 2 fuser
1. Faulty/blocked fuser exit sensor or faulty/blocked POB sensor. The printer thinks paper is present at one of these sensors when there should not be paper present. Verify that the fuser exit sensor is not stuck Verify operation of the POB sensor If both sensors are working correctly, the most likely cause is the POB sensor is being blocked by the transfer unit. This can happen if the sensor is out of position, or if the transfer unit's white plastic baffle is out of position. Try bending the POB sensor bracket outward slightly to clear the baffle and retest
Posted on Dec 20, 2007
ctf1800
  • 4402 Answers
SOURCE: HP LJ 1020 Output Page Jams @ Fuser input
either your fuser is bad or output rollers, I put my money on the fuser
Posted on Mar 26, 2008
yooperbud
  • 8637 Answers
SOURCE: Lexmark E238 paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 22, 2009
ynogami21
  • 670 Answers
SOURCE: paper jams at half printing, have cleaned all
It seems that this problem is known to this model of Samsung printers.
http://www.techsupportforum.com/forums/f109/paper-jam-samsung-clp-315-a-350102.html
It is said that the exit sensor of the printer is the cause of the problem and that it needs to be replaced.
Here's a link of the part number to be replaced.
http://www.partstore.com/Part/Samsung/Samsung/0604001393/New.aspx
Remember the steps to replace this part is on the first link that I posted if you're uncomfortable doing it I suggest you call Samsung for the help of a technician or otherwise proceed with great caution as exposed parts are easily damaged.
Hope this helps!
Posted on Jul 18, 2011
Paper jams at toner cartridge, printer service maintenance kit installed
Paper Jam clearing: copy and paste the link in your web browser...I used to work with these printer's..when they work great, when they don't, not so great..
https://www.manualslib.com/manual/949165/Hp-Laserjet-5000.html?page=84
Clearing Paper Jams If the printer's control panel displays a paper jam message, look for paper in the locations indicated in Figure 22, then see the procedure for clearing the paper jam. You might need to look for paper in other locations than indicated in the paper jam message. If the location of the paper jam is not obvious, look first in the top cover area.When clearing paper jams, be very careful not to tear the paper. If a small piece of paper is left in the printer, it could cause additional jams. If paper jams are a recurring problem, see page 78.(A paper jam message might also display if the rear door is open.)
The top cover of the printer must be opened and then closed to clear a paper jam message.Paper jams can occur at the following locations:Output areas(top and rear)Go to page 75.
Loose toner might remain in the printer after a paper jam, but thetoner should clear after a few sheets are printed.
Jan 31, 2018 | HP LaserJet 5000n Printer
My Dell 1720dn constantly has paper jams. A
I am having the same problem, did this get resolved?
Dec 02, 2009 | Dell 1720dn Laser Printer
Brother MFC 7420 - paper jams in fuser unit -
Its probably the pickup roller and/or separator pads. Another possibility is a tear in the fuser heat cover. IF you can manually rotate the fuser(when its cool) you can see if the fuser roller has any problems. Last thing is make sure its looking at the right paper size. Maybe reset all software settings and start over? If its looking for one size and seeing another, it may cry jam.
Feb 02, 2018 | Brother Office Equipment & Supplies
I have a total of 10 HP Color LaserJet 4650 printers, and 7 of them have the following problem: they jam at the fuser whenever a full-color picture, photo, or slide is sent to print (especially ones with...
This jamming has to do with third-party toner cartridges being used. I had this problem using Xerox toner cartridges and found that I would have no jamming if I used at least 2 hp-brand toner cartridges and the rest Xerox. I then used a different brand of 3rd party toner cartridges that would not jam as long as just the black cartridge was a genuine HP black toner cartridge. This issue has been confirmed even by the manufacturers of the generic toner cartridges. Hope that helps!
Oct 15, 2009 | HP LaserJet 4650 Color Printer
Constant paper jams in lexmark t614
it would help to have a bit more information on where the paper jams. but ill give this a shot any way. 241 jams clean or replace the pick wheels on the auto compensator. 201 jams no paper present change main motor drive. paper stops 3 inches through the fuser timming issue check the paper size i the paper menu check the fingers on the side of the tray letter is the 2 bottom fingers sticking out. if you have network port print the network page if it is smaller than the page change paper selction pcb located behind the logic pack. if the the line at the bottom of the read out is missing and the box is incomplete the printer is reporting leagal size paper change the paper size pcb. 202 errors check the sensor flags on the fuser. there are 2 sensors on the fuser the one on the left is the narrow media sensor the one on the right is the exit sensor. check to make sure the sensor flag is not broken. check them for fluid movement if you cant hear them snap back replace the sensors hope this helps you out
Oct 01, 2009 | Lexmark Optra T614 Laser Printer
Lexmark C710 MFP jams 200.04
Things to try:
1. Look for a piece of paper jammed in the rollers. 95% of the time that is what it is.
2. You have a paperclip or paper wad in a feed roller or gear.
3. The hard and easy way to find the jam is to feed a piece of paper and then before it feeds all the way through unplug power to the machine about the time where it usually jams.(several times may be necessary) Then follow the piece of paper to where it jams to find the location of the clogged paper.
Sep 15, 2009 | Lexmark Optra C710 Laser Printer
Paper Jam
If you are getting a lot of jams in the fuser then there is a problem in the fuser unit !
Is it jamming like an accordion? if Yes, then the problem is w/ the little fingers in the fuser, they are worn and need to be replaced. The rollers in the fuser should be shiny and smooth if not they ca also cause jams.
What black thingy are we talking about and where? if it's the fuser rollers ( where the paper exits and gets hot then try cleaning w/reg soap & water rag then wipe off.
Nov 17, 2008 | Sharp AR-153E Copier
Printer always jams
check your toner cartridge and also u need to service the printer fuser aseembly.also change roller.or taplon tape.
thats all
also see there is not any paper jam in parts.
Oct 09, 2008 | Lexmark X2500 All-In-One Printer
Mar 26, 2008 | Office Equipment & Supplies
PAPER JAM
Did not specify where it is jamming?
is the paper size correct?
is the paper under the metal tabs in the tray?
is it jamming in the fuser?
is the fuser OK, if constant jamming in fuser then replace.
Jan 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
Samsung CLX-3175FN Color Laser All-in-One Printer Logo
359 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
